#11 | ||||
2005 foci key will not come out
I have a 2005 zx3 that we can turn on and off but the key is stuck in the ignition and will not come out we bought it used with 74k on it it has just over 80k on it now but we did notice that when we move it to park or any other gear we can do so without having our foot on the brake just want to make sure the sensor is our issue as well and if that will fix ours if we remove the console and either clean it or replace the sensor
#12 | ||||
Posted via FF Mobile |
#13 | ||||
Key stuck in ignition
Went to Ford dealership to get key out of ignition and they said "You need a new gear shift assembly". I asked them to show me the problem. They said that they has already put the assembly back together. Well the aassembly was dusty, and there were no fingerprints in the dust. So I took the car home. Called a mechanic friend of mine. He found that the little screw that holds the shifter knob in place was loose. He tightened the screw and the key came out.
#14 | ||||
Well i'm going to play with my '05 ZX5 tonight and see if i can get the key out! thanks fot posting your experiences on this issue.
#15 | ||||
stuck key
Last night i tried popping the button with no luck. Removing the negative cable from the battery did the trick so i think i'm heading the right direction. I'm going to start taking the center consel apart this weekend. Any advice? Where is this sensor/any screw i might need to tighten be located?
Thanks!! |
#16 | ||||
i'm having the samw problem on my '05 zx5. i'm hoping to tackle this prob this weekend, where is the sensor located? Thanks!
#17 | ||||
The sensor is inside the shifter column. The screw is a hex screw on the left had site of the shifter knob. Make sure that screw is lined up with the thread hole on the shifter. When the holes line up, you will not the little connectors inside are fully connected.
#18 | ||||
thanks to everyone for your help. I found that the electrical connecter was a bit gooey from some type of soda, cleaned it up and so far so good, the car is back to normal!
#19 | ||||
#20 | ||||
Gets more V8
yup nice that happens to a few cars I get once in a awhile. interesting fix though I ought to try that.
SR #127 | '02 Focus SE "Foci" (5.0 in progress) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-selling) | '94 Toyota 4Runner SR5 "Roach" (daily-stockish) Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Every trouble code defined | 03OrangeSVT | General Forced Induction | 9 | 05-25-2011 12:53 PM |
| Could use some help please? | Iceberg | General Technical Chat | 13 | 06-30-2009 09:26 PM |
| Damn Key is Stuck! | Focusedat50 | General Technical Chat | 38 | 11-07-2005 05:34 PM |
| Key getting stuck? | zx3cutieinoc | General Technical Chat | 14 | 08-08-2004 04:36 AM |
