Old 02-25-2009, 01:30 PM   #11
lindleypoolman
Fan#: 62924
What I Drive: 2001 Blue Focus CL
FF Reputation: 1 lindleypoolman Good Standing Member
Ok, I have bought a ELM327 scan tool. Waiting for it to be delivered. Will post results when I have them.
lindleypoolman is offline
Old 02-27-2009, 01:06 AM   #12
lindleypoolman
Fan#: 62924
Hello again guys. Here's the live data readings I got from the scanner. I took the car through about four cycles of acceleration, the hesitation occurred each time.
02-27-2009 11:09:47.312, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:09:47.328, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:09:47.515, Calculated Load Value, 25.1, %, 25.1, %
02-27-2009 11:09:47.703, Engine Coolant Temperature, 208.4, deg F, 98, deg C
02-27-2009 11:09:47.906, Short Term Fuel Trim (Bank 1), 0.78125, %, 0.78125, %
02-27-2009 11:09:48.093, Long Term Fuel Trim (Bank 1), 3.90625, %, 3.90625, %
02-27-2009 11:09:48.296, Intake Manifold Absolute Pressure, 4.49275362318841, psi, 31, kPa
02-27-2009 11:09:48.484, Engine RPM, 793.5, rpm, 793.5, rpm
02-27-2009 11:09:48.640, Vehicle Speed Sensor, 0, mph, 0, km/h
02-27-2009 11:09:48.765, Ignition Timing Advance for #1 Cylinder, 10, deg, 10, deg
02-27-2009 11:09:48.890, Intake Air Temperature, 62.6, deg F, 17, deg C
02-27-2009 11:09:49.031, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:09:49.156, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.635, V, 0.635, V
02-27-2009 11:09:49.156, Short Term Fuel Trim (Bank 1, Sensor 1), 1.5625, %, 1.5625, %
02-27-2009 11:09:49.281, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.25, V, 0.25, V
02-27-2009 11:09:49.281, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:09:49.484, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:09:49.687, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:09:49.687, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:09:49.875, Calculated Load Value, 26.27, %, 26.27, %
02-27-2009 11:09:50.062, Engine Coolant Temperature, 208.4, deg F, 98, deg C
02-27-2009 11:09:50.187, Short Term Fuel Trim (Bank 1), -0.78125, %, -0.78125, %
02-27-2009 11:09:50.343, Long Term Fuel Trim (Bank 1), 3.90625, %, 3.90625, %
02-27-2009 11:09:50.531, Intake Manifold Absolute Pressure, 4.63768115942029, psi, 32, kPa
02-27-2009 11:09:50.718, Engine RPM, 810.75, rpm, 810.75, rpm
02-27-2009 11:09:50.906, Vehicle Speed Sensor, 0, mph, 0, km/h
02-27-2009 11:09:51.109, Ignition Timing Advance for #1 Cylinder, 12.5, deg, 12.5, deg
02-27-2009 11:09:51.296, Intake Air Temperature, 62.6, deg F, 17, deg C
02-27-2009 11:09:51.484, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:09:51.609, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.33, V, 0.33, V
02-27-2009 11:09:51.625, Short Term Fuel Trim (Bank 1, Sensor 1), 0, %, 0, %
02-27-2009 11:09:51.812, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.285, V, 0.285, V
02-27-2009 11:09:51.812, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:09:52.000, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:09:52.125, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:09:52.140, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:09:52.250, Calculated Load Value, 27.45, %, 27.45, %
02-27-2009 11:09:52.531, Engine Coolant Temperature, 208.4, deg F, 98, deg C
02-27-2009 11:09:52.718, Short Term Fuel Trim (Bank 1), 0.78125, %, 0.78125, %
02-27-2009 11:09:52.890, Long Term Fuel Trim (Bank 1), 3.90625, %, 3.90625, %
02-27-2009 11:09:53.046, Intake Manifold Absolute Pressure, 4.63768115942029, psi, 32, kPa
02-27-2009 11:09:53.250, Engine RPM, 810.75, rpm, 810.75, rpm
02-27-2009 11:09:53.437, Vehicle Speed Sensor, 0, mph, 0, km/h
02-27-2009 11:09:53.625, Ignition Timing Advance for #1 Cylinder, 11.5, deg, 11.5, deg
02-27-2009 11:09:53.828, Intake Air Temperature, 62.6, deg F, 17, deg C
02-27-2009 11:09:54.015, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:09:54.203, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.81, V, 0.81, V
02-27-2009 11:09:54.218, Short Term Fuel Trim (Bank 1, Sensor 1), -1.5625, %, -1.5625, %
02-27-2009 11:09:54.406, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.375, V, 0.375, V
02-27-2009 11:09:54.406, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:09:54.593, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:09:54.718, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:09:54.718, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:09:54.906, Calculated Load Value, 27.45, %, 27.45, %
02-27-2009 11:09:55.109, Engine Coolant Temperature, 208.4, deg F, 98, deg C
02-27-2009 11:09:55.296, Short Term Fuel Trim (Bank 1), 0, %, 0, %
02-27-2009 11:09:55.421, Long Term Fuel Trim (Bank 1), 3.90625, %, 3.90625, %
02-27-2009 11:09:55.562, Intake Manifold Absolute Pressure, 4.63768115942029, psi, 32, kPa
02-27-2009 11:09:55.765, Engine RPM, 814.5, rpm, 814.5, rpm
02-27-2009 11:09:55.953, Vehicle Speed Sensor, 0, mph, 0, km/h
02-27-2009 11:09:56.140, Ignition Timing Advance for #1 Cylinder, 11.5, deg, 11.5, deg
02-27-2009 11:09:56.328, Intake Air Temperature, 62.6, deg F, 17, deg C
02-27-2009 11:09:56.531, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:09:56.703, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.725, V, 0.725, V
02-27-2009 11:09:56.703, Short Term Fuel Trim (Bank 1, Sensor 1), 0.78125, %, 0.78125, %
02-27-2009 11:09:56.828, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.29, V, 0.29, V
02-27-2009 11:09:56.828, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:09:56.984, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:09:57.171, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:09:57.171, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:09:57.312, Calculated Load Value, 27.06, %, 27.06, %
02-27-2009 11:09:57.484, Engine Coolant Temperature, 208.4, deg F, 98, deg C
02-27-2009 11:09:57.625, Short Term Fuel Trim (Bank 1), -1.5625, %, -1.5625, %
02-27-2009 11:09:57.828, Long Term Fuel Trim (Bank 1), 3.90625, %, 3.90625, %
02-27-2009 11:09:58.015, Intake Manifold Absolute Pressure, 4.63768115942029, psi, 32, kPa
02-27-2009 11:09:58.203, Engine RPM, 796.75, rpm, 796.75, rpm
02-27-2009 11:09:58.406, Vehicle Speed Sensor, 0, mph, 0, km/h
02-27-2009 11:09:58.609, Ignition Timing Advance for #1 Cylinder, 11.5, deg, 11.5, deg
02-27-2009 11:09:58.796, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:09:58.968, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:09:59.125, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.16, V, 0.16, V
02-27-2009 11:09:59.125, Short Term Fuel Trim (Bank 1, Sensor 1), 0.78125, %, 0.78125, %
02-27-2009 11:09:59.312, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.215, V, 0.215, V
02-27-2009 11:09:59.312, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:09:59.500, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:09:59.687, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:09:59.703, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:09:59.890, Calculated Load Value, 26.27, %, 26.27, %
02-27-2009 11:10:00.078, Engine Coolant Temperature, 208.4, deg F, 98, deg C
02-27-2009 11:10:00.265, Short Term Fuel Trim (Bank 1), -0.78125, %, -0.78125, %
02-27-2009 11:10:00.468, Long Term Fuel Trim (Bank 1), 3.90625, %, 3.90625, %
02-27-2009 11:10:00.640, Intake Manifold Absolute Pressure, 4.78260869565217, psi, 33, kPa
02-27-2009 11:10:00.796, Engine RPM, 810.75, rpm, 810.75, rpm
02-27-2009 11:10:00.984, Vehicle Speed Sensor, 0, mph, 0, km/h
02-27-2009 11:10:01.187, Ignition Timing Advance for #1 Cylinder, 10, deg, 10, deg
02-27-2009 11:10:01.375, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:10:01.562, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:10:01.750, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.56, V, 0.56, V
02-27-2009 11:10:01.765, Short Term Fuel Trim (Bank 1, Sensor 1), -1.5625, %, -1.5625, %
