Yellow ! light comes on - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-01-2009, 09:29 AM   #1
rgvtx
Fan#: 61243
What I Drive: 2001 SE Wagon
FF Reputation: 1 rgvtx Good Standing Member
I have a 2001 Ford Focus SE with the zetec. I bought it new and it has less than 50K miles. The exclamation point (!) light comes on while driving, the car stumbles and sometimes dies. It will re-start occasionally and sometimes not. The owners manual says it a multi function light for the cooling system and the transaxle. The transaxle is full and the fluid does not appear or smell burnt. There was a leaking heater hose (pin hole) that I replaced so now there are no coolant leaks and the level is full. This problem started the same day I replaced a bad alternator ( several months ago). I replaced the temperature sensor behind the alternator gussing that was the problem (thinking I may have damaged the wire or plug when I replaced the alternator), but the problem persists. I plug in the pocket OBD2 sensor but get zero codes every time. I was told the scanner will only read a code if the check engine light comes on. The only light that comes on is the yellow ! light. The engine stumbles I assume because it cuts back to 2 cylinders. Most times you can accelerate and it keeps running and the light goes out. Sometimes it dies and quickly restarts. Sometimes it dies and won't restart. I tow it home and it starts, maybe after cooling off? Yes I have unhooked the battery to reset with no positive results. Ideas?
rgvtx is offline
Old 03-01-2009, 09:45 AM   #2
sjdwales
Wales!!
sjdwales's Avatar
Fan#: 46854
What I Drive: 11 mustang
Points 15,624, Level 80
Points: 15,624, Level: 80 Points: 15,624, Level: 80 Points: 15,624, Level: 80
Level Up 55% Completed
Forum Activity 2%
FF Reputation: 13 sjdwales Great Standing Member
Buy-Sell-Trade Rating: (26)
i have the same problem, the rpms just sky rockets as well, i think it has something to do with the throttle cables. one of my cables wasn't connected properly and got caught on a intake gasket and couple other stuff. sometimes the car just dies/stalls(drive auto). since i put the cable back on properly ive had no problem, 3hrs west, then 3hrs back and still no problems.
No longer drives a focus, WTF?
sjdwales is offline
Old 03-02-2009, 04:46 AM   #3
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
Buy-Sell-Trade Rating: (4)
For an automatic equipped car like yours (I assume) that light related to transmission temperature for the most part. Meaning that the transmission is overheating. That could be due to the oil being old and not having the same capacity to deal with heat, my best guess, and possibly due to a dirty transmission filter, or combination there of.
Being I'm doubtful it's been done, I would recommend a transmission flush and filter change and go from there. Preventive maintenance if for nothing else.
I think I have also seen some mention that the shift solenoids may be associated with that light, but that should trigger a check engine light also being there are codes for them.
If on the off chance your car is a manual transmission that light is for Evaporative Emissions. Most likely a vacuum hose to the Purge Solenoid came loose (was my issue more than a few times, zip tie on the line solved that). But this only applies to the manual.
OH, you're not playing dumb ...
iminhell is offline
Old 03-02-2009, 06:27 AM   #4
hontoir
hontoir's Avatar
Fan#: 61146
What I Drive: None currently
FF Reputation: 1 hontoir Good Standing Member
In mine the yellow ! is the engine management light. And i had symptoms similar to yours, mine was a manual however, and it needed a new coilpack
hontoir is offline
Old 03-02-2009, 07:10 AM   #5
burkej62
Fan#: 62689
What I Drive: 2002 Focus Zx3 5 speed, air ride.
FF Reputation: 1 burkej62 Good Standing Member
Electrical issues can cause it to come on as well. On mine when my coil pack connector was loose it would break up around 5k and everything would come on.
burkej62 is offline
Old 03-02-2009, 03:40 PM   #6
zx32nr
zx32nr's Avatar
Fan#: 43460
What I Drive: 2007 pitch black zx3 ses
FF Reputation: 16 zx32nr Great Standing Member
mine came on when i was out of coolant from a hose snapping
Zetec Crew #175
REP WHEN REP IS DUE
shorty header, magnaflow 2 1/2 catback, 65mm TB, pipercross viper, cfm pully set, sct reflash, steeda STS, screemin deamon coil, livewires, and a damn good driver
zx32nr is offline
Old 03-02-2009, 03:44 PM   #7
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
mine comes on when i hit large bumps
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 03-02-2009, 03:59 PM   #8
e2amnuel
Fan#: 53777
What I Drive: 2003 Black SE Wagon
FF Reputation: 1 e2amnuel Good Standing Member
check your shift solenoids, many references in the fourms
very easy to replace. it sounds like the tranny goes into neutral? any DTC's?
P0750 shift solenoid A malfunction most common with your tranny
e2amnuel is offline
Old 03-02-2009, 04:00 PM   #9
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
mines a manual and it isnt going into nutral when i hit bumps thou
FF MODERATOR
RIFF CREW
Old 03-02-2009, 04:38 PM   #10
cwatson411
cwatson411's Avatar
Fan#: 60321
What I Drive: '03 Torador Red ZTS
FF Reputation: 6 cwatson411 Good Standing Member
Buy-Sell-Trade Rating: (-1)
i have a friend that had problems with the tranny's solenoids.
if the tranny flush doesnt help anything, i would look into those^
-Cory
Snoochie Boochies
cwatson411 is offline
Similar Threads
WEIRD Battery light on, but no problems...? DetroitBass General Technical Chat 27 08-10-2011 10:41 AM
What's the yellow bottle cap light with the exclamation point QQQQ General Technical Chat 35 04-16-2007 09:54 AM
emission light thepaz420 General Technical Chat 4 10-06-2006 08:27 PM
After Counter Weight Delete Dash Light on tazz3131 General Technical Chat 2 09-26-2006 08:22 PM
