Charging system problem please help!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-13-2009, 06:06 PM   #1
C. Mills
C. Mills's Avatar
Fan#: 62033
What I Drive: 2013 ST2
FF Reputation: 2 C. Mills Good Standing Member
Ok so I have a 2005 zx4 with the D20. While driving this past week I noticed the battery light on the dash kept coming on. Twice this light came on while at a red light and the car died but started right back up. So I took it in to Ford and they tested the alternator and the battery and told me that the alternator is good but the battery is bad because it is not charging at an idle, it only charges when the rpm's are higher. (That sounds like an alternator problem to me.) So they offered to replace the battery for 70 bucks and see if that would fix it. I said no and took it to Advance Auto to get the battery and alternator checked. They said the battery is fine but their machine couldn't test my alternator for some reason. So I took it to Autozone to see what their machine said, and they told me everything was fine. When I got home my dad and I did the old start then unhook positive terminal trick to test the alternator and the car died so that tells me the alternator isn't charging right? If anyone can help me it would be greatly appreciated and i'm not afraid to hit that rep button lol.
C. Mills is offline
Old 02-13-2009, 06:22 PM   #2
malim
malim's Avatar
Fan#: 55004
What I Drive: 2007 Ford Focus ST - Black
Points 972, Level 16
Points: 972, Level: 16 Points: 972, Level: 16 Points: 972, Level: 16
Level Up 72% Completed
FF Reputation: 4 malim Good Standing Member
Good old tricks work. Alternator my friend. Get a multimeter and test the battery for voltage. Should be around 14.x volts If it is less, that is another proof of the alternator failing.
However good old trick is solid and points to the alternator.
malim is offline
Old 02-13-2009, 06:28 PM   #3
C. Mills
C. Mills's Avatar
Fan#: 62033
The battery is above 14 volts. Does this mean the alternator is only charging at higher rpm's and it's running off of the battery at lower rpm's?
C. Mills is offline
Old 02-13-2009, 06:41 PM   #4
Grumpy
Fan#: 43791
What I Drive: 2005 Sonic Blue ZX3
FF Reputation: 28 Grumpy Great Standing Member
Damn......first......NEVER, NEVER disconnect/reconnect the battery with the ignition switch ON, engine running or otherwise. It's a good way to kill your ECM, or alternator for that matter. A "good" battery voltage reading should be about 12.5 volts with the Ign. sw. OFF. At warm idle it should be over 13 volts, indicating that the alternator is putting out. Do you have aftermarket amps.?
Grumpy is offline
Old 02-13-2009, 06:45 PM   #5
C. Mills
C. Mills's Avatar
Fan#: 62033
Yea I have a full stereo system. The only thing is that when all this happened the subs and amp were sittin in my garage. I had them all installed from June until about a month ago and this problem started just a few days ago.
C. Mills is offline
Old 02-13-2009, 06:55 PM   #6
Grumpy
Fan#: 43791
First check that the battery posts and cable clamps are clean and tight. A good alternator will normally give you a voltage reading at the battery from something like 13 -13.5 volts at idle like I mentioned above, to something like about 14.7, maybe 14.9 volts max. at higher RPM.
Grumpy is offline
Old 02-13-2009, 11:36 PM   #7
C. Mills
C. Mills's Avatar
Fan#: 62033
Its all clean and tight. It seems like the alternator is only charging at higher rpms. It died on me 3 times tonight and I had to hold it and 1500 rpm at red lights just to keep it running.
C. Mills is offline
Old 02-14-2009, 04:22 PM   #8
C. Mills
C. Mills's Avatar
Fan#: 62033
any one else have any input??
C. Mills is offline
Old 02-14-2009, 04:27 PM   #9
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
Buy-Sell-Trade Rating: (4)
http://www.focusfanatics.com/forum/showthread.php?t=104396
maybe.
OH, you're not playing dumb ...
iminhell is offline
Old 02-14-2009, 04:49 PM   #10
C. Mills
C. Mills's Avatar
Fan#: 62033
I can't get to the alternator to check that right now but i did notice this piece broken and maybe it has something to do with my problem. I'll attach pics.
C. Mills is offline
Similar Threads
Alternator Charging Problem! Help! Moved from JRSC Forced Induction GDGemmer General Technical Chat 0 12-04-2008 01:32 PM
Charging System Problem, Need Advice nate2006 General Technical Chat 8 02-29-2008 12:39 PM
charging system problem blazinzx3 Car Audio, SYNC, MyFord Touch & Electronics 4 07-31-2006 04:56 PM
Problem with AM/FM reception with OEM single-CD audio system lavalfocus Car Audio, SYNC, MyFord Touch & Electronics 0 07-18-2006 01:21 PM
Charging System Woggie General Technical Chat 7 08-31-2005 09:59 PM
