when buying speakers... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-14-2009, 03:57 AM   #1
toeycrack
toeycrack's Avatar
Fan#: 38332
What I Drive: 03 zx3, name "TRISH"
FF Reputation: 9 toeycrack Good Standing Member
Buy-Sell-Trade Rating: (18)
hey guys, when buying speakers... is it a good idea to keep it in the same brand/model for the front n rear? or is mixing up a good thing too?
im not sure on the speakers.. im trying to put together a front/rear speaker, with a amp.
for speakers, im lookin at the Polk Audio MM571
  • 5"x7" 2-way speakers (pair)
  • woven honeycomb glass fiber composite woofer cone with butyl rubber surround
  • 1" silk composite dome tweeter
  • certified for marine use
  • 2.7-ohm impedance for extra power (compatible with all factory or aftermarket car stereos)
  • power range: 15-90 watts RMS (200 watts peak power)
  • frequency response: 38-25,000 Hz
  • sensitivity: 92 dB @ 2.83 V
  • top-mount depth: 2-5/8"
im thinking on staying with the same speakers for front n rear... would those be a good combo or should i mix them up???
------ for a amp, im not sure what kind of specs im looking for. someone help me out.... the amp is only going to be running to the front n rear speakers.... and tweeters too if they supposed to be hooked up to em.
all help will be thankED!!!
-Bunna
my focus is for sale....
toeycrack is offline
Old 01-14-2009, 07:47 AM   #2
selfguided
selfguided's Avatar
Fan#: 49057
What I Drive: SVT3
FF Reputation: 4 selfguided Good Standing Member
Buy-Sell-Trade Rating: (11)
definitely stay with the same brand! they will be 'voice matched'. as far as amplifier, without getting into specific brands, stay with a leading manufacturer. you should be fine with 50-75x4 RMS pushing them. i would stick with a class 'AB' amp for best sound quality. class 'D' if space/heat is an issue.
selfguided is offline
Old 01-14-2009, 12:50 PM   #3
skikid89
Fan#: 60687
What I Drive: 2003 CD Silver Blaupunkt ZX3
FF Reputation: 6 skikid89 Good Standing Member
Buy-Sell-Trade Rating: (4)
...x2^^^^^
skikid89 is offline
Old 01-14-2009, 02:17 PM   #4
jmanpc
jmanpc's Avatar
Fan#: 61602
What I Drive: 2007 Red ZX4
FF Reputation: 5 jmanpc Good Standing Member
I would personally recommend getting one nice pair of components for the front, and amp them with a good 100+ watts of good clean power. Also, deaden your front doors for improved midbass response and a reduction in road noise and rattles.
One potent pair of speakers on a budget I would recommend is the Image Dynamics CTX65CS. While I've never heard them personally, on the car audio forum which I frequent, they are getting rave reviews.
http://www.woofersetc.com/index.cfm?...roduct_ID=6201
As far as power goes, there are several options depending on how much you're willing to spend. You can get an amp for as little as $45 from Profile (www.profileusa.com, go to their online store, look at the 400SX). Other budget options include Hifonics or Cadence (www.cadencestore.com, their outlet section is fantastic)
I highly recommend Second Skin deadening (www.secondskinaudio). In all my time installing, it's the best I have come across. Ant, the owner of SS, is a really cool dude who will personally help you decide what products you need. For a bit less, check out RAAMat (www.raamaudio.com). It's a very effective butyl deadener, but is a bit sloppier during install. I'd avoid FatMat, because its just crappy asphalt roof patching material. Don't believe their hype. eDead is alright, but Ben Milne, the owner of eDuh is a pretty crappy dude with overrated products. I pretty much just don't trust their business ethics.