02-27-2009 11:10:01.953, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.22, V, 0.22, V
02-27-2009 11:10:01.953, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:02.156, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:02.343, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:02.359, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:02.531, Calculated Load Value, 23.53, %, 23.53, %
02-27-2009 11:10:02.671, Engine Coolant Temperature, 208.4, deg F, 98, deg C
02-27-2009 11:10:02.859, Short Term Fuel Trim (Bank 1), 0.78125, %, 0.78125, %
02-27-2009 11:10:03.000, Long Term Fuel Trim (Bank 1), 3.90625, %, 3.90625, %
02-27-2009 11:10:03.187, Intake Manifold Absolute Pressure, 4.34782608695652, psi, 30, kPa
02-27-2009 11:10:03.328, Engine RPM, 817.25, rpm, 817.25, rpm
02-27-2009 11:10:03.515, Vehicle Speed Sensor, 0, mph, 0, km/h
02-27-2009 11:10:03.703, Ignition Timing Advance for #1 Cylinder, 6, deg, 6, deg
02-27-2009 11:10:03.921, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:10:04.109, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:10:04.296, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.845, V, 0.845, V
02-27-2009 11:10:04.312, Short Term Fuel Trim (Bank 1, Sensor 1), -1.5625, %, -1.5625, %
02-27-2009 11:10:04.500, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.26, V, 0.26, V
02-27-2009 11:10:04.500, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:04.687, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:04.890, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:04.890, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:05.078, Calculated Load Value, 57.65, %, 57.65, %
02-27-2009 11:10:05.281, Engine Coolant Temperature, 208.4, deg F, 98, deg C
02-27-2009 11:10:05.468, Short Term Fuel Trim (Bank 1), -3.125, %, -3.125, %
02-27-2009 11:10:05.671, Long Term Fuel Trim (Bank 1), 0.78125, %, 0.78125, %
02-27-2009 11:10:05.859, Intake Manifold Absolute Pressure, 7.53623188405797, psi, 52, kPa
02-27-2009 11:10:06.046, Engine RPM, 1477.5, rpm, 1477.5, rpm
02-27-2009 11:10:06.250, Vehicle Speed Sensor, 1.875, mph, 3, km/h
02-27-2009 11:10:06.437, Ignition Timing Advance for #1 Cylinder, 25.5, deg, 25.5, deg
02-27-2009 11:10:06.625, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:10:06.828, Absolute Throttle Position, 36.8627450980392, %, 36.8627450980392, %
02-27-2009 11:10:07.015, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.06, V, 0.06, V
02-27-2009 11:10:07.031, Short Term Fuel Trim (Bank 1, Sensor 1), 1.5625, %, 1.5625, %
02-27-2009 11:10:07.218, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.055, V, 0.055, V
02-27-2009 11:10:07.218, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:07.421, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:07.609, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:07.609, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:07.781, Calculated Load Value, 65.88, %, 65.88, %
02-27-2009 11:10:08.000, Engine Coolant Temperature, 208.4, deg F, 98, deg C
02-27-2009 11:10:08.187, Short Term Fuel Trim (Bank 1), 4.6875, %, 4.6875, %
02-27-2009 11:10:08.375, Long Term Fuel Trim (Bank 1), -2.34375, %, -2.34375, %
02-27-2009 11:10:08.515, Intake Manifold Absolute Pressure, 4.05797101449275, psi, 28, kPa
02-27-2009 11:10:08.734, Engine RPM, 1839, rpm, 1839, rpm
02-27-2009 11:10:08.921, Vehicle Speed Sensor, 7.5, mph, 12, km/h
02-27-2009 11:10:09.109, Ignition Timing Advance for #1 Cylinder, 12, deg, 12, deg
02-27-2009 11:10:09.312, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:10:09.484, Absolute Throttle Position, 34.1176470588235, %, 34.1176470588235, %
02-27-2009 11:10:09.640, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.705, V, 0.705, V
02-27-2009 11:10:09.640, Short Term Fuel Trim (Bank 1, Sensor 1), 3.90625, %, 3.90625, %
02-27-2009 11:10:09.828, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.23, V, 0.23, V
02-27-2009 11:10:09.843, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:10.031, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:10.218, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:10.218, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:10.406, Calculated Load Value, 65.1, %, 65.1, %
02-27-2009 11:10:10.625, Engine Coolant Temperature, 208.4, deg F, 98, deg C
02-27-2009 11:10:10.812, Short Term Fuel Trim (Bank 1), -0.78125, %, -0.78125, %
02-27-2009 11:10:11.000, Long Term Fuel Trim (Bank 1), -1.5625, %, -1.5625, %
02-27-2009 11:10:11.171, Intake Manifold Absolute Pressure, 8.11594202898551, psi, 56, kPa
02-27-2009 11:10:11.390, Engine RPM, 1325.5, rpm, 1325.5, rpm
02-27-2009 11:10:11.578, Vehicle Speed Sensor, 10.625, mph, 17, km/h
02-27-2009 11:10:11.781, Ignition Timing Advance for #1 Cylinder, 24.5, deg, 24.5, deg
02-27-2009 11:10:11.984, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:10:12.171, Absolute Throttle Position, 34.9019607843137, %, 34.9019607843137, %
02-27-2009 11:10:12.359, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.265, V, 0.265, V
02-27-2009 11:10:12.375, Short Term Fuel Trim (Bank 1, Sensor 1), 0.78125, %, 0.78125, %
02-27-2009 11:10:12.546, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.795, V, 0.795, V
02-27-2009 11:10:12.562, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:12.750, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:12.953, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:12.953, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:13.140, Calculated Load Value, 58.82, %, 58.82, %
02-27-2009 11:10:13.343, Engine Coolant Temperature, 208.4, deg F, 98, deg C
02-27-2009 11:10:13.531, Short Term Fuel Trim (Bank 1), -2.34375, %, -2.34375, %
02-27-2009 11:10:13.718, Long Term Fuel Trim (Bank 1), -1.5625, %, -1.5625, %
02-27-2009 11:10:13.906, Intake Manifold Absolute Pressure, 3.6231884057971, psi, 25, kPa
02-27-2009 11:10:14.062, Engine RPM, 1632.5, rpm, 1632.5, rpm
02-27-2009 11:10:14.250, Vehicle Speed Sensor, 14.375, mph, 23, km/h
02-27-2009 11:10:14.437, Ignition Timing Advance for #1 Cylinder, 25, deg, 25, deg
02-27-2009 11:10:14.656, Intake Air Temperature, 62.6, deg F, 17, deg C
02-27-2009 11:10:14.843, Absolute Throttle Position, 26.6666666666667, %, 26.6666666666667, %
02-27-2009 11:10:15.031, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.025, V, 0.025, V
02-27-2009 11:10:15.031, Short Term Fuel Trim (Bank 1, Sensor 1), 1.5625, %, 1.5625, %
02-27-2009 11:10:15.218, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.05, V, 0.05, V
02-27-2009 11:10:15.234, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:15.421, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:15.609, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:15.609, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:15.812, Calculated Load Value, 46.67, %, 46.67, %
02-27-2009 11:10:16.015, Engine Coolant Temperature, 208.4, deg F, 98, deg C
02-27-2009 11:10:16.203, Short Term Fuel Trim (Bank 1), 0, %, 0, %
02-27-2009 11:10:16.390, Long Term Fuel Trim (Bank 1), -0.78125, %, -0.78125, %
02-27-2009 11:10:16.578, Intake Manifold Absolute Pressure, 6.52173913043478, psi, 45, kPa
02-27-2009 11:10:16.781, Engine RPM, 1138.75, rpm, 1138.75, rpm
02-27-2009 11:10:16.984, Vehicle Speed Sensor, 15, mph, 24, km/h
02-27-2009 11:10:17.171, Ignition Timing Advance for #1 Cylinder, 7.5, deg, 7.5, deg
02-27-2009 11:10:17.359, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:10:17.546, Absolute Throttle Position, 87.0588235294118, %, 87.0588235294118, %
02-27-2009 11:10:17.687, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.94, V, 0.94, V
02-27-2009 11:10:17.687, Short Term Fuel Trim (Bank 1, Sensor 1), 15.625, %, 15.625, %
02-27-2009 11:10:17.875, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.905, V, 0.905, V
