Project FSP Focus is kicked off!!! - Page 15 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 06-27-2011, 10:37 PM   #141
GodLovesUgly
.Flat Out.
GodLovesUgly's Avatar
Fan#: 56705
What I Drive: ^^^ That!
Points 28,334, Level 98
Points: 28,334, Level: 98 Points: 28,334, Level: 98 Points: 28,334, Level: 98
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 10 GodLovesUgly Great Standing Member
Buy-Sell-Trade Rating: (7)
see, breaking things isn't always THAT bad! you just get to upgrade the part!
i can't wait for the review, that should be a noticeable difference for sure.
The Rich Get Richer Until The Poor Get Educated.
Do Vegetarians eat Animal Crackers?
Moderator of Ford Focus Racing Discussions & Rocky Mountain Fanatics
GodLovesUgly is online now
Old 07-18-2011, 11:36 AM   #142
Blackcatn2o
soon to be turbo!
Blackcatn2o's Avatar
Fan#: 48278
What I Drive: 06 silver ZX4 ST
Points 8,020, Level 60
Points: 8,020, Level: 60 Points: 8,020, Level: 60 Points: 8,020, Level: 60
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 48 Blackcatn2o Great Standing Member
Buy-Sell-Trade Rating: (13)
Bumping the thread because I too am also curious on the Kaaz diff.
Blackcatn2o is offline
Old 07-19-2011, 10:51 AM   #143
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,584, Level 37
Points: 3,584, Level: 37 Points: 3,584, Level: 37 Points: 3,584, Level: 37
Level Up 56% Completed
FF Reputation: 23 wrc_fan Great Standing Member
Well, the work is done, and I made it to one day of the two day autox. Thanks to Andrew and others for their help on this undertaking, I owe Andrew some time as crew at a rally in the future. Doing this was quite the undertaking, and without a doubt the most extensive bit of car repair/work Ive undertaken.
Some lessons learned from all this work:
-If you are going to use a junk yard transmission, check all of the threaded holes for damage
-The best way to drop the transmission and reinstall it is to drop the subframe
-The bracket on top of the steering rack uses a 5.5mm size bolt head, luckily a 7/32 is pretty close
Some crappy cell phone pics:
Original autox car gear set, third syncro is beyond toast
Guts from the junkyard trans in the original case
Getting setup to check for play in the diff
"Super" Limited Slip
Time to go under the car. Next time, I will be taking the front bumper cover off
After the initial install, the Kaaz differential requires a break in procedure and changing the transmission fluid afterwards. Do this step. Also note, this is not a part for a daily driver. The diff is expensive, loud, and requires frequent trans fluid changes. Driving in parking lots slowly is equivalent to driving a 4x4 with a locked front axle.
The good news, the new differential has made the car night and day different to drive. This is a good thing, accelerating out of a turn, both tires send power to the ground, and the car grips and goes like hell. The ability to put power to the ground when turning, threw off my normal timing in the slaloms. I was also a little hesitant to hammer on the car at first, given that I had just spent many days getting it back together. With the autox that weekend, we only had 4 timed runs, but by the end I had easily knocked 5 seconds off my original run and the car felt like it had lots of time left in it. Also, consider that my last two runs were without a rear sway bar (need to fix the rear endlink).
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 07-20-2011, 11:12 AM   #144
GodLovesUgly
.Flat Out.
Fan#: 56705
that is awesome!
i can only imagine the difference! i bet it felt like a different car.
that's true, after taking something like a tranny apart and putting it back together with a foreign part would make me hesitant to go flat out as well.
nice work man.
Old 08-01-2011, 05:35 PM   #145
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
I wasn't worried about the japanesse part, more worried about my mechanic skills, hehe.
Also, opened up this thread to brag that I found an advance track car at the junkyard. So yeah, I got out of there with e-brake cables, hubs, spindles, calipers and braklines for $149. Not sure when it'll be worked into the autox car, but I think it will be a project for this winter. Rear disk upgrade, will it make a difference, we shall see.
Parking Lot Hero
wrc_fan is offline
Old 08-22-2011, 09:08 AM   #146
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
New update, motor mounts have been upgraded, with crappy pictures
Transmission mount before install. I wasn't thrilled about the design of the VF mounts. They look functional, just not optimized for what we're trying to do here. The stock mount uses a burly nyloc nut. I'm pretty sure that friction from the bushing should keep thinks from coming loose, but I added some blue locktite for just in case.
Original mount, pretty rough shape.
Mount is out.
New mount, all torqued down and in place. The VF piece is tricky to get lined up right.
Old passenger side halfway through disassembly. This mount was completely trashed, what a crap design from the factory.
New mount in, I liked the concept of this guy better, but I would add a few tweaks to it. The bolts supplied could be a little longer... Added blue locktite for where the aluminum mount bolts to the steel bracket. These bolts come with split washers in the kit, and if you read Carrol Smith's books, you'll know that split washers are useless.
Vibration didn't feel any worse, so that was good. Actually since the passenger mount was so bad, I got rid of a wierd vibration on decel.
Parking Lot Hero
wrc_fan is offline
Old 08-23-2011, 10:51 AM   #147
GodLovesUgly
.Flat Out.
Fan#: 56705
looks good. i need new motor mounts. every time i let off the brakes it feels like my motor is going to fly out of the hood.
how long did this take?
Old 08-23-2011, 12:32 PM   #148
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
Not more than an hour, now that I have an air impact, there's not much to slow me down.
Just pull the battery, move the coolant overflow tank, and everything else is right there. I supported the engine underneath with a jack and big block of wood.
Parking Lot Hero
wrc_fan is offline
Old 08-23-2011, 03:56 PM   #149
Blackcatn2o
soon to be turbo!
Fan#: 48278
Air tools make life so much easier.
Old 10-19-2011, 03:17 PM   #150
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
The FSP car is finally making a pilgrimage to the tail of the dragon this weekend. Check out the carolina's section for details.
Parking Lot Hero
wrc_fan is offline
Similar Threads
Project: 4WD cossie powered WRC kitted Focus!!! *56K;noway! ozan Ford Focus Builds & General Showroom 200 01-12-2015 11:37 PM
Project Twincharged SVT Focus CHIBULLSAN General Forced Induction 97 04-22-2010 10:24 PM
*feeler* 2001 Rs Look Project Show/ Race Focus! sstfocus Archive 4 06-11-2007 02:09 AM
Will the REAL Focus ST please stand up? flat 4 Ford Focus & General Car Chat 11 02-28-2005 06:40 PM
