$0 Thunder Throttle - Official DIY & Details - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-19-2009, 06:01 PM   #71
tb1999
tb1999's Avatar
Fan#: 44261
What I Drive: '05 ZX3 D2.3 & '03 Jag S-TYPE 4.2L
Points 24,620, Level 95
Points: 24,620, Level: 95 Points: 24,620, Level: 95 Points: 24,620, Level: 95
Level Up 27% Completed
FF Reputation: 47 tb1999 Great Standing Member
Buy-Sell-Trade Rating: (7)
Originally Posted by gonefhsn View Post
I had this problem too Evan, so I reverted back to the stock set up, I also popped a code for higher then expected rpms
Can you confirm the steps done to set-up the base throttle stop on the car?
And did you do the battery reset to allow the vehicle to relearn the idle/TPS adaptive values?
What was the DTC #?
I'm thinkning that if you had too much throttle angle and RPM too high with IAC disconnected, then the IAC motor will not have enough range to keep idle RPM's on target.
Originally Posted by warneej View Post
my brain hurts.
i played around with mine some more today...got it to run better with the IAC connected but it still pulls off throttle and revs randomly..like i'll pull up to a stop light out of gear (this isn't a new problem since the TB) and it'll be at idle and right before I stop it'll rev up to 2k and then slowly come back down...its really odd.
Evan,
You might need to have your cal reviewed for the dashpot strategy.
There is a "dashpot preposition" setting in the CAL that controls where the IAC motor will go to for a "starting point" upon initial "coast down" before it ratchets down the RPM back down to idle.
If your engine makes more HP and is more efficient than stock, then this value may need to be reduced, so it does not flare up when coasting down to a stop. This is when the dashpot strategy kicks in, and if the preposition value is too high, you might get a flare like that.
Then there are also values to adjust "decay rates" etc which control how quickly the CAL will drop RPM from the preposition to the desired idle PRM.
Too slow of a decay rate, and the throttle feels like it's hanging, too fast of a decay rate, and it can feel like it's trying to stall.
These factors also come into play when you have a very light flywheel.
You would want a slower decay rate to keep the revs from dropping to fast since the reduced flywheel mass has less inertia.
When I was messing with my calibration, I played around with this a little since a have a slightly lighter steel flywheel, but mainly to get a slightly quicker decay rate so I can get more enigne braking and rotation on tight turns when I want it.
Since I have the SCT pro-racer package, I get to swap and adjust cals all I want, so my street, autoX and road race cals will have subtle changes to things like this.
213 whp / 160 wtq D23 NA with stock intake and TB.
Inventor of "The $0 Thunder Throttle" & "Focuzdax-7" brake swap.
I like the same qualities in women and pistons; Lightweight, fast, and with the smallest skirts possible...
tb1999 is offline
Old 02-19-2009, 07:22 PM   #72
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
I hate you
my idle strategy is &*^%*'d. needs overhauling. MTX swap really does a number on load at idle.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 03-24-2009, 03:02 AM   #73
TarmacterroR
TarmacterroR's Avatar
Fan#: 57714
What I Drive: 2004 silver zx3
Points 145, Level 2
Points: 145, Level: 2 Points: 145, Level: 2 Points: 145, Level: 2
Level Up 90% Completed
FF Reputation: 1 TarmacterroR Good Standing Member
well im convinced!! im pulling out my TB tomorrow morning and doin it up during my downtime and lunchbreak at work!! ill try and post results tomorrow night...
TarmacterroR is offline
Old 03-24-2009, 09:29 AM   #74
NemesisEnforcer
Force-Powered Focus
NemesisEnforcer's Avatar
Fan#: 48598
What I Drive: LIQUID GRAY 2005 ST
Points 18,461, Level 86
Points: 18,461, Level: 86 Points: 18,461, Level: 86 Points: 18,461, Level: 86
Level Up 23% Completed
FF Reputation: 352 NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member
id rec. having a dremel handy...file down the ridge
GIVE DUE REP!! ST Crew #78 /Duratec Crew #91
Go Pats!! Go Green!! Go Sox!! Go B's!
Seeker of Wisdom, LG Crew #1
Resident Sith Lord & Jedi Master, MMA
Thx to those in the military.
NemesisEnforcer is offline
Old 03-24-2009, 11:34 AM   #75
TarmacterroR
Fan#: 57714
Points 145, Level 2
Yea i was planning on doin that, i might also try to make the throttle plate thinner all together
Old 03-24-2009, 02:42 PM   #76
NemesisEnforcer
Force-Powered Focus
Fan#: 48598
oh, u can do that...but BE CAREFUL. i dremeled right through.
Old 03-24-2009, 02:47 PM   #77
focusboy5
focusboy5's Avatar
Fan#: 50002
What I Drive: Four Wheels
Points 8,328, Level 61
Points: 8,328, Level: 61 Points: 8,328, Level: 61 Points: 8,328, Level: 61
Level Up 60% Completed
FF Reputation: 31 focusboy5 Great Standing Member
Buy-Sell-Trade Rating: (13)
I would rec. an extra TB...just in case...
focusboy5 is offline
Old 03-24-2009, 11:01 PM   #78
TarmacterroR
Fan#: 57714
Points 145, Level 2
well its in!! it only took an hour too, it went very smooth. I dremeled the ducktail a little bit to round off the edge, but i was a little too sketched out to try and go much further than that... It made an awesome difference too! I dont have to give it as much heel during rev matching before a corner and corner exit acceleration is great! The response gain is great just from doing that small change, it also solved the rough idle problem i had! its idles very smooth now, thank you very much for the idea tb1999!! It is great, ill post a pic of it within the next few minutes in my gallery
Old 03-24-2009, 11:41 PM   #79
TarmacterroR
Fan#: 57714
Points 145, Level 2
*pics pending approval*
Old 03-25-2009, 09:07 AM   #80
warneej
BodyKits=PantiesDrop
warneej's Avatar
Fan#: 20372
What I Drive: 04 ZX3 D23E-10SES Sedan-12 Ti Hatch
Points 32,500, Level 100
Points: 32,500, Level: 100 Points: 32,500, Level: 100 Points: 32,500, Level: 100
Level Up 0% Completed
FF Reputation: 201 warneej Excellent Standing Member warneej Excellent Standing Member warneej Excellent Standing Member
Buy-Sell-Trade Rating: (12)
pics are up. blurry but up.
glad you like it
Disciple of the "Push harder, suck less" school of autocross.
173.4whp
gump
crew #6
warneej is online now
Similar Threads
How are people cleaning their throttle bodies? drjkel ZETEC Performance (2000-2004) 14 12-18-2012 03:02 AM
How to: BDR Throttle Body collective2 SPI Performance (2000-2004) 9 07-30-2008 11:05 PM
For Sale: 05-07 2.3L Throttle body and Throttle Position Sensor afraziaaaa Archive 3 12-03-2007 08:47 PM
BBK Throttle Bodies Do Not Seem to Be An Option biketcher SVT Performance (2002-2004) 5 12-02-2004 12:37 PM
Problem (?) after Volant & throttle body install pvjhawk ZETEC Performance (2000-2004) 5 06-16-2004 12:17 AM