02-27-2009 11:10:17.890, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:18.093, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:18.281, Fuel System 1 Status, OL-Drive: Open loop due to driving conditions. (e.g., power enrichment, deceleration enleanment), OL/CL, OL-Drive, OL/CL
02-27-2009 11:10:18.281, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:18.468, Calculated Load Value, 100, %, 100, %
02-27-2009 11:10:18.687, Engine Coolant Temperature, 210.2, deg F, 99, deg C
02-27-2009 11:10:18.859, Short Term Fuel Trim (Bank 1), 13.28125, %, 13.28125, %
02-27-2009 11:10:19.046, Long Term Fuel Trim (Bank 1), 2.34375, %, 2.34375, %
02-27-2009 11:10:19.250, Intake Manifold Absolute Pressure, 4.34782608695652, psi, 30, kPa
02-27-2009 11:10:19.421, Engine RPM, 1350, rpm, 1350, rpm
02-27-2009 11:10:19.578, Vehicle Speed Sensor, 17.5, mph, 28, km/h
02-27-2009 11:10:19.765, Ignition Timing Advance for #1 Cylinder, 7.5, deg, 7.5, deg
02-27-2009 11:10:19.953, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:10:20.140, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:10:20.281, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.055, V, 0.055, V
02-27-2009 11:10:20.281, Short Term Fuel Trim (Bank 1, Sensor 1), 10.9375, %, 10.9375, %
02-27-2009 11:10:20.468, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.88, V, 0.88, V
02-27-2009 11:10:20.468, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:20.640, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:20.812, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:20.812, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:20.984, Calculated Load Value, 20.39, %, 20.39, %
02-27-2009 11:10:21.187, Engine Coolant Temperature, 210.2, deg F, 99, deg C
02-27-2009 11:10:21.375, Short Term Fuel Trim (Bank 1), 12.5, %, 12.5, %
02-27-2009 11:10:21.578, Long Term Fuel Trim (Bank 1), -7.8125, %, -7.8125, %
02-27-2009 11:10:21.781, Intake Manifold Absolute Pressure, 3.6231884057971, psi, 25, kPa
02-27-2009 11:10:21.968, Engine RPM, 1146.75, rpm, 1146.75, rpm
02-27-2009 11:10:22.171, Vehicle Speed Sensor, 14.375, mph, 23, km/h
02-27-2009 11:10:22.359, Ignition Timing Advance for #1 Cylinder, 25, deg, 25, deg
02-27-2009 11:10:22.546, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:10:22.750, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:10:22.937, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.795, V, 0.795, V
02-27-2009 11:10:22.937, Short Term Fuel Trim (Bank 1, Sensor 1), 10.15625, %, 10.15625, %
02-27-2009 11:10:23.140, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.175, V, 0.175, V
02-27-2009 11:10:23.140, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:23.328, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:23.515, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:23.515, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:23.718, Calculated Load Value, 18.04, %, 18.04, %
02-27-2009 11:10:23.890, Engine Coolant Temperature, 210.2, deg F, 99, deg C
02-27-2009 11:10:24.109, Short Term Fuel Trim (Bank 1), 8.59375, %, 8.59375, %
02-27-2009 11:10:24.296, Long Term Fuel Trim (Bank 1), -0.78125, %, -0.78125, %
02-27-2009 11:10:24.484, Intake Manifold Absolute Pressure, 14.7826086956522, psi, 102, kPa
02-27-2009 11:10:24.671, Engine RPM, 1014.75, rpm, 1014.75, rpm
02-27-2009 11:10:24.890, Vehicle Speed Sensor, 13.125, mph, 21, km/h
02-27-2009 11:10:25.078, Ignition Timing Advance for #1 Cylinder, -5, deg, -5, deg
02-27-2009 11:10:25.265, Intake Air Temperature, 66.2, deg F, 19, deg C
02-27-2009 11:10:25.468, Absolute Throttle Position, 82.3529411764706, %, 82.3529411764706, %
02-27-2009 11:10:25.656, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.91, V, 0.91, V
02-27-2009 11:10:25.656, Short Term Fuel Trim (Bank 1, Sensor 1), 5.46875, %, 5.46875, %
02-27-2009 11:10:25.859, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.9, V, 0.9, V
02-27-2009 11:10:25.859, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:26.031, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:26.250, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:26.250, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:26.437, Calculated Load Value, 20.39, %, 20.39, %
02-27-2009 11:10:26.640, Engine Coolant Temperature, 212, deg F, 100, deg C
02-27-2009 11:10:26.828, Short Term Fuel Trim (Bank 1), 3.125, %, 3.125, %
02-27-2009 11:10:27.015, Long Term Fuel Trim (Bank 1), -5.46875, %, -5.46875, %
02-27-2009 11:10:27.203, Intake Manifold Absolute Pressure, 3.91304347826087, psi, 27, kPa
02-27-2009 11:10:27.390, Engine RPM, 1222, rpm, 1222, rpm
02-27-2009 11:10:27.593, Vehicle Speed Sensor, 15, mph, 24, km/h
02-27-2009 11:10:27.796, Ignition Timing Advance for #1 Cylinder, 10, deg, 10, deg
02-27-2009 11:10:27.984, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:10:28.187, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:10:28.375, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.055, V, 0.055, V
02-27-2009 11:10:28.390, Short Term Fuel Trim (Bank 1, Sensor 1), 7.8125, %, 7.8125, %
02-27-2009 11:10:28.562, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.36, V, 0.36, V
02-27-2009 11:10:28.562, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:28.765, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:28.968, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:28.968, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:29.156, Calculated Load Value, 21.96, %, 21.96, %
02-27-2009 11:10:29.343, Engine Coolant Temperature, 212, deg F, 100, deg C
02-27-2009 11:10:29.546, Short Term Fuel Trim (Bank 1), 4.6875, %, 4.6875, %
02-27-2009 11:10:29.734, Long Term Fuel Trim (Bank 1), -9.375, %, -9.375, %
02-27-2009 11:10:29.921, Intake Manifold Absolute Pressure, 4.05797101449275, psi, 28, kPa
02-27-2009 11:10:30.109, Engine RPM, 855.25, rpm, 855.25, rpm
02-27-2009 11:10:30.312, Vehicle Speed Sensor, 10.625, mph, 17, km/h
02-27-2009 11:10:30.500, Ignition Timing Advance for #1 Cylinder, 25, deg, 25, deg
02-27-2009 11:10:30.703, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:10:30.906, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:10:31.093, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.81, V, 0.81, V
02-27-2009 11:10:31.093, Short Term Fuel Trim (Bank 1, Sensor 1), 3.125, %, 3.125, %
02-27-2009 11:10:31.281, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.56, V, 0.56, V
02-27-2009 11:10:31.296, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:31.468, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:31.671, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:31.671, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:31.859, Calculated Load Value, 31.37, %, 31.37, %
02-27-2009 11:10:32.046, Engine Coolant Temperature, 212, deg F, 100, deg C
02-27-2009 11:10:32.250, Short Term Fuel Trim (Bank 1), 1.5625, %, 1.5625, %
02-27-2009 11:10:32.437, Long Term Fuel Trim (Bank 1), -7.8125, %, -7.8125, %
02-27-2009 11:10:32.640, Intake Manifold Absolute Pressure, 5.36231884057971, psi, 37, kPa
02-27-2009 11:10:32.828, Engine RPM, 705.25, rpm, 705.25, rpm
02-27-2009 11:10:33.031, Vehicle Speed Sensor, 8.75, mph, 14, km/h
02-27-2009 11:10:33.218, Ignition Timing Advance for #1 Cylinder, -11, deg, -11, deg
02-27-2009 11:10:33.406, Intake Air Temperature, 66.2, deg F, 19, deg C
02-27-2009 11:10:33.609, Absolute Throttle Position, 88.2352941176471, %, 88.2352941176471, %
02-27-2009 11:10:33.796, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.975, V, 0.975, V
02-27-2009 11:10:33.796, Short Term Fuel Trim (Bank 1, Sensor 1), 14.0625, %, 14.0625, %
02-27-2009 11:10:33.984, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.96, V, 0.96, V
02-27-2009 11:10:33.984, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:34.187, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:34.375, Fuel System 1 Status, OL-Drive: Open loop due to driving conditions. (e.g., power enrichment, deceleration enleanment), OL/CL, OL-Drive, OL/CL
