Turbo LSX Focus - Page 116 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-11-2011, 10:12 PM   #1151
FocusBoy58
Sonic Mk3 Crew #03
FocusBoy58's Avatar
Fan#: 38424
What I Drive: 01 Turbo,12 SE,95 Vette 396
Points 20,766, Level 90
Points: 20,766, Level: 90 Points: 20,766, Level: 90 Points: 20,766, Level: 90
Level Up 84% Completed
Forum Activity 2%
FF Reputation: 14 FocusBoy58 Great Standing Member
Buy-Sell-Trade Rating: (16)
With the 3 speed what kind of rear end gearing are you going for? 2.93?
2012 Audi Q7 TDI S Line ABTuning 391whp588wtq
01 Turbo Focus 300+ whp
2012 Focus 19" Niches, AEM CAI, F2 Race Header, 3" Borla Dual Exit, H&Rs, Eibach Sways 183whp157wtq
FocusBoy58 is offline
Old 12-11-2011, 11:10 PM   #1152
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 20,973, Level 91
Points: 20,973, Level: 91 Points: 20,973, Level: 91 Points: 20,973, Level: 91
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 11%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
stock mustang. i think 2.93 is about right
Turbo Turtle Garage
Mig and Tig fabrication, engine building
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 12-11-2011, 11:20 PM   #1153
dino lord
Fan#: 92295
What I Drive: black 04 SVTF5
FF Reputation: 1 dino lord Good Standing Member
Originally Posted by Turbo Turtle View Post
Everything
really. if you gotta ask your going to have a lot of trouble doing it. front subframe is cut all to pieces and modified to allow the engine to fit through, motor mounts to be attached, and rack and pinion to be attached to. rack has to be moved to the front and you will have to change to a rack that is meant to work up front such as a mustang or a pinto rack. if you want power steering that has to be custom. steering shaft has to be custom. hubs have to be swapped around for the rack to attach in the front, brake lines have to be moved to the front. trans tunnel and fire wall have to be cut out if you dont want to raise the car up real high like they do with the krugel kit. cooling system has to be custom. drive shaft will have to be custom built. trans crossmember. rear subframe has to be removed and thrown it the trash. buy either a solid axle or a irs rear subframe out of something irs from factory and make it fit. you will have to cut the whole rear end out of the car if you want the ride height lower than the krugel kit. rear crossmember and link mounts for rearend. c-notch frame rails if you want it lower than krugel kit. most people use vertical coil overs like mine. custom rear brake lines and parking brake. custom fuel system with fuel cell. since the rear end will be 5 lug if you want to use a mustang one then you will either have miss matched wheels or have to do a 5 lug conversion or redrill hubs (i did the 5 lug conversion using parts from a mazda3). custom wiring, gauges, and ecu. i did a lot more custom stuff b/c of the turbo system... this makes it all sound so simple to and im probably forgetting 1/2 of it. ive spent 3 years and 1150 posts on this thread doing it... good luck
i got the cliff notes. guess i need to brush up on my welding skills if i go thru with it. i have no problem engineering something to make it worth. the only think i lack right now if fab/welding skills, only bc i've never been anything more than oxy-acetylene and a lil stick welder. hm.
if i did, i would leave it n/a. a cam only ls1 should propel a 2800 pound well into the 10's if it'll hook.
2:73, 3:08, or 3:27 are 3 most common depending on year and car it came from.
dino lord is offline
Old 12-11-2011, 11:55 PM   #1154
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 11%
2.73
lots of welding if you go the same route as me. probably 100lb of wire
Turbo Turtle Garage
Old 12-12-2011, 10:00 AM   #1155
dougy fresh
Sooo Fresh
dougy fresh's Avatar
Fan#: 12780
What I Drive: 2000 zx3, 1978 mustang II 302
Points 2,829, Level 32
Points: 2,829, Level: 32 Points: 2,829, Level: 32 Points: 2,829, Level: 32
Level Up 53% Completed
FF Reputation: 4 dougy fresh Good Standing Member
2.73
thats a good highway gear and you sir have awesome Fab skills and holy hell thats alot of wirez
ZETECCREW#208
Hatch Nation # 74
dougy fresh is offline
Old 12-12-2011, 10:29 AM   #1156
dino lord
Fan#: 92295
as per your sig: so how much for the project?? :)
Old 12-12-2011, 06:43 PM   #1157
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 11%
depends on when you buy it really. probably like 17k, would like to get 20 but i dont know if i can since its just a focus lol.
Turbo Turtle Garage
Old 12-12-2011, 07:40 PM   #1158
dino lord
Fan#: 92295
Oooooooohhhhhh.
*this post made by and approved by the one and only Dino via extra-terrestrial communimacations.
Old 12-15-2011, 12:03 AM   #1159
Rudel
FF's Quadriplegic!
Rudel's Avatar
Fan#: 13465
What I Drive: 2.3 ATX-RSVT
Points 10,049, Level 66
Points: 10,049, Level: 66 Points: 10,049, Level: 66 Points: 10,049, Level: 66
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 15 Rudel Great Standing Member
Buy-Sell-Trade Rating: (17)
3 speed, AOD?
I might have a nice RS kit to weld on...
513whp on Race Gas; Tuned by Fernando@RacingPartsSolution.com
Pump gas? Ppffff!
Part III: Install Handicap Driving Controls
Ma Cah: http://imgur.com/a/TuyYL
Rudel is offline
Old 12-15-2011, 12:58 AM   #1160
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,634, Level 94
Points: 23,634, Level: 94 Points: 23,634, Level: 94 Points: 23,634, Level: 94
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
you know you want it Mike
wondering about why power steering needs to be custom other than the lines themselves.
mikebontoft is offline
Similar Threads
Zero to 60 & 1/4 Miles Times (List of all cars) OrangeSVTguy Drag Racing 36 07-09-2013 10:48 PM
The Ford Focus - General History and Information S2 Ford Focus & General Car Chat 1 11-14-2008 03:04 PM
