New Water Pump Replacement HOW-TO w/ PICS - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-21-2013, 08:57 PM   #31
finalfantasy
Fan#: 86774
What I Drive: 2001 SE
Points 551, Level 11
Points: 551, Level: 11 Points: 551, Level: 11 Points: 551, Level: 11
Level Up 2% Completed
Forum Activity 8%
FF Reputation: 1 finalfantasy Good Standing Member
I didn't get bolts with the new pump, reused the old ones but the "pan" head seemed to cock slightly when torqued down...
finalfantasy is offline
Old 01-21-2014, 09:42 AM   #32
blazindave
Fan#: 78810
What I Drive: 2003 White ZX5
FF Reputation: 1 blazindave Good Standing Member
just wanted to add another thanks to this thread.
worth noting, as I've seen elsewhere across the internet, the water pump can be removed and reinstalled without pulling the motor mount and dropping the engine. It is tricky, and it only goes one way, but it can be done. I did it yesterday. Didn't have a torque wrench handy so didn't want to loosen the motor mount -- just took the 4 bolts out of the AC Compressor and hung it aside out of the way with a wire coathanger.
As has been mentioned, the trick to getting it out starts with flipping it 180 degrees so the impeller is pointing away from the engine block. Then you just have to rotate and twist it just right. It felt like one of those "magic trick" games where you try to free the ball from the cage and it will only come out one way... I can't really explain exactly how it's done, just be patient and keep trying. and then reverse it to get the new one in.
also, thanks to this thread I decided to go ahead and replace the overflow reservoir bottle - I had noticed that I was losing coolant, but pretty slowly... couldn't find any leaks around any hoses or around the thermostat housing, no cracks in the radiator, etc. After I took the old bottle out (which was yellow and really nasty looking down in there), I could see a couple of those hairline cracks on the very bottom of it.
blazindave is offline
Old 02-23-2014, 12:48 AM   #33
FoFo4Me
Fan#: 143969
What I Drive: 2000 Orange Red SE
FF Reputation: 1 FoFo4Me Good Standing Member
You know you rock, right??
I *knew* I was right and the auto parts guys are going to eat crow!! ;-)
I've been looking for this all over the 'Net, no diagrams for the DOHC engines with the water pump on the accessory belt!
Me, I've got the Guinea Pig model, 2000 and while I am glad I can work on it myself, it always helps to have the correct information!!!
FoFo4Me is offline
Old 11-14-2014, 12:52 PM   #34
tp156533
Fan#: 202449
What I Drive: 2001 Yellow ZX3
Points 4, Level 1
Points: 4, Level: 1 Points: 4, Level: 1 Points: 4, Level: 1
Level Up 7% Completed
FF Reputation: 1 tp156533 Good Standing Member
New Member first post
Hey guys new member here and first post. Had my 2001 ZX3 for about 1 1/2 years now and done a fair amount of rebuilding. I've decided it's time for this. Only reason I haven't done it yet is because I've been afraid of it.
Anyway, I've got a slow leak coming from somewhere and I changed (almost) all hoses this time last year. So I've got a few more to check before taking on this project. Am I only one who feels like this would be a great car if they didn't start falling apart at ~150k miles?
So thanks for this and everyone who has had input. It'll really help people who either can't or won't get rid of their old Foci.
tp156533 is offline
Old 02-21-2015, 11:58 PM   #35
Rryan2
Fan#: 223210
What I Drive: 2003 red svt
Points 4, Level 1
FF Reputation: 1 Rryan2 Good Standing Member
Aloha, new here...hello ?
Thanks for the helpful tips, I've gotten to the part where I pulled all the 4 bolts out of the pump, but the pump won't budge.
I've tried the classic tap with a hammer which has moved to a screw driver/pry bar and a 4# sledge. Any of you guys ever had a pump get stuck? My only other idea is to find a steel bar and drill holes so I can attach it to the pump.
Thanks!
Rryan2 is offline
Similar Threads
Focus 2002 Zetec - Water Pump Failure? stubee General Technical Chat 4 11-16-2008 06:02 AM
Just had timing belt and water pump changed now car is overheating?!?!? DanielW General Technical Chat 5 11-10-2008 10:37 PM
water pump problems officefocus General Technical Chat 1 06-25-2006 11:54 AM
Water pump clicking... Marko1962 General Technical Chat 9 07-03-2005 02:20 PM