02-27-2009 11:10:34.375, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:34.578, Calculated Load Value, 99.61, %, 99.61, %
02-27-2009 11:10:34.765, Engine Coolant Temperature, 212, deg F, 100, deg C
02-27-2009 11:10:34.937, Short Term Fuel Trim (Bank 1), 14.0625, %, 14.0625, %
02-27-2009 11:10:35.093, Long Term Fuel Trim (Bank 1), -2.34375, %, -2.34375, %
02-27-2009 11:10:35.281, Intake Manifold Absolute Pressure, 15.0724637681159, psi, 104, kPa
02-27-2009 11:10:35.468, Engine RPM, 1069.25, rpm, 1069.25, rpm
02-27-2009 11:10:35.671, Vehicle Speed Sensor, 14.375, mph, 23, km/h
02-27-2009 11:10:35.859, Ignition Timing Advance for #1 Cylinder, -4, deg, -4, deg
02-27-2009 11:10:36.046, Intake Air Temperature, 66.2, deg F, 19, deg C
02-27-2009 11:10:36.265, Absolute Throttle Position, 88.6274509803922, %, 88.6274509803922, %
02-27-2009 11:10:36.453, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.93, V, 0.93, V
02-27-2009 11:10:36.453, Short Term Fuel Trim (Bank 1, Sensor 1), 14.84375, %, 14.84375, %
02-27-2009 11:10:36.640, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.895, V, 0.895, V
02-27-2009 11:10:36.640, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:36.828, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:37.046, Fuel System 1 Status, OL-Drive: Open loop due to driving conditions. (e.g., power enrichment, deceleration enleanment), OL/CL, OL-Drive, OL/CL
02-27-2009 11:10:37.046, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:37.234, Calculated Load Value, 100, %, 100, %
02-27-2009 11:10:37.421, Engine Coolant Temperature, 215.6, deg F, 102, deg C
02-27-2009 11:10:37.640, Short Term Fuel Trim (Bank 1), 15.625, %, 15.625, %
02-27-2009 11:10:37.828, Long Term Fuel Trim (Bank 1), -2.34375, %, -2.34375, %
02-27-2009 11:10:38.015, Intake Manifold Absolute Pressure, 14.9275362318841, psi, 103, kPa
02-27-2009 11:10:38.203, Engine RPM, 1601.5, rpm, 1601.5, rpm
02-27-2009 11:10:38.406, Vehicle Speed Sensor, 20.625, mph, 33, km/h
02-27-2009 11:10:38.593, Ignition Timing Advance for #1 Cylinder, 19, deg, 19, deg
02-27-2009 11:10:38.796, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:10:38.984, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:10:39.187, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.915, V, 0.915, V
02-27-2009 11:10:39.187, Short Term Fuel Trim (Bank 1, Sensor 1), 7.8125, %, 7.8125, %
02-27-2009 11:10:39.375, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.94, V, 0.94, V
02-27-2009 11:10:39.375, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:39.562, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:39.765, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:39.765, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:39.953, Calculated Load Value, 20.78, %, 20.78, %
02-27-2009 11:10:40.140, Engine Coolant Temperature, 215.6, deg F, 102, deg C
02-27-2009 11:10:40.359, Short Term Fuel Trim (Bank 1), 3.125, %, 3.125, %
02-27-2009 11:10:40.546, Long Term Fuel Trim (Bank 1), -6.25, %, -6.25, %
02-27-2009 11:10:40.734, Intake Manifold Absolute Pressure, 3.91304347826087, psi, 27, kPa
02-27-2009 11:10:40.921, Engine RPM, 1163.25, rpm, 1163.25, rpm
02-27-2009 11:10:41.109, Vehicle Speed Sensor, 15, mph, 24, km/h
02-27-2009 11:10:41.250, Ignition Timing Advance for #1 Cylinder, 20, deg, 20, deg
02-27-2009 11:10:41.421, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:10:41.562, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:10:41.750, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.64, V, 0.64, V
02-27-2009 11:10:41.750, Short Term Fuel Trim (Bank 1, Sensor 1), 3.90625, %, 3.90625, %
02-27-2009 11:10:41.906, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.845, V, 0.845, V
02-27-2009 11:10:41.906, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:42.078, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:42.203, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:42.218, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:42.421, Calculated Load Value, 25.1, %, 25.1, %
02-27-2009 11:10:42.593, Engine Coolant Temperature, 215.6, deg F, 102, deg C
02-27-2009 11:10:42.796, Short Term Fuel Trim (Bank 1), 2.34375, %, 2.34375, %
02-27-2009 11:10:42.984, Long Term Fuel Trim (Bank 1), -9.375, %, -9.375, %
02-27-2009 11:10:43.187, Intake Manifold Absolute Pressure, 5.07246376811594, psi, 35
Old 02-27-2009, 01:07 AM   #13
lindleypoolman
Fan#: 62924
02-27-2009 11:10:43.375, Engine RPM, 922.75, rpm, 922.75, rpm
02-27-2009 11:10:43.562, Vehicle Speed Sensor, 11.875, mph, 19, km/h
02-27-2009 11:10:43.765, Ignition Timing Advance for #1 Cylinder, 23.5, deg, 23.5, deg
02-27-2009 11:10:43.953, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:10:44.156, Absolute Throttle Position, 58.4313725490196, %, 58.4313725490196, %
02-27-2009 11:10:44.359, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.705, V, 0.705, V
02-27-2009 11:10:44.359, Short Term Fuel Trim (Bank 1, Sensor 1), 14.84375, %, 14.84375, %
02-27-2009 11:10:44.546, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.85, V, 0.85, V
02-27-2009 11:10:44.546, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:44.734, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:44.921, Fuel System 1 Status, OL-Drive: Open loop due to driving conditions. (e.g., power enrichment, deceleration enleanment), OL/CL, OL-Drive, OL/CL
02-27-2009 11:10:44.937, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:45.125, Calculated Load Value, 100, %, 100, %
02-27-2009 11:10:45.296, Engine Coolant Temperature, 215.6, deg F, 102, deg C
02-27-2009 11:10:45.437, Short Term Fuel Trim (Bank 1), 14.84375, %, 14.84375, %
02-27-2009 11:10:45.640, Long Term Fuel Trim (Bank 1), -2.34375, %, -2.34375, %
02-27-2009 11:10:45.828, Intake Manifold Absolute Pressure, 15.0724637681159, psi, 104, kPa
02-27-2009 11:10:46.031, Engine RPM, 1226.75, rpm, 1226.75, rpm
02-27-2009 11:10:46.218, Vehicle Speed Sensor, 15.625, mph, 25, km/h
02-27-2009 11:10:46.421, Ignition Timing Advance for #1 Cylinder, 1.5, deg, 1.5, deg
02-27-2009 11:10:46.609, Intake Air Temperature, 66.2, deg F, 19, deg C
02-27-2009 11:10:46.796, Absolute Throttle Position, 87.843137254902, %, 87.843137254902, %
02-27-2009 11:10:46.984, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.925, V, 0.925, V
02-27-2009 11:10:47.000, Short Term Fuel Trim (Bank 1, Sensor 1), 15.625, %, 15.625, %
02-27-2009 11:10:47.203, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.935, V, 0.935, V
02-27-2009 11:10:47.203, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:47.390, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:47.578, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:47.593, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:47.796, Calculated Load Value, 19.61, %, 19.61, %
02-27-2009 11:10:47.968, Engine Coolant Temperature, 217.4, deg F, 103, deg C
02-27-2009 11:10:48.171, Short Term Fuel Trim (Bank 1), 7.03125, %, 7.03125, %
02-27-2009 11:10:48.359, Long Term Fuel Trim (Bank 1), -3.125, %, -3.125, %
02-27-2009 11:10:48.562, Intake Manifold Absolute Pressure, 3.76811594202899, psi, 26, kPa
02-27-2009 11:10:48.734, Engine RPM, 1401, rpm, 1401, rpm
02-27-2009 11:10:48.875, Vehicle Speed Sensor, 18.125, mph, 29, km/h
02-27-2009 11:10:49.093, Ignition Timing Advance for #1 Cylinder, 7.5, deg, 7.5, deg
02-27-2009 11:10:49.281, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:10:49.468, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:10:49.656, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.185, V, 0.185, V
02-27-2009 11:10:49.671, Short Term Fuel Trim (Bank 1, Sensor 1), 5.46875, %, 5.46875, %
02-27-2009 11:10:49.859, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.895, V, 0.895, V
