HEATER not working PLEASE HELP very cold!! - Focus Fanatics
Old 01-05-2009, 10:04 PM   #1
natewhicker1
Fan#: 61729
What I Drive: 2002, Red, Ford Focus SE
FF Reputation: 1 natewhicker1 Good Standing Member
Alright, 2 days ago my wife's heater in her 2002 ford focus, suddenly gave out.
She called me on her way to work saying she had been driving for 15 minutes and it wont blow hot air. The fan works fine and still blows but she said she couldnt feel hot air.
When she got to work she said that she might have been able to feel a bit of warm air but nothing that would matter( i think that it was her mind saying its warm)
Keep in mind its around 5 degrees Faren.
We have never had a problem with the heater in the past
The Temp Sensor is warming up and sits perfectly in the middle.
Where can i look what do i need.
Im having a hard time working on it cause A. I dont get home from work till dark and B. ITS FLIPPIN FREAZIN!
Please HELP!
natewhicker1 is offline
Old 01-05-2009, 10:44 PM   #2
RocSVT
RocSVT's Avatar
Fan#: 34860
What I Drive: 03 SVT FOCUS
FF Reputation: 1 RocSVT Good Standing Member
it could be your heater core thats clog or just dont want to work no more.also how many miles on it?have you replace you water pump? or done any coolant work,if so you might of gotten air in the coolant system...but if you havent touch the coolant i put my money on the heater core thats cousing this prob.
boom boom boommmmmm ppppsssshhhhh.
RocSVT is offline
Old 01-05-2009, 11:55 PM   #3
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Memberjetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Your thermostat is most likely stuck open. It won't cause any serious mechanical harm its just annoying to the person that wants heat. It is fairly easy to replace.
jetrinka is offline
Old 01-06-2009, 12:13 AM   #4
macgurl
macgurl's Avatar
Fan#: 60767
What I Drive: 2002 Silver SVT/RIP 2002 ZX5
FF Reputation: 1 macgurl Good Standing Member
I know very little about cars... but I agree! Exact same issue just happened to my focus and it was the thermostat stuck open. If you know how to replace it yourself I highly suggest it as I paid $20 for the thermostat and $134 for labour.... ouch.
macgurl is offline
Old 01-06-2009, 12:22 AM   #5
norcalfocus01
Fan#: 55603
FF Reputation: 132 norcalfocus01 Excellent Standing Membernorcalfocus01 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
this could be it, but at some point the water temp would heat and start blowing hot air. and he said the temp gauge is normal in the middle.
if you turn the knob for the heat control, can you hear the flap moving? (there is a flap inside the dash that directs hot air or cold air) if the motor is blowing and you have air, but the flap is not moving than thats your problem. also scine the car is heating up to normal temp than your heater core is not leaking. its got to be clogged. take it to a mechanic and have then blow it out. my parents had there truck done last month cost 150 bucks.
hope that helps bro, lord know you gotta keep the wife warm!
norcalfocus01 is offline
Old 01-06-2009, 08:50 AM   #6
natewhicker1
Fan#: 61729
Im not convinced its the thermostat. The car heats up find doesnt overheat doesnt underheat. She said during her trip last night it started warming up a little bit still under 15 degreees. Im going to go drive it right now ill give you my observation
Old 01-06-2009, 08:58 AM   #7
PDQEagle
Fan#: 9356
What I Drive: 03 Focus ZX3
FF Reputation: 11 PDQEagle Great Standing Member
On the lower part of the center dash, there is a knob that directs inside air or outside air through the system. Make sure it is redirecting inside air, as taking 5 degree air and trying to heat it up another 60 degrees just won't work. Get back it this sort of helps.
PDQEagle is offline
Old 01-06-2009, 09:02 AM   #8
natewhicker1
Fan#: 61729
Just checked, The flapper when you cycle back and forth through cold and hot works... fan works on all speeds and speeds up when it goes to cool.. which i believe is normal happens in my other car..
RECAP
heats to normal temp.
fan works
flapper works
Thanks for your help like i said its kinda hard to diognose when its 20 below and dark
Nate
Old 01-06-2009, 09:56 AM   #9
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Memberpenguin Excellent Standing Member
You cannot trust the temperature gauge, as it isn't a temperature gauge in the normal sense of the word. The "gauge" will always go to a fixed "normal" position when the temperature is within a certain range. If it is at the low end of the range, it will still point "normal." Many car companies have done this due to people complaining the needle is not always in the same spot on a very hot day with the A/C running full blast. So the companies "fixed" it so the temp gauge works more like an idiot light, e.g., notice how quickly the needle goes to "normal" one it gets into the range on the gauge.
penguin is offline
Old 01-06-2009, 10:32 AM   #10
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Memberbluefront Excellent Standing Member
It's fairly easy to see if your heater core is clogged. Get the car warmed up, turn the heater knob and the fan to high. Have a helper keep the engine at a high idle.
Then reach down from under the hood and touch both the heater hoses, going into the cabin. They both should be hot....equally so. If one hose (the outlet hose) is a bunch colder.....you have a restriction of some sort in the heater core.
If both hoses are cool, or only slightly warm, you have a general coolant circulation problem, or a thermostat problem.
I'd bet thermostat.....
I'll keep my guns, my freedom, and my money.....you can keep the "change".
bluefront is offline
Similar Threads
MTX-75 not working in the cold Chupathingy009 General Technical Chat 18 01-06-2009 09:12 AM
Block Heater: AWSOME ShamrockSVT Ford Focus & General Car Chat 20 09-18-2007 10:27 PM
Air-Conditioner doesn't stay cold goheels681 General Technical Chat 1 08-24-2007 04:24 PM
Cold air bad? 07ZX4 DURATEC Performance (2003-2007) 46 06-29-2007 09:48 PM