Anyhow, ranting aside and back to the topic at hand, I like to recommend that you spend a majority of your speaker budget on your front speakers; after all that's where you are. For the time being, if I were you, I'd get nice front speakers, keep the stockers in the rear and just keep them turned down. Screw whoever is sitting in the back
jmanpc is offline
Old 01-14-2009, 02:48 PM   #5
zlaja
Fan#: 52919
What I Drive: 2003 While LX Sedan
FF Reputation: -11 zlaja Needs To Improve
id probably stick with the same speakers all around, though it would be interesting to put 6x9s in the rear (dont know if they fit)
the reason i say this is that i believe you could get more low end with them
zlaja is offline
Old 01-14-2009, 02:54 PM   #6
svtguy88
svtguy88's Avatar
Fan#: 13476
What I Drive: 2003 Infra Red SVT
Points 8,660, Level 62
Points: 8,660, Level: 62 Points: 8,660, Level: 62 Points: 8,660, Level: 62
Level Up 70% Completed
FF Reputation: 17 svtguy88 Great Standing Member
^^^You'd have to cut a big hole to get a 6x9 back there, and even then you'd have clearance issues, I think.
I would have to agree with jmanpc. Get one good set of components up from, supply them with about 100 watts RMS (each) and enjoy.
However, are you going to have a sub at all? If not, you may want some rear speakers, just to give some added sound. If you are running a sub, forget the rears (as long as you don't care how good it sounds in the back seat).
svtguy88 is offline
Old 01-14-2009, 04:49 PM   #7
jmanpc
jmanpc's Avatar
Fan#: 61602
Don't mess around with putting bynines in. While the extra cone area is enticing, it's not worth hacking up your car. If you're serious about getting extra oomph in the bass department without putting a subwoofer in, get a pair of 6.5" freeair midbasses or subwoofers, make some adapter rings, and put them in the rear.
Speakers such as these:
http://www.parts-express.com/pe/show...number=295-305
or
http://www.parts-express.com/pe/show...number=264-832
www.partsexpress.com and www.madisound.com are your friends.
jmanpc is offline
Old 01-14-2009, 05:50 PM   #8
kenzx3
Say NO to FRPP Drops
Fan#: 42651
What I Drive: '00 ZX3, '03 ZX3, '07 ZX3
FF Reputation: 125 kenzx3 Excellent Standing Member kenzx3 Excellent Standing Member
Buy-Sell-Trade Rating: (49)
6x9's in the rear will not fit without some modification back there. I have seen it done but remember to look at the depth of the 6x9's to see if they will fit back there before modding as some 6x9's may be too deep
and to toeycrack, keep the same speakers front to rear, you don't want to be mixing brands or even models.
kenzx3 is offline
Old 01-14-2009, 06:59 PM   #9
hypnoticracing
Fan#: 51709
What I Drive: 2003 Focus Sedan Zetec 5 Spd
FF Reputation: 13 hypnoticracing Great Standing Member
Buy-Sell-Trade Rating: (19)
i have a set of memphis pr 5x7s and love the sound, they are hooked to a memphis 300x4 amp
03 SE Liquid Grey zetec 5 spd
07 F150 FX2 Sport, White
Parting out the slammed sedan...
hypnoticracing is offline
Old 01-15-2009, 12:48 AM   #10
toeycrack
toeycrack's Avatar
Fan#: 38332
on a hatchy, what is the rear speaker size?? 5.25 inch?
Similar Threads
Questions about OEM 'upgrade' speakers shane_c Car Audio, SYNC, MyFord Touch & Electronics 3 02-23-2008 01:25 PM
Problem with stock speakers sjdwales Car Audio, SYNC, MyFord Touch & Electronics 9 01-31-2008 06:11 PM
Upgrading speakers, but nothing else??? DrkKnight614 Car Audio, SYNC, MyFord Touch & Electronics 3 04-01-2007 05:04 PM
OEM speakers impedance owensleon Car Audio, SYNC, MyFord Touch & Electronics 2 02-15-2007 03:36 PM
back speakers sound bad? three_X_Z Car Audio, SYNC, MyFord Touch & Electronics 7 09-24-2003 11:34 PM