02-27-2009 11:10:49.859, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:50.046, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:50.234, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:50.234, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:50.453, Calculated Load Value, 20.39, %, 20.39, %
02-27-2009 11:10:50.640, Engine Coolant Temperature, 217.4, deg F, 103, deg C
02-27-2009 11:10:50.828, Short Term Fuel Trim (Bank 1), 7.03125, %, 7.03125, %
02-27-2009 11:10:51.000, Long Term Fuel Trim (Bank 1), -7.8125, %, -7.8125, %
02-27-2009 11:10:51.156, Intake Manifold Absolute Pressure, 3.91304347826087, psi, 27, kPa
02-27-2009 11:10:51.359, Engine RPM, 1100.75, rpm, 1100.75, rpm
02-27-2009 11:10:51.546, Vehicle Speed Sensor, 13.125, mph, 21, km/h
02-27-2009 11:10:51.734, Ignition Timing Advance for #1 Cylinder, 25, deg, 25, deg
02-27-2009 11:10:51.937, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:10:52.125, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:10:52.312, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.885, V, 0.885, V
02-27-2009 11:10:52.328, Short Term Fuel Trim (Bank 1, Sensor 1), 3.90625, %, 3.90625, %
02-27-2009 11:10:52.515, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.84, V, 0.84, V
02-27-2009 11:10:52.515, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:52.703, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:52.890, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:10:52.890, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:53.078, Calculated Load Value, 19.22, %, 19.22, %
02-27-2009 11:10:53.296, Engine Coolant Temperature, 217.4, deg F, 103, deg C
02-27-2009 11:10:53.484, Short Term Fuel Trim (Bank 1), 2.34375, %, 2.34375, %
02-27-2009 11:10:53.671, Long Term Fuel Trim (Bank 1), -9.375, %, -9.375, %
02-27-2009 11:10:53.875, Intake Manifold Absolute Pressure, 4.20289855072464, psi, 29, kPa
02-27-2009 11:10:54.062, Engine RPM, 862.75, rpm, 862.75, rpm
02-27-2009 11:10:54.250, Vehicle Speed Sensor, 10.625, mph, 17, km/h
02-27-2009 11:10:54.453, Ignition Timing Advance for #1 Cylinder, -14, deg, -14, deg
02-27-2009 11:10:54.656, Intake Air Temperature, 66.2, deg F, 19, deg C
02-27-2009 11:10:54.828, Absolute Throttle Position, 88.2352941176471, %, 88.2352941176471, %
02-27-2009 11:10:55.031, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.965, V, 0.965, V
02-27-2009 11:10:55.046, Short Term Fuel Trim (Bank 1, Sensor 1), 14.0625, %, 14.0625, %
02-27-2009 11:10:55.234, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.95, V, 0.95, V
02-27-2009 11:10:55.234, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:55.421, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:55.609, Fuel System 1 Status, OL-Drive: Open loop due to driving conditions. (e.g., power enrichment, deceleration enleanment), OL/CL, OL-Drive, OL/CL
02-27-2009 11:10:55.609, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:55.796, Calculated Load Value, 100, %, 100, %
02-27-2009 11:10:56.000, Engine Coolant Temperature, 217.4, deg F, 103, deg C
02-27-2009 11:10:56.203, Short Term Fuel Trim (Bank 1), 14.84375, %, 14.84375, %
02-27-2009 11:10:56.390, Long Term Fuel Trim (Bank 1), -2.34375, %, -2.34375, %
02-27-2009 11:10:56.578, Intake Manifold Absolute Pressure, 15.0724637681159, psi, 104, kPa
02-27-2009 11:10:56.765, Engine RPM, 1194.25, rpm, 1194.25, rpm
02-27-2009 11:10:56.968, Vehicle Speed Sensor, 15, mph, 24, km/h
02-27-2009 11:10:57.156, Ignition Timing Advance for #1 Cylinder, 0.5, deg, 0.5, deg
02-27-2009 11:10:57.359, Intake Air Temperature, 66.2, deg F, 19, deg C
02-27-2009 11:10:57.546, Absolute Throttle Position, 88.6274509803922, %, 88.6274509803922, %
02-27-2009 11:10:57.734, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.93, V, 0.93, V
02-27-2009 11:10:57.750, Short Term Fuel Trim (Bank 1, Sensor 1), 15.625, %, 15.625, %
02-27-2009 11:10:57.953, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.925, V, 0.925, V
02-27-2009 11:10:57.953, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:10:58.140, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:10:58.328, Fuel System 1 Status, OL-Drive: Open loop due to driving conditions. (e.g., power enrichment, deceleration enleanment), OL/CL, OL-Drive, OL/CL
02-27-2009 11:10:58.328, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:10:58.531, Calculated Load Value, 100, %, 100, %
02-27-2009 11:10:58.734, Engine Coolant Temperature, 217.4, deg F, 103, deg C
02-27-2009 11:10:58.921, Short Term Fuel Trim (Bank 1), 17.1875, %, 17.1875, %
02-27-2009 11:10:59.109, Long Term Fuel Trim (Bank 1), -2.34375, %, -2.34375, %
02-27-2009 11:10:59.328, Intake Manifold Absolute Pressure, 14.9275362318841, psi, 103, kPa
02-27-2009 11:10:59.531, Engine RPM, 1738.75, rpm, 1738.75, rpm
02-27-2009 11:10:59.718, Vehicle Speed Sensor, 22.5, mph, 36, km/h
02-27-2009 11:10:59.921, Ignition Timing Advance for #1 Cylinder, 1, deg, 1, deg
02-27-2009 11:11:00.125, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:11:00.312, Absolute Throttle Position, 88.6274509803922, %, 88.6274509803922, %
02-27-2009 11:11:00.500, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.93, V, 0.93, V
02-27-2009 11:11:00.515, Short Term Fuel Trim (Bank 1, Sensor 1), 15.625, %, 15.625, %
02-27-2009 11:11:00.703, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.945, V, 0.945, V
02-27-2009 11:11:00.703, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:00.906, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:01.093, Fuel System 1 Status, OL-Drive: Open loop due to driving conditions. (e.g., power enrichment, deceleration enleanment), OL/CL, OL-Drive, OL/CL
02-27-2009 11:11:01.109, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:01.296, Calculated Load Value, 100, %, 100, %
02-27-2009 11:11:01.484, Engine Coolant Temperature, 217.4, deg F, 103, deg C
02-27-2009 11:11:01.687, Short Term Fuel Trim (Bank 1), 14.84375, %, 14.84375, %
02-27-2009 11:11:01.875, Long Term Fuel Trim (Bank 1), -3.90625, %, -3.90625, %
02-27-2009 11:11:02.078, Intake Manifold Absolute Pressure, 14.6376811594203, psi, 101, kPa
02-27-2009 11:11:02.250, Engine RPM, 2257.5, rpm, 2257.5, rpm
02-27-2009 11:11:02.390, Vehicle Speed Sensor, 29.375, mph, 47, km/h
02-27-2009 11:11:02.609, Ignition Timing Advance for #1 Cylinder, 15, deg, 15, deg
02-27-2009 11:11:02.796, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:11:02.984, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:11:03.171, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.95, V, 0.95, V
02-27-2009 11:11:03.187, Short Term Fuel Trim (Bank 1, Sensor 1), 6.25, %, 6.25, %
02-27-2009 11:11:03.375, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.975, V, 0.975, V
02-27-2009 11:11:03.375, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:03.578, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:03.765, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:11:03.765, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:03.953, Calculated Load Value, 16.47, %, 16.47, %
02-27-2009 11:11:04.156, Engine Coolant Temperature, 219.2, deg F, 104, deg C
02-27-2009 11:11:04.359, Short Term Fuel Trim (Bank 1), 1.5625, %, 1.5625, %
02-27-2009 11:11:04.546, Long Term Fuel Trim (Bank 1), -2.34375, %, -2.34375, %
02-27-2009 11:11:04.750, Intake Manifold Absolute Pressure, 3.6231884057971, psi, 25, kPa
02-27-2009 11:11:04.937, Engine RPM, 1428.75, rpm, 1428.75, rpm
02-27-2009 11:11:05.125, Vehicle Speed Sensor, 27.5, mph, 44, km/h
02-27-2009 11:11:05.312, Ignition Timing Advance for #1 Cylinder, 8.5, deg, 8.5, deg
02-27-2009 11:11:05.531, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:11:05.718, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:11:05.890, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.155, V, 0.155, V
02-27-2009 11:11:05.906, Short Term Fuel Trim (Bank 1, Sensor 1), 3.125, %, 3.125, %
