#1 | ||||
Here is a how to write up incase anyone wants to know how to fix the pigtail on a Ford Focus.
Special thanks to Feral, The norm, and Bullitt5177 for helping me out when I mostly needed them. First you have to identify if the Pigtail connector is Faulty. Mine was the ignition coil pigtail.
"Never settle for the Best, Settle for being the Best of the Best." |
Remove Advertisements |
Fan#: 1
#2 | ||||
Next you want to cut the wires as close as possible to the old one.
As you can see from my pics mine was very torn up very close to the plug so might as well cut it as close as I could to the plug.
#3 | ||||
Next you want to order your part. I use RockAuto website to get my plug.
Here is how it looks.
#4 | ||||
Then you want to Splice your cables.. If your were question was like mine
what do you use? this is what you use:
#5 | ||||
After you do that you can either use a blow dryier or a torch to melt the heat shrink wrap at the end it will look like this..
#6 | ||||
Finally just put the plug back. I used wire loom to cover my wires just incase the heat
wants to attack my wires it will protect them. Here is how the installation of the Pigtail looks after you are thru...
#7 | ||||
Good write-up! If you know how to solder, it is the perfered method (over butt connectors) for reattaching wires.
"I aim to misbehave"-Malcolm Reynolds |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| The Ford Focus Parts List! | gthang | MK2 Focus | 13 | 01-26-2009 11:05 PM |
| Australia gets the new Focus next month | Kneel | Ford Focus & General Car Chat | 27 | 11-26-2007 08:17 PM |
| 2008 Ford Focus US-Spec part 1 | mitchlguzin | Ford Focus & General Car Chat | 9 | 01-08-2007 05:57 PM |
| Aussie Fords Coming? | igor | Ford Focus & General Car Chat | 27 | 06-06-2006 11:32 AM |
