Turbo LSX Focus - Page 60 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-16-2009, 08:05 PM   #591
Tantalus
Tantalus's Avatar
Fan#: 47203
What I Drive: 2005 CD Silver ZX3
FF Reputation: 48 Tantalus Great Standing Member
Ouch, sorry to hear that sir. At least we got a good documentation on what NOT to do to a turbo lsx focus ;)
As if the rest of us could do fab work like that... :rolleyes:
2005 Ford Focus ZX3 D23 Swapped 5-speed
FSWerks Header, flex, 2.5" SS exhaust
Custom Ported 2.0L head, Stock cams w/ Crower springs/Titanium Retainers
Quaife ATB Differential, Exedy Stg II Clutch/Flywheel
Coming soon...
Tantalus is offline
Old 11-17-2009, 07:31 AM   #592
Roushturboedzx3
I Fab Too Much
Roushturboedzx3's Avatar
Fan#: 42814
What I Drive: 2002 Liquid Gray ZX3
Points 14,483, Level 78
Points: 14,483, Level: 78 Points: 14,483, Level: 78 Points: 14,483, Level: 78
Level Up 9% Completed
FF Reputation: 20 Roushturboedzx3 Great Standing Member
Buy-Sell-Trade Rating: (18)
Oooooo woww that sucks Tim Bring it down here here and ill hook you up ;) on some turbo manifolds. lol but man that really blows if you need any help with making the manifold or if you get it tacked up and want it tig welded to make it pretty ill help you out
New: 2012 Mustang GT premium
SOLD:RACE GAS 602whp 501tq Pump Gas SAE 454whp
Garrett GT3582r, Topmount, built motor, Ported head,Tuned by Fernando@RacingPartsSolution
I may not be the baddest, but the baddest dont Fu** with me
Roushturboedzx3 is offline
Old 11-17-2009, 08:37 AM   #593
ChuckDee
Ehh...
ChuckDee's Avatar
Fan#: 43589
What I Drive: 02 SC SVT
Points 17,687, Level 84
Points: 17,687, Level: 84 Points: 17,687, Level: 84 Points: 17,687, Level: 84
Level Up 68% Completed
FF Reputation: 48 ChuckDee Great Standing Member
Buy-Sell-Trade Rating: (6)
damn dude, i can see some rubbing in the future, especially with those pipes running right over the tire itself! are u still gonna find a way to clear it?
unique(adj): to break off from the crowd and do your own thing
ChuckDee is offline
Old 11-17-2009, 11:23 AM   #594
Zx2Lame
Fan#: 66915
What I Drive: 2001 Tropic Green Zx2
FF Reputation: 1 Zx2Lame Good Standing Member
Originally Posted by hourang View Post
so your using the focus suspension? have you had it on the ground yet with all that weight up front?
you do know that the LSx engine are very lightweight. If its an aluminum one the difference in weight from the zetec to the LSx is 40lbs.......... if its cast iron its 110lbs. most of the weight wont be up front, it will be in the middle to back where theres a bunch of "weird" new parts the focus isnt use to, like a rearend, driveshaft, etc.
Zx2Lame is offline
Old 11-17-2009, 12:14 PM   #595
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 21,159, Level 91
Points: 21,159, Level: 91 Points: 21,159, Level: 91 Points: 21,159, Level: 91
Level Up 62% Completed
Forum Activity 7%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
i may take you up on that tig welding. i can build it myself no problem.. but i cant weld like a tig thats for sure.
where do you get your shed 10 piping?
as far as the engines weight goes it is a cast iron block cause i couldnt afford an aluminum one. i do plan on building the engine later on and i may very well switch to a ls2 who knows.
Turbo Turtle Garage
Zetec and Duratec Turbo kits, engine building
turboturtlegarage.com
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 11-17-2009, 12:59 PM   #596
hourang
Fan#: 67397
What I Drive: 2000 T-Red Sedan 5speed
FF Reputation: 5 hourang Good Standing Member
wow that sux. i would just get it working without the turbo for now.
-Jeff
2000 Focus Sedan - 5 speed SPI - T-Red
1994 GMC Sierra - ext cab - 5.7l TBI - blowmaster dual exhaust
*sold* 98 Camaro SS - 6sp silver - cam/intake/exhaust, 6pt cage, ford 9" w/truetrac, 150wet shot, dr's
hourang is offline
Old 11-17-2009, 02:56 PM   #597
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 7%
umm... the turbo is already on it, im going to get it working with the turbo, then change it.
Turbo Turtle Garage
Old 11-17-2009, 04:28 PM   #598
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 7%
well some good news on top of the bad. the wiring for the engine is almost done. and the ecu didnt smoke when i connected it to the computer and appears to be working so far. i need to hook up the sensor signal for the crank and cam sensor and that is all for the ecu. then i have to hook up relays and power for stuffs. i have to get a oil sending unit to plug the whole in the block with, i have to put oil in it, get a dip stick, and fuel cell in... should be able to start it soon.
as far as the manifold i am going to have to build i have done some searching. there are tons of these engines in various tight places so there are a lot of different manifold built. so far this seems to be the best i have found. of course my turbo flange will be further back than this but you get the idea.
1.5" primaries into a 3" log, 2.5" cross over in the front comming into the bottom of the manifold, turbo sits on top with wg mounted in collector area. the downpipe will go back, through the firewall (will make a small tunnel of some kind), and out the side of the car in front of the door. wack as hell i know but it should work better.
Turbo Turtle Garage
Old 11-17-2009, 04:48 PM   #599
SVTRSST
70 100 70 70 : (
SVTRSST's Avatar
Fan#: 50439
What I Drive: 2003 Sonic Blue SVT Focus
Points 8,661, Level 62
Points: 8,661, Level: 62 Points: 8,661, Level: 62 Points: 8,661, Level: 62
Level Up 71% Completed
Level up: 71% Level up: 71% Level up: 71%
FF Reputation: 16 SVTRSST Great Standing Member
Buy-Sell-Trade Rating: (10)
uhm would that design of manifold work with a foci?.. it actually looks cool haha
'03 SVT
0381 of 3985
SVTRSST is offline
Old 11-17-2009, 05:15 PM   #600
SVTflyer03
RB25 = Amazing
SVTflyer03's Avatar
Fan#: 62344
What I Drive: 2003 Infra Red SVT ZX5, 1991 240sx
FF Reputation: 5 SVTflyer03 Good Standing Member
nice!
Moderator for your Buy - Sell - Trade, General Chat, and Showroom forums
SVTf 5-door #892 out of about 2200
Hi
SVTflyer03 is offline
Similar Threads
Zero to 60 & 1/4 Miles Times (List of all cars) OrangeSVTguy Drag Racing 36 07-09-2013 10:48 PM
The Ford Focus - General History and Information S2 Ford Focus & General Car Chat 1 11-14-2008 03:04 PM