02-27-2009 11:11:06.109, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.875, V, 0.875, V
02-27-2009 11:11:06.109, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:06.312, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:06.500, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:11:06.515, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:06.687, Calculated Load Value, 16.86, %, 16.86, %
02-27-2009 11:11:06.890, Engine Coolant Temperature, 219.2, deg F, 104, deg C
02-27-2009 11:11:07.078, Short Term Fuel Trim (Bank 1), -0.78125, %, -0.78125, %
02-27-2009 11:11:07.281, Long Term Fuel Trim (Bank 1), -9.375, %, -9.375, %
02-27-2009 11:11:07.468, Intake Manifold Absolute Pressure, 3.91304347826087, psi, 27, kPa
02-27-2009 11:11:07.656, Engine RPM, 910.25, rpm, 910.25, rpm
02-27-2009 11:11:07.859, Vehicle Speed Sensor, 23.125, mph, 37, km/h
02-27-2009 11:11:08.062, Ignition Timing Advance for #1 Cylinder, 25, deg, 25, deg
02-27-2009 11:11:08.250, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:11:08.453, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:11:08.625, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.855, V, 0.855, V
02-27-2009 11:11:08.640, Short Term Fuel Trim (Bank 1, Sensor 1), -2.34375, %, -2.34375, %
02-27-2009 11:11:08.843, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.86, V, 0.86, V
02-27-2009 11:11:08.843, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:09.015, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:09.140, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:11:09.140, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:09.343, Calculated Load Value, 18.43, %, 18.43, %
02-27-2009 11:11:09.546, Engine Coolant Temperature, 221, deg F, 105, deg C
02-27-2009 11:11:09.734, Short Term Fuel Trim (Bank 1), -3.90625, %, -3.90625, %
02-27-2009 11:11:09.875, Long Term Fuel Trim (Bank 1), -9.375, %, -9.375, %
02-27-2009 11:11:10.078, Intake Manifold Absolute Pressure, 4.20289855072464, psi, 29, kPa
02-27-2009 11:11:10.265, Engine RPM, 883.25, rpm, 883.25, rpm
02-27-2009 11:11:10.468, Vehicle Speed Sensor, 15.625, mph, 25, km/h
02-27-2009 11:11:10.656, Ignition Timing Advance for #1 Cylinder, 25, deg, 25, deg
02-27-2009 11:11:10.859, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:11:11.046, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:11:11.250, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.33, V, 0.33, V
02-27-2009 11:11:11.265, Short Term Fuel Trim (Bank 1, Sensor 1), -4.6875, %, -4.6875, %
02-27-2009 11:11:11.437, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.85, V, 0.85, V
02-27-2009 11:11:11.437, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:11.578, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:11.765, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:11:11.765, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:11.906, Calculated Load Value, 18.04, %, 18.04, %
Old 02-27-2009, 01:09 AM   #14
lindleypoolman
Fan#: 62924
02-27-2009 11:11:12.125, Engine Coolant Temperature, 221, deg F, 105, deg C
02-27-2009 11:11:12.312, Short Term Fuel Trim (Bank 1), -1.5625, %, -1.5625, %
02-27-2009 11:11:12.515, Long Term Fuel Trim (Bank 1), -9.375, %, -9.375, %
02-27-2009 11:11:12.703, Intake Manifold Absolute Pressure, 3.91304347826087, psi, 27, kPa
02-27-2009 11:11:12.906, Engine RPM, 889.5, rpm, 889.5, rpm
02-27-2009 11:11:13.093, Vehicle Speed Sensor, 15, mph, 24, km/h
02-27-2009 11:11:13.296, Ignition Timing Advance for #1 Cylinder, 0, deg, 0, deg
02-27-2009 11:11:13.484, Intake Air Temperature, 66.2, deg F, 19, deg C
02-27-2009 11:11:13.687, Absolute Throttle Position, 87.4509803921569, %, 87.4509803921569, %
02-27-2009 11:11:13.875, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.95, V, 0.95, V
02-27-2009 11:11:13.890, Short Term Fuel Trim (Bank 1, Sensor 1), 14.0625, %, 14.0625, %
02-27-2009 11:11:14.062, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.965, V, 0.965, V
02-27-2009 11:11:14.078, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:14.265, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:14.453, Fuel System 1 Status, OL-Drive: Open loop due to driving conditions. (e.g., power enrichment, deceleration enleanment), OL/CL, OL-Drive, OL/CL
02-27-2009 11:11:14.453, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:14.640, Calculated Load Value, 100, %, 100, %
02-27-2009 11:11:14.859, Engine Coolant Temperature, 221, deg F, 105, deg C
02-27-2009 11:11:15.046, Short Term Fuel Trim (Bank 1), 14.84375, %, 14.84375, %
02-27-2009 11:11:15.234, Long Term Fuel Trim (Bank 1), -2.34375, %, -2.34375, %
02-27-2009 11:11:15.421, Intake Manifold Absolute Pressure, 14.7826086956522, psi, 102, kPa
02-27-2009 11:11:15.625, Engine RPM, 1032.75, rpm, 1032.75, rpm
02-27-2009 11:11:15.812, Vehicle Speed Sensor, 18.125, mph, 29, km/h
02-27-2009 11:11:16.000, Ignition Timing Advance for #1 Cylinder, -2.5, deg, -2.5, deg
02-27-2009 11:11:16.218, Intake Air Temperature, 66.2, deg F, 19, deg C
02-27-2009 11:11:16.406, Absolute Throttle Position, 88.2352941176471, %, 88.2352941176471, %
02-27-2009 11:11:16.593, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.92, V, 0.92, V
02-27-2009 11:11:16.609, Short Term Fuel Trim (Bank 1, Sensor 1), 14.84375, %, 14.84375, %
02-27-2009 11:11:16.781, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.935, V, 0.935, V
02-27-2009 11:11:16.796, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:16.984, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:17.171, Fuel System 1 Status, OL-Drive: Open loop due to driving conditions. (e.g., power enrichment, deceleration enleanment), OL/CL, OL-Drive, OL/CL
02-27-2009 11:11:17.171, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:17.375, Calculated Load Value, 100, %, 100, %
02-27-2009 11:11:17.578, Engine Coolant Temperature, 221, deg F, 105, deg C
02-27-2009 11:11:17.765, Short Term Fuel Trim (Bank 1), 15.625, %, 15.625, %
02-27-2009 11:11:17.937, Long Term Fuel Trim (Bank 1), -2.34375, %, -2.34375, %
02-27-2009 11:11:18.140, Intake Manifold Absolute Pressure, 14.7826086956522, psi, 102, kPa
02-27-2009 11:11:18.343, Engine RPM, 1288, rpm, 1288, rpm
02-27-2009 11:11:18.531, Vehicle Speed Sensor, 23.125, mph, 37, km/h
02-27-2009 11:11:18.734, Ignition Timing Advance for #1 Cylinder, 0, deg, 0, deg
02-27-2009 11:11:18.937, Intake Air Temperature, 66.2, deg F, 19, deg C
02-27-2009 11:11:19.125, Absolute Throttle Position, 21.5686274509804, %, 21.5686274509804, %
02-27-2009 11:11:19.312, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.945, V, 0.945, V
02-27-2009 11:11:19.312, Short Term Fuel Trim (Bank 1, Sensor 1), 12.5, %, 12.5, %
02-27-2009 11:11:19.515, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.96, V, 0.96, V
02-27-2009 11:11:19.515, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:19.718, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:19.906, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:11:19.906, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:20.093, Calculated Load Value, 18.82, %, 18.82, %
02-27-2009 11:11:20.296, Engine Coolant Temperature, 221, deg F, 105, deg C
02-27-2009 11:11:20.484, Short Term Fuel Trim (Bank 1), 5.46875, %, 5.46875, %
02-27-2009 11:11:20.687, Long Term Fuel Trim (Bank 1), -7.03125, %, -7.03125, %
02-27-2009 11:11:20.890, Intake Manifold Absolute Pressure, 3.76811594202899, psi, 26, kPa
02-27-2009 11:11:21.078, Engine RPM, 1102.25, rpm, 1102.25, rpm
02-27-2009 11:11:21.265, Vehicle Speed Sensor, 18.75, mph, 30, km/h
02-27-2009 11:11:21.453, Ignition Timing Advance for #1 Cylinder, 25, deg, 25, deg
02-27-2009 11:11:21.656, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:11:21.859, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:11:22.031, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.89, V, 0.89, V
