Ignition key stuck due to shifter? Help Please - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-23-2009, 11:49 PM   #1
JoshCF
Fan#: 62995
What I Drive: 2007 Silver 4d coupe
FF Reputation: 1 JoshCF Good Standing Member
I have a 2007 Focus 4d coupe with 2.0 engine & Auto tranny. Today when I got to work I could turn off the engine with the ignition key, but not switch it to the "LOCK" position to remove the key. When I got home we started checking things out and have found out that if we remove the neg battery cable I can turn the key to the lock position and remove the key. I can insert, turn the key, go back to lock and remove the key OK as long as battery cable is off. As soon as it is connected then I can start the engine and drive the car OK, but I'm back to not being able to move the ignition switch to the LOCK position and remove the key again until I first remove the battery cable. I checked with a friend at FORD who says there is a sensor (or switch) in the shifter for the automatic transmission that will not let the ignition key move to the lock position until it senses the transmission has been shifted into "P" (park). I am putting the transmission in park before trying to turn off the engine and remove the key.
Of note, the transmission shift indicator (the little red line that moves when shifting gears) only moves to the "N" position when I put the shifter into park, but it has been this way since I bought the car last year and I never had this ignition switch problem before.
Has anyone else had this problem, and if so, how did you repair it? I'm new to this forum and tonight is my 1st time visiting. Any help will be very much appreciated. Thanks in advance!
JoshCF is offline
Old 02-24-2009, 06:34 AM   #2
death_bomber
Aggresive Not Crazy
death_bomber's Avatar
Fan#: 39461
What I Drive: 2001 RED LX
Points 5,773, Level 49
Points: 5,773, Level: 49 Points: 5,773, Level: 49 Points: 5,773, Level: 49
Level Up 12% Completed
FF Reputation: 6 death_bomber Good Standing Member
i wold try tinkering around the area, try removing the center console to see if the sensor is visible. if its visible but still not working you could just do a swap yourself instead of taking it to the dealership.
death_bomber is offline
Old 02-24-2009, 08:29 PM   #3
JoshCF
Fan#: 62995
Good news, the problem has been fixed - thanks to my dad. He removed the center console and did in fact isolated the trouble to the shifter position switch there. He was able to fix it saving me the $180 the dealer wanted for a new shifter assembly. The problem was a sticky mess under the console caused by spilled soft drinks (and maybe a beer or two, and no I don't drink and drive any more) and other crud. After a couple of hours of cleaning and re-assembly everything is working correctly again. Even the gear selection indicator (the little red line showing which gear the shifter is set to) works like it should again. The sticky mess must have been interfering with the gear selection sensor. I would never have thought this would have prevented the ignition key from moving into the lock position and preventing the key to be removed. But I guess it makes sense when you think about it. You don't want the steering wheel locking before the car is in PARK as the car could still be rolling. "Thanks, Dad!"
JoshCF is offline
Old 02-24-2009, 08:45 PM   #4
gonzorelic
gonzorelic's Avatar
Fan#: 13348
What I Drive: 2003 Pitch Black SVT Focus ZX5
FF Reputation: 31 gonzorelic Great Standing Member
glad you quit drinking and driving. also glad you got the problem fixed.
Jealousy is contagious,
Get well soon bitch!
WWW.PATTERNTEK.COM
WWW.SNAPOFFRACING.COM
gonzorelic is offline
Old 02-24-2009, 11:04 PM   #5
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Yup. I believe this "feature" was added many years back after some people sued the automobile companies when they got out of the car with the car not in park and they were knocked down by the door as the car rolled backwards. This "feature" provides a good court defense in these cases, since they cannot remove the key without having the vehicle in "Park."
penguin is offline
Old 02-24-2009, 11:06 PM   #6
penguin
Fan#: 21700
penguin is offline
Old 02-27-2009, 02:20 AM   #7
Gro Harlem
Fan#: 63000
What I Drive: 2001 Blue WAGON
FF Reputation: 1 Gro Harlem Good Standing Member
Crap...i have this same problem this morning on my 01' Wagon. I was like freaking out as to why it wouldn't come out of the ignition. I just bought the car & the interior was pretty disgusting with soda spills so hopefully that switch is the culprit. No time to remove the console right now, so I just left the key in the ignition & am using the keyless remote to lock the doors & get back into it later.
Hopefully no one steals it lol.
Gro Harlem is offline
Old 02-27-2009, 12:05 PM   #8
Feral
Feral's Avatar
Fan#: 58350
What I Drive: 1 2002 / 2 2001 Wagons
FF Reputation: 53 Feral Excellent Standing Member
Buy-Sell-Trade Rating: (23)
when you in the car depress the shifter and just slide your finder away from the shifter button letting it pop out on its own eventually it will free the safety switch.. mine does that on my new car already '02 wagon.. as mentioned tho I just depress the button with the edge of my thumb and just slide it out of the way letting the button pop out with force
Wagon Partout - http://www.focusfanatics.com/forum/showthread.php?t=212282
My Wagon Rebuild - http://www.focusfanatics.com/forum/showthread.php?t=217009
Feral is offline
Old 08-23-2009, 08:16 PM   #9
mjseibert
Fan#: 53875
What I Drive: 2007 Gold Ford Focus
FF Reputation: 1 mjseibert Good Standing Member
I have an '07 Focus as well with the same issue. Where did you get your new shifter position switch and is that the actual name for it? I can't seem to find the part anywhere.
mjseibert is offline
Old 08-23-2009, 08:50 PM   #10
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
^Read carefully
He didn't get a new part, his dad took tools in hand, removed the console, and cleaned the mess created by spilled drinks.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Similar Threads
Every trouble code defined 03OrangeSVT General Forced Induction 9 05-25-2011 01:53 PM
Could use some help please? Iceberg General Technical Chat 13 06-30-2009 10:26 PM
Damn Key is Stuck! Focusedat50 General Technical Chat 38 11-07-2005 06:34 PM
Key getting stuck? zx3cutieinoc General Technical Chat 14 08-08-2004 05:36 AM
