$0 Thunder Throttle - Official DIY & Details - Page 15 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-26-2011, 11:26 PM   #141
Slkfucusdvr
Slkfucusdvr's Avatar
Fan#: 90401
What I Drive: 2005 ZX3 2.0L Black
FF Reputation: 1 Slkfucusdvr Good Standing Member
Awesome thread and your enginuity is very admirable but what seems to be the problem with the CFM TB? Every review I read on the TB says "it was an awesome upgrade" or "didnt run into one problem and the engine runs great". Is it a tuning issue that can be worked out or is it really just "to much" air going through the stock MAF?
Giddyup focus.... Giddyup...
Slkfucusdvr is offline
Old 10-26-2011, 11:35 PM   #142
Slkfucusdvr
Fan#: 90401
NVM, re-read the inicial thread and better understand now. Thanks!
Old 10-30-2011, 02:59 PM   #143
pj96ss
Fan#: 84020
What I Drive: 2004 Black Ford F250
Points 353, Level 7
Points: 353, Level: 7 Points: 353, Level: 7 Points: 353, Level: 7
Level Up 6% Completed
FF Reputation: 1 pj96ss Good Standing Member
Great info!!!
pj96ss is offline
Old 07-21-2013, 03:31 AM   #144
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
What I Drive: blue sub #6
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 3%
FF Reputation: 10 Paladin Great Standing Member
am i the first to do this on an svt? i stubled across this and gave it a shot. i ahve some cleaning / adjusting to do. but i'm liking he feel.
MR. freaking negative
i'm not an enthusiast...... the internets told me.
Paladin is offline
Old 03-01-2014, 05:15 PM   #145
JoeyK
JoeyK's Avatar
Fan#: 74299
What I Drive: 07, Metalic Grey, ZX5 SES
Points 247, Level 4
Points: 247, Level: 4 Points: 247, Level: 4 Points: 247, Level: 4
Level Up 94% Completed
FF Reputation: 1 JoeyK Good Standing Member
Just found a extra for sell, torn apart and back together soon. Though my hollow screw tips broke. Ill be sure to add some extra lock tight.
2007 Liquid Grey 5 Door SES
JoeyK is offline
Old 12-30-2014, 06:20 PM   #146
Ak-Focus
Fan#: 86672
What I Drive: 2005 Silver ZX3
Points 188, Level 3
Points: 188, Level: 3 Points: 188, Level: 3 Points: 188, Level: 3
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 4%
FF Reputation: 1 Ak-Focus Good Standing Member
Works great! Four observations of interest.
I did this recently -- and it works great. Four things of interest:
1. Here is a third "trick" regarding the epoxy seal over the idle adjustment screw (see tb1999's other two tricks in post #5). If you can't get all of the epoxy removed, but can get your torx bit part way into the screwhead, heat the screw by sticking a small-tip soldering iron into the screwhead. Keep your finger on the black plastic, nearby, and when it start feeling pretty hot the epoxy will be soft enough to turn the screw. You may need to repeat the heating a time or two.
My screw was totally stuck. Without the heat I couldn't budge the screw, even with a small vise-grips on the stub end (unthreaded part) of the screw.
2. As mentioned by others above, I have avoided replacing the epoxy; instead using a machine screw with lock nut. The diameter is 5mm, and a length of 20 or 30mm is fine.
3. This is a fast job (less than an hour), and is a good opportunity for some important preventive maintenance. This is the second time I have removed my throttle body. Two years ago the throttle totally stuck, and even a lot of force on the throttle pedal wouldn't break it loose. The car had worked fine when I parked it, and when I came out of a store it stuck solid. The problem was carbon loading on the throttle plate. Now, two years later there was a lot of carbon build-up and the action was a bit sticky in the closed position. So, this modification probably has saved me another incident, and serves as a reminder to do this PM periodically.
4. There was an earlier question about the effect of this modification on mileage. I can report that at worst there is no effect unless it makes your driving more aggressive. However, it has helped my mileage because the throttle action is more predictable, am careful with the pedal, and it aids some of my hypermile techniques.
Ak-Focus is offline
Old 12-30-2014, 07:02 PM   #147
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,844, Level 100
Points: 51,844, Level: 100 Points: 51,844, Level: 100 Points: 51,844, Level: 100
Level Up 0% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
You guys crack me up with this LOL
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Similar Threads
How are people cleaning their throttle bodies? drjkel ZETEC Performance (2000-2004) 14 12-18-2012 03:02 AM
How to: BDR Throttle Body collective2 SPI Performance (2000-2004) 9 07-30-2008 11:05 PM
For Sale: 05-07 2.3L Throttle body and Throttle Position Sensor afraziaaaa Archive 3 12-03-2007 08:47 PM
BBK Throttle Bodies Do Not Seem to Be An Option biketcher SVT Performance (2002-2004) 5 12-02-2004 12:37 PM
Problem (?) after Volant & throttle body install pvjhawk ZETEC Performance (2000-2004) 5 06-16-2004 12:17 AM