02-27-2009 11:11:22.046, Short Term Fuel Trim (Bank 1, Sensor 1), 1.5625, %, 1.5625, %
02-27-2009 11:11:22.250, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.905, V, 0.905, V
02-27-2009 11:11:22.250, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:22.421, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:22.546, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:11:22.546, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:22.734, Calculated Load Value, 20.78, %, 20.78, %
02-27-2009 11:11:22.937, Engine Coolant Temperature, 221, deg F, 105, deg C
02-27-2009 11:11:23.062, Short Term Fuel Trim (Bank 1), 0, %, 0, %
02-27-2009 11:11:23.203, Long Term Fuel Trim (Bank 1), -9.375, %, -9.375, %
02-27-2009 11:11:23.390, Intake Manifold Absolute Pressure, 4.34782608695652, psi, 30, kPa
02-27-2009 11:11:23.593, Engine RPM, 785.5, rpm, 785.5, rpm
02-27-2009 11:11:23.781, Vehicle Speed Sensor, 13.125, mph, 21, km/h
02-27-2009 11:11:23.968, Ignition Timing Advance for #1 Cylinder, 25, deg, 25, deg
02-27-2009 11:11:24.156, Intake Air Temperature, 66.2, deg F, 19, deg C
02-27-2009 11:11:24.359, Absolute Throttle Position, 70.9803921568627, %, 70.9803921568627, %
02-27-2009 11:11:24.546, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.89, V, 0.89, V
02-27-2009 11:11:24.546, Short Term Fuel Trim (Bank 1, Sensor 1), 14.0625, %, 14.0625, %
02-27-2009 11:11:24.734, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.87, V, 0.87, V
02-27-2009 11:11:24.750, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:24.953, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:25.140, Fuel System 1 Status, OL-Drive: Open loop due to driving conditions. (e.g., power enrichment, deceleration enleanment), OL/CL, OL-Drive, OL/CL
02-27-2009 11:11:25.156, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:25.328, Calculated Load Value, 99.61, %, 99.61, %
02-27-2009 11:11:25.515, Engine Coolant Temperature, 221, deg F, 105, deg C
02-27-2009 11:11:25.734, Short Term Fuel Trim (Bank 1), 14.0625, %, 14.0625, %
02-27-2009 11:11:25.921, Long Term Fuel Trim (Bank 1), -2.34375, %, -2.34375, %
02-27-2009 11:11:26.125, Intake Manifold Absolute Pressure, 14.7826086956522, psi, 102, kPa
02-27-2009 11:11:26.312, Engine RPM, 942.5, rpm, 942.5, rpm
02-27-2009 11:11:26.515, Vehicle Speed Sensor, 16.25, mph, 26, km/h
02-27-2009 11:11:26.703, Ignition Timing Advance for #1 Cylinder, -3, deg, -3, deg
02-27-2009 11:11:26.890, Intake Air Temperature, 66.2, deg F, 19, deg C
02-27-2009 11:11:27.093, Absolute Throttle Position, 87.843137254902, %, 87.843137254902, %
02-27-2009 11:11:27.281, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.88, V, 0.88, V
02-27-2009 11:11:27.281, Short Term Fuel Trim (Bank 1, Sensor 1), 14.84375, %, 14.84375, %
02-27-2009 11:11:27.484, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.865, V, 0.865, V
02-27-2009 11:11:27.500, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:27.687, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:27.875, Fuel System 1 Status, OL-Drive: Open loop due to driving conditions. (e.g., power enrichment, deceleration enleanment), OL/CL, OL-Drive, OL/CL
02-27-2009 11:11:27.875, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:28.062, Calculated Load Value, 100, %, 100, %
02-27-2009 11:11:28.250, Engine Coolant Temperature, 221, deg F, 105, deg C
02-27-2009 11:11:28.453, Short Term Fuel Trim (Bank 1), 14.84375, %, 14.84375, %
02-27-2009 11:11:28.640, Long Term Fuel Trim (Bank 1), -2.34375, %, -2.34375, %
02-27-2009 11:11:28.843, Intake Manifold Absolute Pressure, 14.7826086956522, psi, 102, kPa
02-27-2009 11:11:29.046, Engine RPM, 1134.75, rpm, 1134.75, rpm
02-27-2009 11:11:29.234, Vehicle Speed Sensor, 19.375, mph, 31, km/h
02-27-2009 11:11:29.421, Ignition Timing Advance for #1 Cylinder, 1, deg, 1, deg
02-27-2009 11:11:29.625, Intake Air Temperature, 66.2, deg F, 19, deg C
02-27-2009 11:11:29.828, Absolute Throttle Position, 87.843137254902, %, 87.84313725490
Old 02-27-2009, 01:09 AM   #15
lindleypoolman
Fan#: 62924
02-27-2009 11:11:30.015, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.92, V, 0.92, V
02-27-2009 11:11:30.015, Short Term Fuel Trim (Bank 1, Sensor 1), 15.625, %, 15.625, %
02-27-2009 11:11:30.203, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.935, V, 0.935, V
02-27-2009 11:11:30.218, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:30.406, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:30.593, Fuel System 1 Status, OL-Drive: Open loop due to driving conditions. (e.g., power enrichment, deceleration enleanment), OL/CL, OL-Drive, OL/CL
02-27-2009 11:11:30.593, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:30.796, Calculated Load Value, 100, %, 100, %
02-27-2009 11:11:30.984, Engine Coolant Temperature, 221, deg F, 105, deg C
02-27-2009 11:11:31.187, Short Term Fuel Trim (Bank 1), 15.625, %, 15.625, %
02-27-2009 11:11:31.375, Long Term Fuel Trim (Bank 1), -2.34375, %, -2.34375, %
02-27-2009 11:11:31.562, Intake Manifold Absolute Pressure, 14.7826086956522, psi, 102, kPa
02-27-2009 11:11:31.765, Engine RPM, 1365.25, rpm, 1365.25, rpm
02-27-2009 11:11:31.953, Vehicle Speed Sensor, 23.75, mph, 38, km/h
02-27-2009 11:11:32.140, Ignition Timing Advance for #1 Cylinder, 1, deg, 1, deg
02-27-2009 11:11:32.359, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:11:32.546, Absolute Throttle Position, 85.4901960784314, %, 85.4901960784314, %
02-27-2009 11:11:32.734, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.91, V, 0.91, V
02-27-2009 11:11:32.734, Short Term Fuel Trim (Bank 1, Sensor 1), 15.625, %, 15.625, %
02-27-2009 11:11:32.921, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.94, V, 0.94, V
02-27-2009 11:11:32.937, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:33.125, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:33.328, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:11:33.328, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:33.515, Calculated Load Value, 100, %, 100, %
02-27-2009 11:11:33.718, Engine Coolant Temperature, 221, deg F, 105, deg C
02-27-2009 11:11:33.890, Short Term Fuel Trim (Bank 1), 5.46875, %, 5.46875, %
02-27-2009 11:11:34.093, Long Term Fuel Trim (Bank 1), -3.90625, %, -3.90625, %
02-27-2009 11:11:34.281, Intake Manifold Absolute Pressure, 3.6231884057971, psi, 25, kPa
02-27-2009 11:11:34.484, Engine RPM, 1963.75, rpm, 1963.75, rpm
02-27-2009 11:11:34.671, Vehicle Speed Sensor, 26.25, mph, 42, km/h
02-27-2009 11:11:34.859, Ignition Timing Advance for #1 Cylinder, 20, deg, 20, deg
02-27-2009 11:11:35.078, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:11:35.250, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:11:35.390, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.88, V, 0.88, V
02-27-2009 11:11:35.390, Short Term Fuel Trim (Bank 1, Sensor 1), 0.78125, %, 0.78125, %
02-27-2009 11:11:35.578, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.945, V, 0.945, V
02-27-2009 11:11:35.593, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:35.781, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:35.968, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:11:35.968, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:36.156, Calculated Load Value, 20.78, %, 20.78, %
02-27-2009 11:11:36.359, Engine Coolant Temperature, 222.8, deg F, 106, deg C
02-27-2009 11:11:36.562, Short Term Fuel Trim (Bank 1), 0, %, 0, %
02-27-2009 11:11:36.750, Long Term Fuel Trim (Bank 1), -8.59375, %, -8.59375, %
02-27-2009 11:11:36.937, Intake Manifold Absolute Pressure, 4.05797101449275, psi, 28, kPa
02-27-2009 11:11:37.140, Engine RPM, 1006.5, rpm, 1006.5, rpm
02-27-2009 11:11:37.328, Vehicle Speed Sensor, 9.375, mph, 15, km/h
02-27-2009 11:11:37.515, Ignition Timing Advance for #1 Cylinder, 25, deg, 25, deg
