Constantly blowing the 20a wiper fuse after this little mod - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-16-2009, 04:18 AM   #1
ChrisRobin
ChrisRobin's Avatar
Fan#: 46204
What I Drive: 04 silver SVT Focus
Points 6,809, Level 54
Points: 6,809, Level: 54 Points: 6,809, Level: 54 Points: 6,809, Level: 54
Level Up 30% Completed
FF Reputation: 4 ChrisRobin Good Standing Member
So I recently picked up an intermittent wiper stalk for a few bucks but I didn't figure on the fact that some are made for the sedan which does not have the rear wiper.
So I decided to try an expirament. I figured there's no way Ford would make a bunch of different wiper stalks for different Focus's so they must be all the same more or less inside... and they are to a point. The only difference is in the arm of the sedan wiper stalk, there's a little attachment that isn't the same as the hatch one: it doesn't let you get that back and forth movement to activate the rear wiper and rear wiper fluid. So after taking things apart, swapping parts, resoldering the wires for the wiper speed switch and putting everything back together, I now have an intermittent wiper that works with a hatch and rear wiper. The ONLY problem is when I pull the wiper stalk to get fluid to shoot out, I blow out the "20" wiper fuse. I can pull it forward to activate the rear wiper but that extra push to activate the fluid consistantly blows the fuse. I'm probably missing something so in the end all of this probably won't work. I'm just curious now to find out why the fuse would blow out everytime. Any ideas??
Originally Posted by WRCwannabe View Post
...and then slap a supercharger on it and rape their tits off.
ChrisRobin is online now
Old 02-16-2009, 06:30 AM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Because you're grounding that switch leg out. Switch leg= wire going from switch to the switched device. Whichever wire gets the hot for that movement of the switch is grounded. I'd use a tester to figure out which one it was, and wire it over to something else that you use so that operation of the switch does two things- or just make sure it's taped up so it won't short out.
Apparently you've never worked on a Ford before. If you want parts swapping mania- try GM, then you get to deal with the interesting removal techniques that come with engineering multiple vehicles using the same parts.
Maybe mine is different since it's an 05, but I push a button on the end of the stalk to operate the fluid spray. Pulling the stalk backwards operates the rear wiper. I think so at least, never really paid much attention to it. I'll check it out this morning when I go to work and post this evening, but it's likely that it's a different stalk.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 02-16-2009, 02:20 PM   #3
ChrisRobin
ChrisRobin's Avatar
Fan#: 46204
Hmmm... I'll take a look and see what I can do. Thanks.
Similar Threads
Constantly blowing the 20a wiper fuse after this little mod. ChrisRobin MK1 Interior Mods & Upgrades 2 02-16-2009 03:49 PM
Anyone from the area done the $20 HP increase Chip MOD? higgszx3se Great Lakes Fanatics 5 07-18-2008 04:16 PM
head lamp fuse keeps blowing FocusedChick3187 General Technical Chat 3 11-29-2007 04:22 PM
Keep blowing Fuse 32 jhowton General Technical Chat 11 11-29-2007 02:00 PM
Intermittent Wiper Mod FiiZh General Technical Chat 22 04-09-2004 03:25 PM
