#1 | ||||
Code P1246
Hye guys,
I have had the P1246 code showing up in my Predator. It has not caused a CEL but ever since I have been getting this code I have noticed a new symptom. The code reads IIRC Alternator Load Input. Now sometimes when I stop at a light or sit at idle the car sometimes will start to sputter. The idle will fluctuate a little. It does the same thing to when I turn the heat on. If I turn it off, the idle will go back to normal. Now what I am trying to figure out is, does the P1246 code only mean that the Alternator is going out? I tried searching the code but not a lot came up. If the Alt. is going out, would that cause the syptoms I list? Let me know guys. Thanks
2003 Vermillion Red SVTF #1606 |
Remove Advertisements |
Fan#: 1
#2 | ||||
C2H5OH
To me that sounds like 1 of a couple possibilities. A. You have underdrives are are not tuned for them. Though I don't think that really happens, possible though I'd think. B. The alternator is not making a good ground to the block. Corrosion or maybe a lackluster engine ground. C. The "alternator clip" has failed or is failing. --> http://www.focusfanatics.com/forum/showthread.php?t=104396 C. would be my best guess as it makes the most sense to me. |
#3 | ||||
Well we can take #1 off cause I do not have any UDP's. Thanks for that info. I will look into those possibilities. I really hope the Alt. itself is not going bad cause I do not want to buy a new one or have to go through putting it on.
#5 | ||||
I have not paid attention to lights. I just freak out becuase it idles all wierd and stalls on me. Or at least it stalled on me today while the idle was going crazy. I will give that a look tomorrow.
#6 | ||||
Well I checked the alt. clip. All the wires are intact. Could the clip still be bad?
I have not checked the ground yet. The wierd idiling that happens when I stop is driving me crazy.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Need Ford Recall, TSB, or your vehicle history? Click Here! | DJ Lukdogg | General Technical Chat | 368 | 10-13-2008 05:04 PM |
| Installed Toms Tune - Pull Trouble Code P1246 | 03SVTFoci | Focus-Power Tuning | 8 | 09-04-2007 06:12 AM |
| Installed Tom's Tune - Pull P1246 Trouble Code | 03SVTFoci | Focus-Power Tuning | 3 | 08-29-2007 06:29 PM |
| DTC code P1246 - should this set of a CEL? | onebluemcm | General Technical Chat | 1 | 06-18-2006 09:28 PM |
| how to deal with this code P1246 | onebluemcm | General Technical Chat | 0 | 05-06-2006 09:27 AM |