02-27-2009 11:11:37.703, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:11:37.906, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:11:38.109, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.89, V, 0.89, V
02-27-2009 11:11:38.109, Short Term Fuel Trim (Bank 1, Sensor 1), -1.5625, %, -1.5625, %
02-27-2009 11:11:38.281, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.885, V, 0.885, V
02-27-2009 11:11:38.296, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:38.500, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:38.687, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:11:38.687, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:38.875, Calculated Load Value, 19.61, %, 19.61, %
02-27-2009 11:11:39.062, Engine Coolant Temperature, 222.8, deg F, 106, deg C
02-27-2009 11:11:39.265, Short Term Fuel Trim (Bank 1), -0.78125, %, -0.78125, %
02-27-2009 11:11:39.468, Long Term Fuel Trim (Bank 1), 3.90625, %, 3.90625, %
02-27-2009 11:11:39.640, Intake Manifold Absolute Pressure, 4.49275362318841, psi, 31, kPa
02-27-2009 11:11:39.859, Engine RPM, 690.75, rpm, 690.75, rpm
02-27-2009 11:11:40.046, Vehicle Speed Sensor, 0, mph, 0, km/h
02-27-2009 11:11:40.234, Ignition Timing Advance for #1 Cylinder, 20, deg, 20, deg
02-27-2009 11:11:40.437, Intake Air Temperature, 64.4, deg F, 18, deg C
02-27-2009 11:11:40.625, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:11:40.812, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.92, V, 0.92, V
02-27-2009 11:11:40.812, Short Term Fuel Trim (Bank 1, Sensor 1), -2.34375, %, -2.34375, %
02-27-2009 11:11:41.015, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.915, V, 0.915, V
02-27-2009 11:11:41.031, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:41.218, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:41.406, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:11:41.406, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:41.593, Calculated Load Value, 20, %, 20, %
02-27-2009 11:11:41.765, Engine Coolant Temperature, 222.8, deg F, 106, deg C
02-27-2009 11:11:41.937, Short Term Fuel Trim (Bank 1), -3.125, %, -3.125, %
02-27-2009 11:11:42.109, Long Term Fuel Trim (Bank 1), 3.90625, %, 3.90625, %
02-27-2009 11:11:42.312, Intake Manifold Absolute Pressure, 4.34782608695652, psi, 30, kPa
02-27-2009 11:11:42.515, Engine RPM, 750, rpm, 750, rpm
02-27-2009 11:11:42.703, Vehicle Speed Sensor, 0, mph, 0, km/h
02-27-2009 11:11:42.890, Ignition Timing Advance for #1 Cylinder, 19.5, deg, 19.5, deg
02-27-2009 11:11:43.078, Intake Air Temperature, 66.2, deg F, 19, deg C
02-27-2009 11:11:43.281, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:11:43.468, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.91, V, 0.91, V
02-27-2009 11:11:43.468, Short Term Fuel Trim (Bank 1, Sensor 1), -3.90625, %, -3.90625, %
02-27-2009 11:11:43.656, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.915, V, 0.915, V
02-27-2009 11:11:43.656, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:43.875, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:44.062, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:11:44.062, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:44.250, Calculated Load Value, 22.35, %, 22.35, %
02-27-2009 11:11:44.437, Engine Coolant Temperature, 222.8, deg F, 106, deg C
02-27-2009 11:11:44.640, Short Term Fuel Trim (Bank 1), -4.6875, %, -4.6875, %
02-27-2009 11:11:44.843, Long Term Fuel Trim (Bank 1), 3.90625, %, 3.90625, %
02-27-2009 11:11:45.015, Intake Manifold Absolute Pressure, 4.34782608695652, psi, 30, kPa
02-27-2009 11:11:45.234, Engine RPM, 734.5, rpm, 734.5, rpm
02-27-2009 11:11:45.421, Vehicle Speed Sensor, 0, mph, 0, km/h
02-27-2009 11:11:45.609, Ignition Timing Advance for #1 Cylinder, 18.5, deg, 18.5, deg
02-27-2009 11:11:45.796, Intake Air Temperature, 66.2, deg F, 19, deg C
02-27-2009 11:11:46.015, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:11:46.187, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.905, V, 0.905, V
02-27-2009 11:11:46.187, Short Term Fuel Trim (Bank 1, Sensor 1), -6.25, %, -6.25, %
02-27-2009 11:11:46.390, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.91, V, 0.91, V
02-27-2009 11:11:46.406, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:46.593, Distance Traveled While MIL is Activated, , miles, , km
02-27-2009 11:11:46.781, Fuel System 1 Status, Closed Loop: Using oxygen sensor(s) as feedback for fuel control., OL/CL, CL, OL/CL
02-27-2009 11:11:46.781, Fuel System 2 Status, , OL/CL, , OL/CL
02-27-2009 11:11:46.968, Calculated Load Value, 21.57, %, 21.57, %
02-27-2009 11:11:47.156, Engine Coolant Temperature, 222.8, deg F, 106, deg C
02-27-2009 11:11:47.359, Short Term Fuel Trim (Bank 1), -7.03125, %, -7.03125, %
02-27-2009 11:11:47.531, Long Term Fuel Trim (Bank 1), 3.90625, %, 3.90625, %
02-27-2009 11:11:47.734, Intake Manifold Absolute Pressure, 4.20289855072464, psi, 29, kPa
02-27-2009 11:11:47.953, Engine RPM, 745.75, rpm, 745.75, rpm
02-27-2009 11:11:48.125, Vehicle Speed Sensor, 0, mph, 0, km/h
02-27-2009 11:11:48.312, Ignition Timing Advance for #1 Cylinder, 15.5, deg, 15.5, deg
02-27-2009 11:11:48.500, Intake Air Temperature, 66.2, deg F, 19, deg C
02-27-2009 11:11:48.703, Absolute Throttle Position, 21.1764705882353, %, 21.1764705882353, %
02-27-2009 11:11:48.890, Oxygen Sensor Output Voltage (Bank 1, Sensor 1), 0.88, V, 0.88, V
02-27-2009 11:11:48.890, Short Term Fuel Trim (Bank 1, Sensor 1), -7.8125, %, -7.8125, %
02-27-2009 11:11:49.093, Oxygen Sensor Output Voltage (Bank 1, Sensor 2), 0.89, V, 0.89, V
02-27-2009 11:11:49.109, Short Term Fuel Trim (Bank 1, Sensor 2), NOT USED, %, NOT USED, %
02-27-2009 11:11:49.296, Distance Traveled While MIL is Activated, , miles, , km
lindleypoolman is offline
Old 02-28-2009, 03:05 PM   #16
djmontara
djmontara's Avatar
Fan#: 59303
What I Drive: 2003 Ink Blue Focus 1.8 Zetec Ghia
FF Reputation: 3 djmontara Good Standing Member
hmm.. im quite stumped to be honest.. sometimes it seems ur running lean... but then other times ur running rich... i dont know why...
maybe some other peeps can chime in??
djmontara is offline
Old 02-28-2009, 03:07 PM   #17
djmontara
djmontara's Avatar
Fan#: 59303
i think u maay have a sliight vacuum leak somwhere...
Old 03-02-2009, 06:02 PM   #18
djmontara
djmontara's Avatar
Fan#: 59303
how is it goin chris? any luck figuring it out? you may want to ask tom? hes the tuning guru around here.. im sure he'll be able to point u in the right area with all ur data lol! keep me updated! ;)
Old 03-23-2009, 09:54 PM   #19
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT , Turbocharged
FF Reputation: 146 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
I would like to see it graphed , I also see a lot of running lean and didnt see any maf counts , also check your TPS voltage from idle to WOT 2 or 3 times with the engine off key on
Customer Support
AIM: hpdyno
Email: tom@focus-power.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 03-25-2009, 02:02 AM   #20
lindleypoolman
Fan#: 62924
What I Drive: 2001 Blue Focus CL
FF Reputation: 1 lindleypoolman Good Standing Member
Thanks for your quick reply Tom. I can do some live data graphs but my software only allows four sensors at a time to be monitored How would you like me to group them? There's no MAF sensor on this model. The ECU calculates air flow using a MAP sensor, RPM and air temp. I will also graph TPS data for you.
Thank you Chris.
Similar Threads
For Sale: Random Focus Parts Feral Archive 20 02-24-2009 10:23 PM
Power for Interior Mods skikid89 MK1 Interior Mods & Upgrades 5 01-16-2009 11:17 AM
500w and DVC?? sleepyboy Car Audio, SYNC, MyFord Touch & Electronics 17 09-16-2008 10:04 PM
BMW M3 Convertible Tom Ford Focus & General Car Chat 11 03-23-2008 12:09 PM
if u want a sc then u should read this good info blazealm General Forced Induction 15 01-26-2005 01:37 PM
