Is it possible to identify a tuned ECU? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-20-2009, 03:20 PM   #1
GreggPDX
Fan#: 59125
What I Drive: 2003 Turbo 2.3l ZX3
FF Reputation: 1 GreggPDX Good Standing Member
I have an SVTF ECU that is supposed to have the Jackson Racing Supercharger Big Boost Kit(BBK) tune on it. The problem is that I'm not sure. What would be the easiest/cheapest way to verify the tune? I presume that the SCT Pro Racer package could view the tune and look for parameters associated with BBK, but I don't have the software.
Would a shop with SCT tuning software be able to do it relatively easy? Any other ideas about how to check?
Gregg
GreggPDX is offline
Old 01-20-2009, 05:35 PM   #2
Blivit
Blivit's Avatar
Fan#: 51292
What I Drive: 2013 ST
Points 2,287, Level 28
Points: 2,287, Level: 28 Points: 2,287, Level: 28 Points: 2,287, Level: 28
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 118 Blivit Excellent Standing Member Blivit Excellent Standing Member
Gregg
The prp will not be able to view the tune, nor will any sct dealer.
There are ways, but nothing that any of our customers or dealers can do.
Blivit is offline
Old 01-20-2009, 06:45 PM   #3
GreggPDX
Fan#: 59125
If I had PRP, wouldn't I be able to look at the injector settings or timing tables and see if they were different from stock? For example, the BBK comes with 42lb injectors, so if the tune is setup for 42's, then that would indicate the ECU probably had the BBK tune.
Gregg
GreggPDX is offline
Old 01-20-2009, 06:54 PM   #4
Blivit
Blivit's Avatar
Fan#: 51292
Gregg
No, that is not how the prp works.
Having a pro racer package gives you access to a particular processor code. You open that processor code in the software (which is a factory ford calibration) make your tune changes (fuel tables, spark, whatever) save the file on your computer then load the tune to one of our flash devices and flash your vehicle. During the flash process, the device saves whatever is in the vehicle and replaces that with the tune file you have created.
You cannot see or modify the stock file that is uploaded to the device. It is there to allow you to return your vehicle to stock (whatever that may be) if needed.
Blivit is offline
Old 01-20-2009, 07:07 PM   #5
GreggPDX
Fan#: 59125
That's very interesting. Is there a technical reason for this, or is it done to prevent "reverse engineering" someone else's tune?
GreggPDX is offline
Old 01-20-2009, 07:11 PM   #6
Blivit
Blivit's Avatar
Fan#: 51292
Yes that is part of the reason it is done that way.
Blivit is offline
Old 01-20-2009, 07:24 PM   #7
GreggPDX
Fan#: 59125
Okay, so what about a bit more "crude" test. If I install this ECU with my stock injectors, but the ECU is setup for 42's, I assume it would run very badly, way too rich. I realize this is not great for the engine, but it should be a quick way to verify if the tune is not stock.
Thoughts?
GreggPDX is offline
Old 01-20-2009, 07:37 PM   #8
Blivit
Blivit's Avatar
Fan#: 51292
Thoughts?
You could do that....if you can bypass PATS. You can't just install another processor in your car with PATS.
Blivit is offline
Old 01-20-2009, 07:40 PM   #9
GreggPDX
Fan#: 59125
The ECU has been PATS reset, so I can install it and associate my keys when I'm ready. That brings up another question, can PRP reset PATS?
GreggPDX is offline
Old 01-20-2009, 07:45 PM   #10
Blivit
Blivit's Avatar
Fan#: 51292
On most vehicles that have PATS it can but unfortunately the SVT focus is not one of them.
Blivit is offline
Similar Threads
Quick ECU question mstng46 Focus-Power Tuning 0 10-27-2008 05:34 PM
ECU Location? pdxgearhead General Technical Chat 2 02-28-2007 01:39 PM
Stand aloin or the focus ecu? FOCUS ZTS General Forced Induction 16 10-23-2006 12:56 PM
For Sale: SCT Xcal 1 tuned for zyf5 ecu code BlackNRed01 Archive 9 08-02-2006 08:00 AM
Stand Alone ECU Question.. pls help.. ozan ZETEC Performance (2000-2004) 20 06-29-2006 09:49 AM
