fuel pressure regulator? - Focus Fanatics
Old 02-15-2009, 03:37 PM   #1
nukldragr
nukldragr's Avatar
Fan#: 20618
What I Drive: 2000 ZX3 DD...2003 SVT
FF Reputation: 1 nukldragr Good Standing Member
During my 100 mile commute yesterday car started surging on the freeway...has done this a couple of times the last month or two...and usually happens around 80 miles into the drive...Just happen to have my scanner in the car this time so i hooked it up...was showing fuel pressure was dropping to 3 psi when i would accelerate...let off the gas and it would go back to 40 psi...Hasn't thrown a code yet either...have done some searchs and read about a fuel rail pressure sensor but not really anything on a regulator...is a regulator built into the fuel pump? Thanks, Tim
nukldragr is offline
Old 02-15-2009, 03:42 PM   #2
Onyx flash
Onyx flash's Avatar
Fan#: 19859
What I Drive: 05' pitch black ZX3
FF Reputation: 1 Onyx flash Good Standing Member
Buy-Sell-Trade Rating: (10)
There is no fuel pressure regulator on these cars, the pump cycles on and off to control pressure.
228whp 216wtq
05 Zx3 2.0 Duratec w/CP Pistons, K1 H-Beam Rods,HiBoost Turbo kit w/Focus Sport tuning @7 psi, 3" Magnaflow flex-back exhaust w/Carsound cat,F2 Flywheel,Exedy organic,VF dogbone,Koni dampers
Onyx flash is offline
Old 02-15-2009, 04:24 PM   #3
nukldragr
nukldragr's Avatar
Fan#: 20618
Also forgot to add that on my way back home after work fuel pressure held steady around 40 psi no matter where the throttle was... Saw on ebay a fuel pump driver module... where is this located... can the fuel pump come and go like this?
http://cgi.ebay.com/00-01-02-03-Ford...3A1%7C294%3A50
Old 02-15-2009, 05:14 PM   #4
malim
malim's Avatar
Fan#: 55004
What I Drive: 2007 Ford Focus ST - Black
FF Reputation: 4 malim Good Standing Member
You had your fuel pump recall done ??? Verryy common.
malim is offline
Old 02-16-2009, 02:04 PM   #5
jacx81
Fan#: 54211
What I Drive: 2000, black, ZX3
FF Reputation: 1 jacx81 Good Standing Member
really???? what about black plastic(kinda valve) thing on left side of fuel rail?? I thought it's preasure regulator, hm..
jacx81 is offline
Old 02-16-2009, 02:59 PM   #6
djmontara
djmontara's Avatar
Fan#: 59303
What I Drive: 2003 Ink Blue Focus 1.8 Zetec Ghia
FF Reputation: 3 djmontara Good Standing Member
jacx81 is right.. our cars do have fuel pressure regulators lool the funny little saucer thing on the end of the fuel rail is just that! lool
djmontara is offline
Old 02-16-2009, 04:27 PM   #7
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Memberpenguin Excellent Standing Member
Well, let's see, when you have a high fuel demand the fuel pressure drops, but when fuel demand is low, pressure is OK.
When was the last time you changed the fuel filter?
penguin is offline
Old 02-16-2009, 04:31 PM   #8
penguin
Fan#: 21700
I believe that is a fuel pressure sensor, providing fuel pressure information to the fuel pump control module. This is different from the traditional fuel pressure regulator, which physically regulates the fuel pressure:
http://www.atlanticz.ca/zclub/techti...0regulator.gif
http://www.zetecinside.com/xr2/pictures/040301_4.jpg
penguin is offline
Old 02-16-2009, 11:44 PM   #9
nukldragr
nukldragr's Avatar
Fan#: 20618
Changed fuel filter about 2 months ago... kept the scanner on it to and from work today and it keeps between 38 to 40 psi now no matter where the fuel demand... this problem only comes up every now and then...could the fuel pump be overheating at times...usually happens after about 80 miles into my drive...
Old 02-17-2009, 12:17 AM   #10
Grumpy
Fan#: 43791
What I Drive: 2005 Sonic Blue ZX3
FF Reputation: 28 Grumpy Great Standing Member
As mentioned ensure that the recall was accomplished. Try
"wiggling" the harness connector at the FP sensor and/or check the connector contacts and sensor pins for corrosion. That pressure regulator looking object is the fuel pressure damper, I believe.
Grumpy is offline
Similar Threads
No fuel pressure FiFoci General Technical Chat 2 10-30-2008 05:40 PM
How to determine a vacuum leak or lack of fuel focus_SWT General Technical Chat 0 11-27-2007 07:36 AM
Fuel pressure PAPI General Forced Induction 1 03-11-2007 08:23 PM
Warm start CEL svt81 General Technical Chat 8 09-22-2006 06:25 PM
Too Much Fuel Pressure BagginWagon General Technical Chat 8 04-06-2006 11:45 AM
