How-To: Focus Amplifier Install - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-05-2004, 12:29 PM   #1
Twofocused
Twofocused's Avatar
Fan#: 408
What I Drive: 84 Stang / 03 Focus SE / 04 F150 /
FF Reputation: 2 Twofocused Good Standing Member
Buy-Sell-Trade Rating: (4)
Good sticky, nice pics.
I found a easier way to run the amp power wire into the cabin. There is a small unused plug in the door jamb on both sides. It comes out behind the kick panels. The plug is far enough foreward so that the wire tucks into the fender and is out of the way of any moving parts. I will try and put up a pic later today. I like it because it doesnt require any drilling.
I ran my wire from the batt up through the top of the fender in the channel between the outer and inner fenders, through the door jamb plug and then like your sticky shows. My wires are 100% hidden and you cant even tell from under the hood that I added a amp. Looks very clean, the amp is under the driver seat. I gotta run and go buy bathroom accents for the new apartment ( not my choice for a day off ) but it keeps the peace......more later
Twofocused is offline
Old 07-05-2004, 01:23 PM   #2
sa_pyro_ne
sa_pyro_ne's Avatar
Fan#: 1437
What I Drive: 2000 Ranger V6 4.0L 4x4 XLT Ext Cab
FF Reputation: 4 sa_pyro_ne Good Standing Member
Thanks for the information. However, I was already aware of this method. I HIGHLY discourage anyone doing this. It is MUCH more prone to damge because it's exposed in the fender (lots of things can happen there such as flying rocks and possible weathering) and a lot of people then run it down the hood jam as seen in this http://www.jwardell.com/focus/amp.html which is a hazzard. That's why I discourage this method so greatly.
- Scott
sa_pyro_ne is offline
Old 07-07-2004, 08:44 PM   #3
Millertyme
Millertyme's Avatar
Fan#: 1992
What I Drive: 2003 Centennial PZEV
FF Reputation: 1 Millertyme Good Standing Member
if you have a duratec watch out where you drill for your power wire through the firewall... where pyro specified there are metal BREAK LINES.... just be careful.. i routed my powerwire between them... you just have to be careful when you drill..
'03 Centennial Edition ZTS, 2.3L MTX
Current mods: MM CAI, Crane Stage 2 Cams, Tint, Balance Shaft Removed, Borla 2.5" Exhaust, Draxas Header, Supertech 11.6:1 pistons, Supertech Valve springs and retainers
14.989 @ 92.96 MPH ~~*NEW*~~12/15/04 (before pistons and cams)
Millertyme is offline
Old 07-08-2004, 08:25 PM   #4
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: 77 F-250, 10 HHR, 08 Outlook
FF Reputation: 5 crazy_urn Good Standing Member
some of the pics posted do not appear to be of a focus... lol
the pics where you see the HU out of the dash doesnt look like any focus dash i have seen.
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
Old 07-08-2004, 08:46 PM   #5
sa_pyro_ne
sa_pyro_ne's Avatar
Fan#: 1437
crazy_urn: sorry, i forgot to add that note. they aren't all pictures from foci. i had to peice together pictures to get everything i needed since i don't have a focus anymore. some of the pictures are of a focus, one is of a ranger, and a few are from a taurus (the HU pictures are). if anyone has some clear pictures of the same thing in a focus i'll update it. otherwise, i don't think it affects the understanding of the installation so i'll just keep them up there.
Millertyme: thanks for the info, i added that info to the how-to.
- Scott
Old 07-09-2004, 07:16 PM   #6
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
dont worry bout the pics, i was just giving you a hard time. lol
thank you very much for the information and the time you spent on it.
Old 07-16-2004, 03:23 PM   #7
ZWZX3
Fan#: 10565
What I Drive: 2001 Midnight Blue ZX3
FF Reputation: 1 ZWZX3 Good Standing Member
Got a midnight blue ZX3 last week, and needed some help with stereo/amp installation. These forums saved my arse BIGTIME. Thanks!
ZWZX3 is offline
Old 02-28-2005, 10:46 PM   #8
bustabob454
Fan#: 19556
What I Drive: 2003 Ford Focus ZTS
FF Reputation: 1 bustabob454 Good Standing Member
I ve got a 2003 Ford Focus ZTS and Im tryin to install an amp and subs with the blankput mp3 player, i got the rca hooked up fine, tyme for tha power cable you said to drill through the clutch plate in doing that do you have to peal back the carpet? FYI ITS AN AUTOMATIC, and as far as runnin the cables to the back is it better to use the bottom trim pieces rather than the top?Thanx for any of your help
bustabob454 is offline
Old 02-28-2005, 11:29 PM   #9
sa_pyro_ne
sa_pyro_ne's Avatar
Fan#: 1437
Welcome to the forum! Yes, peel back the carpet and find the clutch plate as seen in the pictures. Use the bottom trim, it's a lot easier, just follow the guide and you should be okay.
- Scott
Old 03-10-2005, 04:26 AM   #10
postalservice14
Fan#: 19763
What I Drive: 2001 Red Ford Focus SE
FF Reputation: 1 postalservice14 Good Standing Member
Make sure the fuse holder is within 18" of the battery terminal.
Why do you have to have the fuse holder within 18" of the battery terminal?
John
postalservice14 is offline
Similar Threads
The Ultimate 03-09 Focus Thread, SUPER LARGE AMOUNTS OF INFO. honhon DURATEC Performance (2008-2011) 59 08-04-2013 11:41 PM
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
The Ford Focus - General History and Information S2 Ford Focus & General Car Chat 1 11-14-2008 03:04 PM
Soon to come, more SVT parts for your non-SVT Focus... myFordPerformance.com ZETEC Performance (2000-2004) 32 05-02-2004 05:31 PM
