HTPerformance Adjustable Rear Toe Arms - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-09-2009, 01:38 AM   #1
HTPerformance
HTPerformance's Avatar
Fan#: 41307
What I Drive: 2002 SVT Focus
FF Reputation: 10 HTPerformance Great Standing Member
Buy-Sell-Trade Rating: (7)
HTPerformance is proud to introduce a fully Adjustable Rear Toe Arm set! As many Focus and Mazda 3 tuners lower or even raise their rides to maximize performance, caster and camber angles can become skewed and don’t exactly comply with the drivers’ needs. The HTP Adjustable Rear Toe Arm, when correctly installed will allow the tuner to fully adjust rear toe, and may also aid in achieving caster and camber angles desired for performance suspension installations. Other companies make their arms with inferior components such as paper thin rubber bushings that can wear quickly and are prone to dry rot; the use of mild steel alloys is also a big mistake when it comes to long lasting performance. Why just make an adjustable stock arm? It just doesn’t make sense to us.
HTPerformance Adjustable Rear Toe Arms are made with only the best components:
• Adjustable Rear Toe Arm body is made from high grade billet 7075 Aluminum alloy; it is much more expensive than 6061 and 2024 but is well worth the added expense for the additional performance as well as safety and corrosion resistance.
• Adjustable Rear Toe Arm body is anodized to maintain structural performance and to keep the finish long lasting.
• 3pc QA1 Rod Ends
Ball -
52100 Bearing Steel
Heat treated
Hard Chrome Plated
Race -
Stainless Steel
Heat Treated
Self Lubricating Teflon Lined (PTFE)
Body -
Alloy Steel
Heat Treated
Protective Coated for Corrosion Resistance
This is NOT an economy 2pc mild steel rod end!
Other companies will tell you that their toe arms alone will allow for every adjustment on the rear suspension, but this is not true. Be sure to use camber bolts in the curved upper control arm in conjunction with HTP Adjustable Rear Toe Arms and the stock lower arm camber bolts.
If you demand the best for your ride, HTP is your go-to company.
http://htperformance.net/index.php?p...emart&Itemid=1
Updated PDF version of the installation instructions.
See our forum for more info!
HTPerformance is offline
Old 02-09-2009, 12:09 PM   #2
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
Rear caster?
Geezer is offline
Similar Threads
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
htperformance.net adjustable toe arms FOCUSSTDRIVER Wheels & Tires 9 10-19-2008 12:48 AM
For Sale: BRAND NEW SPC Adjustable Rear Control Arms imprtslyr0223 Archive 6 04-12-2008 10:18 PM
Alignment ? (rear toe) ZX3inJersey Wheels & Tires 3 04-07-2008 11:32 PM
Rear Control Arms 00ZetecSE Wheels & Tires 0 10-30-2007 09:25 PM
