Notes on Xcal2: Problems and Resolutions - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Focus Tuning Chat
Old 03-01-2009, 10:42 AM   #1
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 11,949, Level 71
Points: 11,949, Level: 71 Points: 11,949, Level: 71 Points: 11,949, Level: 71
Level Up 75% Completed
FF Reputation: 77 S0C0nFused Excellent Standing Member
Xcal2 Problems and Resolutions.
These are my notes and problem resolution regarding the Xcal2. These are intended to address some common or uncommon issues (new) users may encounter. These are based on personal experience and follow the form Problem / Resolution. There may be more than one Resolution to an issue. Also note that I do own the SCT advantage (Pro Racer) package. So issues may be specific to the loading of tunes from a PC. It is hoped that others will provide there Problem and Resolutions as well.
Problem:
Xcal2 Cannot read DTC codes, read strategy or perform other functions while connected to the OBDII port.
Resolution:
If the Xcal2 is brand new. Gently clean the contacts with Isopropyl alcohol or electrical contact cleaner.
(Manufacturers will often apply a light oil to electrical contacts to prohibit corrosion and extend shelf life. Over time this coating can harden)
Resolution:
(Advantage III)
Delete and reload all tunes.
(While loading a tune from PC (WinXP Pro). I had several other programs running. Xcal2 became corrupted. HINT: turning key on when instructed by Xcal2, The vehicle chime was inhibited. All Xcal2 functions went to timeout.)
Problem:
OBD-II port fuse is blown.
Resolution:
Replace OBD-II port fuse.
(Note: It is possible to plug the Xcal2 plug 'upside down' into the OBD-II port. No damage occurs to Xcal2).
Problem:
Loading a tune does not complete. (specific error not recorded)
Resolution:
Insure that the Fuel Pump fuse (50 amp) and the Engine Fan fuse (15 amp) are pulled before attempting to load a tune. Also turn off radio, Interior heater fan etc.
Resolution: Insure that the cord of the Xcal2 is not wrapped around your foot or otherwise subject to movement / disconnection during the load process.
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
Old 03-01-2009, 04:36 PM   #2
Blivit
Blivit's Avatar
Fan#: 51292
What I Drive: 2013 ST
Points 2,287, Level 28
Points: 2,287, Level: 28 Points: 2,287, Level: 28 Points: 2,287, Level: 28
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 118 Blivit Excellent Standing Member Blivit Excellent Standing Member
Originally Posted by S0C0nFused View Post
Problem:
Resolution:
Do what?
Cleaning contacts has nothing to do with the X2. If the device does not read anything, check fuses and check for a chip already installed in the processor.
Blivit is offline
Old 03-01-2009, 04:40 PM   #3
Blivit
Blivit's Avatar
Fan#: 51292
Problem:
Xcal2 will not communicate with laptop for data logging session.
Resolution:
Enable the laptop serial port in the laptop BIOS settings.
X2 does not use a serial connection. It uses USB through a virtual com port (which is why there is an actual com port number as USB does not use com ports normally.)
The com port in livelink actually does nothing with the X2. It was a carry over from one of our older devices.
Blivit is offline
Old 03-01-2009, 07:38 PM   #4
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
Originally Posted by Blivit View Post
Do what?
1st time I hooked up my Xcal2, it could not read DTC, Strategy, load a tune etc (several insertions). I corrected the problem by cleaning the contacts on the Xcal2. I did nothing else. After than it had no issues.
As I said, these are personal experiences. Now perhaps it was the OBD-II port that needed cleaning as insertion was wet. BTW: All fuses were good and I don't have a 'chip' to install. Or are you saying you were not aware of the coating?
Old 03-01-2009, 07:42 PM   #5
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
Oh wait. Crap! Wrong device! Ok. Now what was I doing where I had to enable the serial port??? But your right Blivit. Heck I knew that, the Xcal2 is sitting right here. Will edit that out. Thanks!
(actually, I was expecting more comment about how I managed to plug the cable in upside down! )
Old 03-01-2009, 08:11 PM   #6
Blivit
Blivit's Avatar
Fan#: 51292
I am well aware of non-conductive paste on electrical connections. However, I have never encountered it in the ALDL connector on any vehicle I have ever worked with.
Blivit is offline
Old 03-01-2009, 09:24 PM   #7
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
Like I stated Blivit. All I did was clean the connectors and then it was working. Before cleaning, nada!
