New Water Pump Replacement HOW-TO w/ PICS - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-07-2009, 07:10 PM   #1
Rabbitccc
Rabbitccc's Avatar
Fan#: 44508
What I Drive: 01 Blue SE / 09 Black Coupe SE
Points 8,638, Level 62
Points: 8,638, Level: 62 Points: 8,638, Level: 62 Points: 8,638, Level: 62
Level Up 63% Completed
FF Reputation: 28 Rabbitccc Great Standing Member
Buy-Sell-Trade Rating: (32)
Disclaimer:
I can't be responsible for any damages done to your car. I'm not an expert, I just was doing the work and had a camera handy. This is a guide and work should be done at your own risk.
grimple1-His original HOW-TO gave me enough info to get the job done. All of this how to is thanks to him.(Except the Pictures)
b16sir1991 A.K.A. Mike at Hilbish Ford-He gave me a great deal on a Motorcraft water pump, seal, and drive belt. Thanks Mike.
Tools Needed:
Jack
Jack Stands
Catch Pan
Cresent Wrench
8mm socket
10mm socket
15mm socket
18mm socket
How To:
1.Jack up the front of the car and place on jack stands.
2.Open the coolant resevoir cap and then loosen radiator drain plug w/ catch pan underneath.(It's on the back of the driver's side at the bottom of the radiator.
3.Take off coolant resevoir tank from frame (1 x 10mm).
4.Remove belt cover plastic from below (2x 10mm).
5.With a wood block and jack support the engine's oil pan.
6.Remove passenger side motor mount w/ engine FIRMLY supported (2 x 18mm ,3 15mm).
Another view
One w/ the mount removed
7.Remove bolts on Water Pump Pulley (3X 10mm wrench)
From up top
From underneath
One w/ the pulley off
8.With the pulley loose it should be able to be carefully pulled off and make the belt come loose, or you could use the belt tensioner.
9.Remove water pump bolts (4x 8mm)
10.Get the water pump out. This is the tricky part. Some people were saying they had to lower the engine on the jack to get the pump out and some were saying they also had to take the a/c compressor off.(4 x13??mm)All I had to do is turn the pump around and place the pulley side in the hole and then it kind of just fell out the bottom. I'm not sure if the engine kind of got lowered and that's why or if I just hit the magic spot, but I was able to put the new pump back in the same way. Try to wiggle it out and if you have to, move on to lowering the engine and then removing the a/c compresser if necessary.
11.Make sure to remove and replace O-ring. I installed the new O-ring to the water pump before putting in. It doesn't stay in place if you try and set it in the block.
12.Re-install in reverse order and remember to fill coolant.
I'm hoping this will be a new sticky???
o/_____\o
(8Oo)FORD(oO8)---SEDAN REVOLUTION
U_{=SR114=}_U----Upgrades In Profile
Rabbitccc is offline
Old 01-07-2009, 08:17 PM   #2
67shelby
67shelby's Avatar
Fan#: 57369
What I Drive: 2000, Pitch Black, ZX3
FF Reputation: 1 67shelby Good Standing Member
Very nice, with the pictures it looks much easier! Thanks!
67shelby is offline
Old 01-07-2009, 11:24 PM   #3
malim
malim's Avatar
Fan#: 55004
What I Drive: 2007 Ford Focus ST - Black
Points 972, Level 16
Points: 972, Level: 16 Points: 972, Level: 16 Points: 972, Level: 16
Level Up 72% Completed
FF Reputation: 4 malim Good Standing Member
Hmm interesting... I always thought you have to remove the belt cover bla bla bla... I was thinking that way because everyone says to change waterpump while changing the timing belt, because 90% of labour is already done.
Guess i misunderstood. Does the same thing apply for SPI or is it a bit different ?
malim is offline
Old 01-08-2009, 07:39 AM   #4
Rabbitccc
Rabbitccc's Avatar
Fan#: 44508
Yeah. Your right most people say to just go ahead and do the timing belt. But I was scared to even attempt this with taking off the motor mount and everything. I need this car for work (Delivery Driver) and can't afford to mess it up. So I'll hold off on the timing belt. I believe the SPI is a little different. I'd have to look at my Hanes manual because I believe you do have to take off the Timing belt cover for that.
o/_____\o
Old 01-09-2009, 08:49 AM   #5
Rabbitccc
Rabbitccc's Avatar
Fan#: 44508
Is my thread not sticky enough for the sticky club......sticky...sticky?
Edit:I guess I was supposed to PM S2 to get it put in. DONE.
o/_____\o
Old 01-09-2009, 09:03 AM   #6
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Yeah I will add this in and/or replace the other one. Typically I leave both HOW TO's in the list as more information is always better. Nice work on taking the time to do this for the members.....
Chad (S2)
S2 is offline
Old 05-26-2009, 12:08 AM   #7
93_03SVT
Fan#: 65472
What I Drive: 2003 Silver Focus SVT
FF Reputation: 1 93_03SVT Good Standing Member
Very useful. Haynes manual didn't mention about taking out the motor mount which doing so as you describe maked it easy. Thanks!
93_03SVT is offline
Old 06-07-2009, 09:35 AM   #8
chefster
chefster's Avatar
Fan#: 60762
What I Drive: ZX3,06stangGT, 2001 F150 Lightning,
Points 3,021, Level 33
Points: 3,021, Level: 33 Points: 3,021, Level: 33 Points: 3,021, Level: 33
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
Forum Activity 2%
FF Reputation: 3 chefster Good Standing Member
you rock dude.
SHOES ARE ALWAYS TIED, READY TO RUN
chefster is offline
Old 06-07-2009, 09:52 AM   #9
Justin svt
Justin svt's Avatar
Fan#: 58325
What I Drive: 2002 CD Silver SVT
Points 2,615, Level 31
Points: 2,615, Level: 31 Points: 2,615, Level: 31 Points: 2,615, Level: 31
Level Up 10% Completed
FF Reputation: 2 Justin svt Good Standing Member
good to know i can do this after i do my T-Belt. great work. why did you do it? did the pump fail or it was "going out"
2002 silver ZX3 SVT #2318: Tom's Tune, 8.2mm Taylor Thundervolt wires, Custom ORP, Full Prothane bushing swap
"I buy things I don't need, with money I don't have, to impress people I don't know"
Justin svt is offline
Old 08-01-2009, 04:00 AM   #10
mrzog
Fan#: 67770
What I Drive: 2002 liquid grey se sedan
FF Reputation: 1 mrzog Good Standing Member
had my pulley bolts back. figured i should go ahead and change the pump in case the pump had damage. figured you would have undo a motor mount
mrzog is offline
Similar Threads
Focus 2002 Zetec - Water Pump Failure? stubee General Technical Chat 4 11-16-2008 06:02 AM
Just had timing belt and water pump changed now car is overheating?!?!? DanielW General Technical Chat 5 11-10-2008 10:37 PM
water pump problems officefocus General Technical Chat 1 06-25-2006 11:54 AM
Water pump clicking... Marko1962 General Technical Chat 9 07-03-2005 02:20 PM
