Race Engineering Pistons - N/A build - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-22-2009, 05:49 PM   #1
yellow2000S/R
Fan#: 58422
What I Drive: ZX2
FF Reputation: 1 yellow2000S/R Good Standing Member
Visiting from the ZX2 forums. Not many do serious builds over there and the aftermarket applications are more geared towards the Focus so I'm here asking.
I'm doing a N/A build and its come down to just needing pistons, bearings, and a bunch of machine work then assembly.
I am debating the way to go about increasing compression. Orriginally I was going to go with 10.5:1 JE pistons and get the head milled some to give me approximatelly 11.5:1 compression. I then came across Race Engineering pistons and they have a 12:1 option and it is also on sale. I'm wodering if anybody has experience or has heard/read reviews on their products. I'm really thinking about it because if I get boored with the N/A setup I could just swap pistons and probably the cams (cams have a lot of duration which isnt good for boost) putting my Crower stage 2 FI cams in and be good to go forced induction.
http://www.raceeng.com/p-7920-focus-...on85mm121.aspx
My mod/parts list for those curious.
Engine/Trans:
SVT intake manifold
Kamikazee header - ceramic coated
2.5" Trubendz SS exhaust - HF cat, 18" res, borla
180* Thermostat
Powder UDP
30 lb injectors
ES engine mount inserts
P&P Focus head (still working on it)
Crower Retainers
Crower valve Springs
Crower Rods
Crower custom grind cams - Duration: 265/268, Lift: .464/.468, RPM range: 9,000+
Focus-Central adjustable cam gears
Stainless clutch line
MFactory LSD
TWM Short shifter
Spec Stage 2 clutch
Fidanza Flywheel
Tuning:
SCT XCal-2 Flash device - may have to go standalone from what I've been reading
Suspension:
BC Racing inverted coilovers (havent gotten yet... waiting on final confirmation from them for fitment)
ES sway bar endlinks
Escort GT 21mm rear sway bar
Brakes:
Precision Brakes 13" big brake Front upgrade
Escort GT Rear disc conversion
Precision Brakes 12" big brake Rear upgrade
Stainless brake lines
Motul brake fluid
Wheels/Tires:
17x8" Motegi TrakLite2 - 14.6 lbs each
215/40/17 Nitto Neo Gens - not sure if I'm going to instal them or sell them and purchase 225/40/17 Dunlop Direzza Sport Z1 tires
yellow2000S/R is offline
Old 02-22-2009, 06:12 PM   #2
mlbbaseball
Shot me 3 deer!!!
mlbbaseball's Avatar
Fan#: 53541
What I Drive: 02 SVT, 2 7.3 L Diesel Excursions!
Points 27,869, Level 98
Points: 27,869, Level: 98 Points: 27,869, Level: 98 Points: 27,869, Level: 98
Level Up 52% Completed
Forum Activity 3%
FF Reputation: 42 mlbbaseball Great Standing Member
Buy-Sell-Trade Rating: (69)
Do u plan on running race gas??? you can check out my profile, i have a maxed out NA build
Now I rive 2 7.3 L diesel trucks!
mlbbaseball is offline
Old 02-22-2009, 06:50 PM   #3
yellow2000S/R
Fan#: 58422
What I Drive: ZX2
I'd "like" to have a tune that I can run 93 for some occasional street use that has the timing retarded a lot but for the track have an aggressive tune and race gas.
I saw the topic for C-F-Ms 175whp zetec and they found the stock intake manifold a restriction (I'm hoping that the SVT mani helps in that area). They ran a 14.09 at 94 with slicks... full interior.
The cams I have were bought from a e-bay buyer that bought them from fasterthanu68 who bought them from Dennis Hilliard of Focus-Central. It is claimed the Focus (ketchup) ran a 12.9@106 (but from research the car was fully stripped? or thats what I read) but even so, it put down 223whp and low 160 tq.
I could only get one dyno from an archived set of Focus-Central and one pic of the car... I can't find a ton of info about the car or the setup. I do know they had a custom intake manifold with dual 65mm TBs
Old 02-22-2009, 07:05 PM   #4
mlbbaseball
Shot me 3 deer!!!
Fan#: 53541
Forum Activity 3%
I would think ur car is very similar, you really cannot run a CR higher than 10.5:1 w/ out racing fuel. i am at 10.7:1 but i already retard alot of timing. 11:5 or 12:1 will be straight race fuel. or at least 97-100 octane minimum.
Old 02-22-2009, 11:20 PM   #5
yellow2000S/R
Fan#: 58422
What I Drive: ZX2
With the duration of the cams I have the effective compression ratio is going to be lower than the static compression because the piston is already moving upward by the time the intake valve fully closes. Yes, more air will be in there because of higher efficiency because of improved port flow, but the actual compression from the swept area of the piston is what determines the effective/true compression. If I had shorter duration I'd have closer to the static compression but because I don't, the engine essentially acts as it is larger and over 100% VE can be achieved.
I'll probably do all the math sometime in the future to figure it all out.
Similar Threads
Long Term Plans....N/A Build svtguy88 SVT Performance (2002-2004) 14 01-26-2009 07:45 PM
Tom, you're about to build an engine for me... Darth Focus Focus-Power Tuning 11 10-03-2006 02:41 PM
Need help with a duratec build archie DURATEC Performance (2003-2007) 13 07-14-2006 04:40 PM
Gran Turismo 4 Car Listing Infra3sv Gaming Fanatics 50 05-19-2004 12:25 PM
