$0 Thunder Throttle - Official DIY & Details - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-01-2009, 10:42 PM   #21
tb1999
tb1999's Avatar
Fan#: 44261
What I Drive: '05 ZX3 D2.3 & '03 Jag S-TYPE 4.2L
Points 24,560, Level 95
Points: 24,560, Level: 95 Points: 24,560, Level: 95 Points: 24,560, Level: 95
Level Up 21% Completed
FF Reputation: 47 tb1999 Great Standing Member
Buy-Sell-Trade Rating: (7)
Ok
Originally Posted by warneej View Post
i find that the car runs much better without it. Keep in mind my other modifications. Now it revs down between shifts and doesn't stall at idle. It also still idles at my programmed 850rpm idle without it.
Seems like it runs like a normal car now...
Then discuss it with Tom, he knows your car and your cal and would understand your situation better.
BTW, how is it for WOT?
No problems or restricted power?
I dont expect any, but with your mods I was just curious how it feels at WOT.
213 whp / 160 wtq D23 NA with stock intake and TB.
Inventor of "The $0 Thunder Throttle" & "Focuzdax-7" brake swap.
I like the same qualities in women and pistons; Lightweight, fast, and with the smallest skirts possible...
tb1999 is online now
Old 02-01-2009, 10:56 PM   #22
warneej
BodyKits=PantiesDrop
warneej's Avatar
Fan#: 20372
What I Drive: 04 ZX3 D23E-10SES Sedan-12 Ti Hatch
Points 32,487, Level 100
Points: 32,487, Level: 100 Points: 32,487, Level: 100 Points: 32,487, Level: 100
Level Up 0% Completed
FF Reputation: 201 warneej Excellent Standing Member warneej Excellent Standing Member warneej Excellent Standing Member
Buy-Sell-Trade Rating: (12)
doesn't feel any different at WOT honestly, except the whistling is gone.
the biggest thing is that it doesn't bog if i'm say rolling at 2k in a gear and punch it, like it used to...
Disciple of the "Push harder, suck less" school of autocross.
173.4whp
gump
crew #6
warneej is online now
Old 02-01-2009, 11:20 PM   #23
N2O Focus
N2O Focus's Avatar
Fan#: 37645
What I Drive: 2004 Yellow Saleen Focus ZX3
FF Reputation: 53 N2O Focus Excellent Standing Member
Buy-Sell-Trade Rating: (9)
Wouldnt thet reversed TB plate cause air flow impedence? Since the back side, now on the front, is not smooth.
Who Rides The Short Bus?
Originally Posted by the_07ninja View Post
my car's weight is 2546lb w/ me in the car and some crap in my pants.
N2O Focus is offline
Old 02-01-2009, 11:34 PM   #24
tb1999
tb1999's Avatar
Fan#: 44261
Can't say for sure......
I never went to engineering school, maybe someone on the forum has.
However it is the same plate in the same bore, just different direction.
So the only effect would be where the turbulence occurs, on entry or exit.
When you use a formula to calculate the coefficient of drag for a vehicle, the formula only cares about the frontal area of the vehicle, not the shape of the vehicle's profile.
A "brick" with 25 SQ FT of frontal area produces the same drag as a 25 Sq Ft "wedge".
Do I have this right mr engineers out there? Or have I made an incorrect assumption?
Old 02-01-2009, 11:50 PM   #25
ehancock
un1corn
ehancock's Avatar
Fan#: 53353
What I Drive: 2004 Twilight Blue D23 ZX5
FF Reputation: 14 ehancock Great Standing Member
That's the main reason i didn't do this to mine. I'm no engineer but it definitely does look like it might cause issues. I just bought a used FC throttle body.
Don't get me wrong, this looks like a great budget mod. I'm sure someone who's smarter than I could enlighten us about it.
ehancock is offline
Old 02-02-2009, 12:05 AM   #26
tb1999
tb1999's Avatar
Fan#: 44261
I'm not the kind of person that likes to speculate or guess.
The first review of this mod seems to indicate a home run, and I'm interested to see more feedback from others that have tried it, but let's not turn this into a theoretical debate of airflow principles by non-experts, including myself.
Although I do believe what I said about calculating drag co-efficients is accurate.
If we were disturbing airflow ahead of the MAF that would clearly be a problem.
Or if this were a carbureted situation, then disturbing or modifying airflow in the carbs would be a problem.
But nothing occurs in the throttle body of a Fuel Injected engine but the control of total volume entering the cylinders. The aerodynamics of the leading edge of the throttle plate is insignificant, it not like a spoiler or wing that needs to have airflow over the pieces in a certain direction etc.
IS THERE AN ENGINEER IN THE HOUSE!!!!
Old 02-02-2009, 12:12 AM   #27
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
thats correct
all bets are off once the air gets to the IM. it really makes no difference once you get to the throttle plate. At that point, laminar flow is next to impossible until you get to the ports, and even then its a challenge since the air is taking heat on from the head (convective cooling anyone?). The plenum is generally thought of as a bathtub of air from which the engine siphons what it needs. Its not usually a place where flow comes into play, unless you are maxing out the plenum.
at WOT there will clearly be no difference at all because both sides of the throttle are still equally exposed
where flow comes into play is all of this "path of least resistance" junk (engineers dont really use that way of thinking, it tends to get you in trouble) where if you create locally higher pressure on the leading edge of the plate you could increase the wall friction and promote turbulence
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 02-02-2009, 12:22 AM   #28
tb1999
tb1999's Avatar
Fan#: 44261
^ thanks!
Rep sent!
Old 02-02-2009, 10:39 AM   #29
NemesisEnforcer
Force-Powered Focus
NemesisEnforcer's Avatar
Fan#: 48598
What I Drive: LIQUID GRAY 2005 ST
Points 18,461, Level 86
Points: 18,461, Level: 86 Points: 18,461, Level: 86 Points: 18,461, Level: 86
Level Up 23% Completed
FF Reputation: 352 NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member
this is the most interesting to me. i hate being at 55/60, then floor it in 5th, and........blah.
GIVE DUE REP!! ST Crew #78 /Duratec Crew #91
Go Pats!! Go Green!! Go Sox!! Go B's!
Seeker of Wisdom, LG Crew #1
Resident Sith Lord & Jedi Master, MMA
Thx to those in the military.
NemesisEnforcer is offline
Old 02-02-2009, 09:34 PM   #30
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Well direct drive is 4th gear and with 5th gear there is no torque multiplication taking place anymore (hence overdrive) and will always bog unless your up in the triple digits or making insane amounts of power. In fact its not good practice to really floor it in 5th unless you have the speed built up. Its hard on the transmission.
jetrinka is offline
Similar Threads
How are people cleaning their throttle bodies? drjkel ZETEC Performance (2000-2004) 14 12-18-2012 03:02 AM
How to: BDR Throttle Body collective2 SPI Performance (2000-2004) 9 07-30-2008 11:05 PM
For Sale: 05-07 2.3L Throttle body and Throttle Position Sensor afraziaaaa Archive 3 12-03-2007 08:47 PM
BBK Throttle Bodies Do Not Seem to Be An Option biketcher SVT Performance (2002-2004) 5 12-02-2004 12:37 PM
Problem (?) after Volant & throttle body install pvjhawk ZETEC Performance (2000-2004) 5 06-16-2004 12:17 AM
