Need help with sway bar end links. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-22-2009, 10:20 PM   #1
Adami
Fan#: 57713
What I Drive: 2005 silver zx3 se
FF Reputation: 1 Adami Good Standing Member
Hi I am new to the board and just finished having the Ford Dynamic suspension put on my 05 zx3. Works great but I now have a clunking that we have traced to the end links, the kit did not come with upgraded ones. Does anyone know where I could get some that would fix the problem?
Thanks in advance, Adam
Adami is offline
Old 01-22-2009, 10:41 PM   #2
toeycrack
toeycrack's Avatar
Fan#: 38332
What I Drive: 03 zx3, name "TRISH"
FF Reputation: 9 toeycrack Good Standing Member
Buy-Sell-Trade Rating: (18)
does it go clunk on every bounce/ bump?
if so, then its the endlink that isn't tight, tighten them up more, and take a test drive.
if you lookin on upgrading them to poly end link, try http://focus.c-f-m.com/index.asp?Pag...&Category=1427
depending on your size of the bar, u'll find it ranging from 20mm to 22mm
mine use to clunk after i installed my rear bar.
my focus is for sale....
toeycrack is offline
Old 01-22-2009, 11:26 PM   #3
Adami
Fan#: 57713
Thanks
They are tight for sure so I think I replace them, thank a ton for the link.
Adam
Adami is offline
Old 01-23-2009, 12:05 AM   #4
toeycrack
toeycrack's Avatar
Fan#: 38332
make sure you bushing on ur endlink are in the right order.... or eles they won't have clearance from the sub frame.
forgot to mention that
Old 01-24-2009, 10:23 AM   #5
amrcni4
amrcni4's Avatar
Fan#: 62083
What I Drive: 2001 Silver ZX3
FF Reputation: 1 amrcni4 Good Standing Member
The sway bar link bushings should be compressed a bit when installed. You could measure quickly the components in the link to make sure that when the nut is fully tightened that bushings are compressed.
Also make sure the "noses" of the grommets are isolating the bolt from the center of the hole in the control arm and sway bar pad. You may want to try to install with the vehicle on the ground at "ride height". This will allow everything to line up better when the link is tightened.
amrcni4 is offline
Old 01-24-2009, 01:00 PM   #6
toeycrack
toeycrack's Avatar
Fan#: 38332
true, very true.... forgot to mention to tighten it up while at rides height...
Similar Threads
Moog Sway bar end links whynotthinkwhynot Wheels & Tires 5 10-21-2008 11:24 PM
Sway bar end links - Torque specs?? rescuer265 General Technical Chat 3 09-16-2007 08:37 PM
WTB: sway bar end links grandskam Archive 3 08-29-2007 10:35 PM
For Sale: A brand new pair of front sway bar links! Fits all models! Moog! with pics! racefocus Archive 3 05-01-2007 12:15 AM
REAR(?) sway bar end links??? socrates General Technical Chat 14 01-11-2007 06:14 PM
