Help with SVT rear caliper removal - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-24-2009, 03:16 PM   #1
racer1735
racer1735's Avatar
Fan#: 13782
What I Drive: 2004 Sonic Blue SVT
FF Reputation: 5 racer1735 Good Standing Member
Question Help with SVT rear caliper removal
Swapping brake pads and cleaning calipers on an '04 SVT. No problem with the front spring and when I got to the rear, I was expecting to see a similar setup. Obviously, its a different caliper and setup. How do I remove the caliper from the spindle? There are two bolts which face 'inward' on the rear of the caliper (appear to go through the entire caliper. There is also a bolt or two which are more towards the center of the caliper. What is the method for removal? And, I'm guessing the pads are held in by tabs on the pad themselves?
When you've run out of mods, it's time to get something new.
racer1735 is offline
Old 01-24-2009, 03:43 PM   #2
UnFocusedST
Fear the TurboSnail!
UnFocusedST's Avatar
Fan#: 40342
What I Drive: 2013 Performance Blue Focus ST
Points 6,367, Level 52
Points: 6,367, Level: 52 Points: 6,367, Level: 52 Points: 6,367, Level: 52
Level Up 9% Completed
Forum Activity 10%
FF Reputation: 13 UnFocusedST Great Standing Member
Buy-Sell-Trade Rating: (14)
There are two bolts on the caliper. They should be the only bots that go through the spindles as well. The pads I believe are just on there. I don't remember what holds them on.
Team Duratec #17
Hatch Nation #17
Midwest Crew #55
Boosted Crew #118
UnFocusedST is offline
Old 01-24-2009, 08:56 PM   #3
racer1735
racer1735's Avatar
Fan#: 13782
The ones I'm seeing are 'regular' bolts, not allen or torx, and they aren't covered by a rubber cover.
Old 01-25-2009, 09:31 AM   #4
eisenhauer01
eisenhauer01's Avatar
Fan#: 62214
What I Drive: 2003 Infra Red SVT ZX3
FF Reputation: 1 eisenhauer01 Good Standing Member
I believe what you are talking about is this:
Farthest away from the caliper, there are the two outside bolts that actually hold it on. Those bolts go through the caliper and into 2 nuts (these are the slides as well). these nuts sometimes spin when you try to loosen the caliper bolts. You have to hold them with a wrench as you take the caliper bolts out. now that you have those 2 bolts out, the caliper should come off, and the caliper bracket should be all that is left with the rotor on the car. 2 more bolts hold the caliper bracket on if you needed to take it off.
eisenhauer01 is offline
Old 01-25-2009, 09:45 AM   #5
ken6x6
ken6x6's Avatar
Fan#: 31100
What I Drive: 03 Black SVTF
Points 3,466, Level 36
Points: 3,466, Level: 36 Points: 3,466, Level: 36 Points: 3,466, Level: 36
Level Up 78% Completed
FF Reputation: 2 ken6x6 Good Standing Member
Buy-Sell-Trade Rating: (7)
remember to screw in the rear cylinders, unlike the fronts that just get pushed in.
03 SVTF #3804, full suspension, CM FX300, Torsen LSD, no cat, dual exhaust, Tom's tune. 167whp 154 wtq (dyno jet) and some other stuff. dyno- http://www.youtube.com/user/ken6x6#p/a/u/1/cKH4FX7c9L4
ken6x6 is offline
Similar Threads
The Ford Focus - General History and Information S2 Ford Focus & General Car Chat 1 11-14-2008 03:04 PM
Rear caliper removal? alecseborp Wheels & Tires 0 11-07-2007 01:20 PM
SVT rear dropout susp. focus'N'SHO Archive 1 01-25-2007 10:12 AM
SVT Big Brakes - 2 piston caliper SVT ewx ca SVT Performance (2002-2004) 3 07-08-2004 05:56 PM
