Advancing or Retarding Timing? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-02-2009, 01:33 PM   #1
mtadd162
Proudly Daily Driven
mtadd162's Avatar
Fan#: 47890
What I Drive: 2005 Focus ST
Points 5,921, Level 49
Points: 5,921, Level: 49 Points: 5,921, Level: 49 Points: 5,921, Level: 49
Level Up 86% Completed
FF Reputation: 9 mtadd162 Good Standing Member
I came across a question in another thread and it seemed to peak more interest than i thought so i decided to make a thread about it...im gunna do some copy and pasting because im lazy...what started the convo is
on my old tune i made more hp cuz he advanced the timing (at a local dyno), but due to his lack of his duratec experience that caused a couple hiccups i had to go back to my base tune which now i know i basically just wasted my money...
so i wanted to know is can we safely adjust the timing ourselves? if so how?
now im gunna add some quotes from other users that kept this progressing
05 Focus ST-Sold but missed
-ST Crew #73 N/A FTW!
Feb. 09' ROTM
SSR - Silver Sedan Revolution Member #1
Cams Installed, great made my car into a VTAK
mtadd162 is offline
Old 02-02-2009, 01:35 PM   #2
mtadd162
mtadd162's Avatar
Fan#: 47890
Originally Posted by jetrinka View Post
There is a way through the xcal. You have certain RPM ranged you can choose to advance or retard timing. I forget how many degrees you have either way. I believe its 10? Not sure.
Originally Posted by mtadd162 View Post
hmmm certain rpm range you say...how is it broken up??
or do u mean it just gives you a specific range that you can adjust?
Originally Posted by NemesisEnforcer View Post
remember, tho, the pcm already advances/retards the timing too.
No. I believe it adds the advancement or retardation (lol) to the base numbers of your tune.
and one more
Feb. 09' ROTM
mtadd162 is offline
Old 02-02-2009, 01:36 PM   #3
mtadd162
mtadd162's Avatar
Fan#: 47890
Originally Posted by tb1999 View Post
I have the SCT pro Racer package similar to what the Vendors use to create/sell tune. (I don't have the package to create tunes for sale, but I can create my own)
Anyway, you can create a cal with XYZ timing tables to do all sorts of custom calibrations, the ECU does a bunch of calcualtions and comes up with an "optimum" spark based on operating conditions and the parameters programed into the CAL.
Now when the cal is sent from their SW package to the flasher, X2 or X3 in my case, there are "options" that can be added for selection at the time you reflash your car. So a "spark adder/subtractor" can be selected that will modify the "calculated" spark at any given time. These are arranged into RPM ranges, 0-2000 2000-4000 & 4000-8000.
So if you add 2 deg to the 4000-8000 you get and extra 2 degrees above 4000 on top of what the calibration is programmed to do. Or -2 degress, and you get a retard to the calculated timing. The Min Max values for these options are limited by the calibrator when the cal is loaded into the flasher so you can't get out of control with the options.
There are also options for Idle RPM, cooling fan switch points, Tire and Rear Diff Ratios, AF/Ratio @ WOT, and a few others, I can't remember all of them.. For ATX versions you can change shift points too.
But vendors will charge extra for these options since they allow you more flexibility and no need to get them to redo your cal if you want to make minor adjustments. Like if I were building an ATX drag racer, I would definitly want some control over my shift points without needing a new cal!
which got me to wondering....
Feb. 09' ROTM
mtadd162 is offline
Old 02-02-2009, 01:37 PM   #4
mtadd162
mtadd162's Avatar
Fan#: 47890
yea i have those options...now with the original tune that i made more power on, he just simply said he advanced my timing a bit...so if i were to attempt this would it be safer to add 2 degrees to all 3 ranges of just 2 out of the 3, or just stick with one?
driving the car i felt a lot more oomph in the 2000 to 4000 range...so shoudl i go with what i felt?
and whats the negative effects if i added too much? my car would just start misfiring?
Feb. 09' ROTM
mtadd162 is offline
Old 02-02-2009, 02:28 PM   #5
RhodySVT
RhodySVT's Avatar
Fan#: 40538
What I Drive: 2000 Celica GT-S 6MT
FF Reputation: 7 RhodySVT Good Standing Member
Well if you get too crazy with adding timing you can get deto, probably not as much now when it's very cool around here (what octane are you running?) but during the summer, under load, you want to be careful not to add too much timing, it can lead to preignition and possibly damage the engine.
And to clarify we are talking about spark timing here, not cam timing
2002 Sonic Blue SVT #62 SOLD
2004 CD Silver SVT ZX5 Euro PowerWorks#1062 of 1079 SOLD to ADAMSVT
Foci I will miss ye...
RhodySVT is offline
Old 02-02-2009, 03:04 PM   #6
mtadd162
mtadd162's Avatar
Fan#: 47890
right spark timing...and im running 93 octane
so those are the effects of under or over timing...
so is this done by trial and error?? there has to be some logistics on how to advance it or what spark range to advance it in...
Feb. 09' ROTM
mtadd162 is offline
Old 02-02-2009, 04:27 PM   #7
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,506, Level 100
Points: 52,506, Level: 100 Points: 52,506, Level: 100 Points: 52,506, Level: 100
Level Up 0% Completed
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
NO you should NOT be ading timing to your engines once you get a tune , VERY DANGERIOUS
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 02-02-2009, 04:40 PM   #8
streetracer
streetracer's Avatar
Fan#: 49229
What I Drive: 2005 Infra Red Focus ST
FF Reputation: 5 streetracer Good Standing Member
i think this stuff should be left to the experts
streetracer is offline
Old 02-02-2009, 08:46 PM   #9
focusboy5
focusboy5's Avatar
Fan#: 50002
What I Drive: Four Wheels
Points 8,328, Level 61
Points: 8,328, Level: 61 Points: 8,328, Level: 61 Points: 8,328, Level: 61
Level Up 60% Completed
FF Reputation: 31 focusboy5 Great Standing Member
Buy-Sell-Trade Rating: (13)
What does 91, and 93 octane add?
kind of off topic but you stated you are running, or were, 93 octane.
focusboy5 is offline
Old 02-02-2009, 11:03 PM   #10
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
It allows you to safely advance the timing. The gas burns slower.
jetrinka is offline
Similar Threads
SPI Timing Belt Change How to untenops SPI Performance (2000-2004) 41 12-05-2013 08:25 PM
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
"How To" VCT Trouble-TSB 03-6-07 Springbuck SVT Performance (2002-2004) 26 08-18-2009 02:21 PM
Timing / Knock sensors /Engine Failure 1turbofocus Focus-Power Tuning 25 01-05-2008 01:44 PM
Advancing your timing resulting in HP+++ autocrossman DURATEC Performance (2003-2007) 26 10-08-2007 02:38 PM
