Blower motor resistor? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-03-2009, 02:29 PM   #1
kmv2
Fan#: 59782
What I Drive: 2001 Amazon Green SE
FF Reputation: 1 kmv2 Good Standing Member
2001 Focus SE SPI, 125,000km
OK, so yesterday I'm driving and smell something like burning diesel or axle grease kind of smell right.. then all of a sudden the cabin just fills with smoke.
Ok whatever, I open the window and pull over.. can't really see anything wrong, just a bit of smoke rising from the back of the engine.
I figure if it was the auto trans or pwr steering, it would be pouring out fluid because they are under pressure, and they are both still full of fluid. Oil in the engine is good too, no noticeable leaks on the ground overnight.
Anyways, so I start it up this morning and notice that there's no heat (blower motor not going). After an hour looking through the fuses, I find the #64 one is blown (FORD needs to work on their little icons that they print on the fusebox maps!!). A new fuse didn't work right away so I jumped it to see if the motor would turn on anyways and it did, then I put a new fuse in and it seemed to work ok, BUT now it just works on the highest speed.
This is probably the blower motor resistor (I probably fried it when I did that jump).. but I am still unsure what this damn burning oil smell is.
Whatever. Any thoughts?
kmv2 is offline
Old 02-03-2009, 02:35 PM   #2
sleddog
sleddog's Avatar
Fan#: 14810
What I Drive: 2009, Silver Metallic, Focus
FF Reputation: 1 sleddog Good Standing Member
The resistor pack is gone... That's why you have only high speed. It's behind the glove box... I went thru 3 or 4 of them on my 2001...
As for the burn oil smell... It could be the resistor pack, maybe... But usually the power resistor, it's actually more of a fuse, blows on the pack and it doesn't generate any smell or smoke.. But I guess anything is possible..
PhuturePrimitive, Crystal Method, Thievery Corporation, Kaya Project
2009 Focus S
2001 Focus LX - Retired at 362,718 miles
sleddog is offline
Old 02-03-2009, 02:54 PM   #3
kmv2
Fan#: 59782
Definitely not electrical burning.
So weird though, because the car runs and operates fine, and there was no visible leaks in the snow this morning.
I think I must have run over a piece of snow junk that fell off a diesel truck or something, and now I got a big lump of axle grease on the exhaust pipe or something.
ughhghg
Yeah, I saw the resistor this morning, seems simple enough to replace.
kmv2 is offline
Old 02-03-2009, 03:29 PM   #4
sleddog
sleddog's Avatar
Fan#: 14810
Remove the one screw, remove the connector, do the reverse to install.. That's it..
I usually remove the glove box. It's just 2 screws and it makes it easier to get to the resistor pack.
2009 Focus S
sleddog is offline
Old 02-07-2009, 01:31 PM   #5
Donk1000
Fan#: 62404
What I Drive: 1999 Black five door with boot
FF Reputation: 1 Donk1000 Good Standing Member
If you purchase a very long cross head(posidrive) screwdriver,(At least 2Ft long) you can open glove box and remove it, then the screw that holds in the resistor is easily accessible... Takes about 20 minutes in all...
Donk1000 is offline
Old 02-07-2009, 01:37 PM   #6
kmv2
Fan#: 59782
lol the blower motor resistor is like the easiest bit of this.
Still wondering what that burning smell is though.. guess I'll have to wait until something fails I guess.
whatev/
kmv2 is offline
Old 02-07-2009, 05:47 PM   #7
sleddog
sleddog's Avatar
Fan#: 14810
Why spend the extra money on the screw driver? With out the very long cross head (I guess that's a phillips) (posidrive) screwdriver (at least 2 feet long) it takes less than 10 minutes to remove the glove box and change the pack.
See... Not only are you saving money by not buying 2 foot screw driver, you're saving 10 minutes... Spend the extra 10 minutes
2009 Focus S
sleddog is offline
Similar Threads
A short in my fuse (64) - heater blower motor? underthought General Technical Chat 3 12-30-2014 12:23 AM
Water in passenger foot well after heavy rain 2003 ZX3 Shoreman General Technical Chat 16 04-29-2013 12:52 PM
Heater Blower Motor-2002 SE Wagon Bo T General Technical Chat 4 06-08-2012 04:58 PM
SATIRE: Leaf Blower Race munkyv22 General Racing Chat 5 09-16-2005 04:01 PM
A/C & blower motor problem....HELP, I'm burning up! BlownSkillet General Technical Chat 10 07-07-2004 07:07 AM
