How-To Light up your door handles... - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 05-11-2012, 06:47 PM   #21
OrangeSVTguy
Get Squashed
OrangeSVTguy's Avatar
Fan#: 33384
What I Drive: '04 Comp. Orange SVT 3dr.
Points 73,307, Level 100
Points: 73,307, Level: 100 Points: 73,307, Level: 100 Points: 73,307, Level: 100
Level Up 0% Completed
FF Reputation: 44 OrangeSVTguy Great Standing Member
Buy-Sell-Trade Rating: (16)
^Yeah but that kind of defeats the purpose. Wouldn't you want to see the door handle in the dark before opening it?
Lee
SVT Squad #227 || Build # 1329 of 1978 || FF ROTM Oct. 2006
OrangeSVTguy is online now
Old 05-11-2012, 09:04 PM   #22
Logoris
Fan#: 60420
What I Drive: 2009 VW Rabbit silver
Points 1,108, Level 18
Points: 1,108, Level: 18 Points: 1,108, Level: 18 Points: 1,108, Level: 18
Level Up 8% Completed
FF Reputation: 1 Logoris Good Standing Member
Originally Posted by slydarkwolf View Post
only thing i would suggest is take some 400 grit to the leds , it will defuse the light so you dont get hot spots you just get the glow
and the door handles looked great you just need to add a backing inside so it doesnt show through,
all in all great work
Logoris is offline
Old 05-11-2012, 11:45 PM   #23
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
What I Drive: '03 SVT EAP "Eurotrish"
Points 2,073, Level 27
Points: 2,073, Level: 27 Points: 2,073, Level: 27 Points: 2,073, Level: 27
Level Up 49% Completed
Forum Activity 9%
FF Reputation: 22 Sniper Focus Great Standing Member
Buy-Sell-Trade Rating: (13)
^^^ Or buy some wide angle flat top LEDs and call it a day.
The wavelength of color red will disappear in you night vision, so it wont be as distracting.
Fox Hound: Liquid Stang - Sniper Focus - Decoy Escort (or was it a Tracer...)
Sniper Focus is online now
Old 05-12-2012, 06:38 AM   #24
BIMMERKID21
Fan#: 98852
What I Drive: 2001 Ford Focus ZTS Twilight Blue
Points 508, Level 10
Points: 508, Level: 10 Points: 508, Level: 10 Points: 508, Level: 10
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 1 BIMMERKID21 Good Standing Member
what type bulbs do you need for the window buttons? that looks sick!
Originally Posted by devil_dog_switch View Post
This is another of a few How-Tos to come from me in the next few weeks...
this one is to light up your inside door handles, this one requires a little bit of dexterity...
oh and i'm sorry for no pictures of during install, i'l get a few showing the wiring and all that later on, but i didn't think about getting them during install as i was in a hurry to beat the sunlight.
Tools/Supplies Needed:
Wire (I used 16 gauge but really the smaller the easier it will be to wire, but harder to solder)
Soldering iron
Solder
3mm LEDs (your choice of color, you may also go with 5mm for brighter glow but it will be harder to hide)
12v Resistors
Shrink tubeing or electric tape
Drill with 7/64 drill bit
Cutter
Optional: glue of some sort, I used gorilla glue.
Steps:
Ok first off pop your door handle covers off, this can be done using a flathead screwdriver to the bottom center of it, between the cover and the rest(if you've ever taking your doors off you'll know how already).
Next drill holes, i used two but you may do up to five if you want a REALLY bright area.
Now depending on where and how many of these little holes you drilled taek something, i used a small peice of wire, and measure aprox the distance of the holes and cut bridging wires from each, don't worry if you measure from hole to hol exactly, you'll have PLENTY of slack when you are done.
Now where the dexterity comes in play. solder the LEDs and resitor into a circuit.
the way it goes is like this...
12vsupply-------resistors-----LED----2ndLED---(or more)-----ground
you only need one resistor in the line to make them all work right, and it MUST be before the first one. this way you have less wires in such a small area. make sure to insulate the sides of the LED tails so they won't touch, and when soldering, you don't need a whole lot.. i found that one out. the more you solder the better you will get though trust me.
now take your LEDs and put them in the holes predrilled, you'll find they won't fit... that is ok, what you want to do is take that drill and open it up a little.. a snug fit is perfect a loose fit is ok too. here's why....
what I did was i got a decent fit going and put a dab of gorilla glue on it.. not a whole ton, just one drop, it's enough to hold it in throughout regular use and door vibrations (speakers, road, opening and closing) but thin enough that you can pop it loose if need be later with a little chipping or whatnot. to hold the LEDs in place if it is a loose fit (while the glue drys) just get some tape and tape around the handle, you should be able to make it hold it tight enough overnight.
if you choose not to use glue, get some good tape and try to make it a snug fit.
now run your wires up the handle and thru the little opening under your switches, from there wire it anyway you like.. mine go thru my door jams to a central switch that all my lights will be hooked up to.
it is a bit of a tight fit yes, but it does fit, and it gives an interesting look, definitly a custom look.
end look: (using 2 3mm bright blue LEDs)::
and yes i did a blue LED swap to the window buttons.. i've been a busy little bee lately..
BIMMERKID21 is offline
Old 05-16-2012, 02:51 PM   #25
tkheaven
tkheaven's Avatar
Fan#: 59098
What I Drive: 2002 Pitch Black ZX3
Points 1,155, Level 18
Points: 1,155, Level: 18 Points: 1,155, Level: 18 Points: 1,155, Level: 18
Level Up 55% Completed
FF Reputation: 3 tkheaven Good Standing Member
I'd like to know how a 2002ZX3 can get the locks to light up. I tried but failed..
"possible" cloning of humans - check
"possible" evolution from non-living particles - check
"possible" time travel aka Big Bang machine - check
creating the perfect pres. candidate and send him back eight years ...impossible...
tkheaven is offline
Old 06-04-2012, 08:31 PM   #26
VinnyB
VinnyB's Avatar
Fan#: 97705
What I Drive: '03 Screaming Yellow EAP
Points 1,199, Level 18
Points: 1,199, Level: 18 Points: 1,199, Level: 18 Points: 1,199, Level: 18
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 18 VinnyB Great Standing Member
Here's my version of this mod:
Fuschia:
Blue:
Center console switch:
It's wired to my dash lights, and the switch on the center console lets me turn them off independently of the dash/headlights.
Also, I added a 2 pin molex connector to the LED's & power line so I can switch the colors whenever I wanted. My ride is yellow, so there's a few different colors that compliment it, lol.
If it wasn't for law enforcement & physics, I'd be unstoppable.
VinnyB is offline
Old 06-04-2012, 09:27 PM   #27
ottotroll
ottotroll's Avatar
Fan#: 63610
What I Drive: Now -2002 svt.....build #3789
Points 1,476, Level 21
Points: 1,476, Level: 21 Points: 1,476, Level: 21 Points: 1,476, Level: 21
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 4 ottotroll Good Standing Member
interesting idea?
ottotroll is offline
Tags
interior leds , interior lighting
Similar Threads
Emergency Brake Light Popping On? JohnMichael General Technical Chat 7 08-17-2007 04:37 PM
emission light thepaz420 General Technical Chat 4 10-06-2006 08:27 PM
After Counter Weight Delete Dash Light on tazz3131 General Technical Chat 2 09-26-2006 08:22 PM
Fog light Mod??? DilSVT MK1 Focus 3 02-26-2004 12:38 PM
