Write up w/Photos ZX3 Power Window Regulator Install - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-24-2013, 06:40 AM   #11
ianmccracken
Fan#: 90222
What I Drive: 2002 TDCi
Points 352, Level 7
Points: 352, Level: 7 Points: 352, Level: 7 Points: 352, Level: 7
Level Up 4% Completed
FF Reputation: 1 ianmccracken Good Standing Member
Symptoms for failed Power Window Regulator???
Hello, can you tell me what the symptoms are? My drivers side window will not open, the motor runs and it moves up and down half an inch and makes a grinding noise. Seems like the regulator could be frozen or broken but I do not want to do all this work if there is an easier fix. Thanks! My car has 100K miles and is a 2001 model.
ianmccracken is offline
Old 03-25-2013, 12:53 PM   #12
amc49
Fan#: 96610
Points 3,270, Level 35
Points: 3,270, Level: 35 Points: 3,270, Level: 35 Points: 3,270, Level: 35
Level Up 47% Completed
Forum Activity 9%
You have the symptoms.....................cable has derailed and locked up the works.
amc49 is offline
Old 07-17-2014, 03:57 PM   #13
Marde
Marde's Avatar
Fan#: 115991
What I Drive: 2004 ZTW PZEV 2.3 ATX
Points 1,686, Level 23
Points: 1,686, Level: 23 Points: 1,686, Level: 23 Points: 1,686, Level: 23
Level Up 86% Completed
Forum Activity 11%
FF Reputation: 11 Marde Great Standing Member
Originally Posted by jongun78 View Post
just wondering, can you give more details about removing the door latch, can't get it off, grrrr....
Thanks!
I see the quote is 3 plus years old but wanted to share what I learned last night when replacing my drivers door window regulator. Like jongun78, I was puzzled on how to remove the inside door handle assembly from the door frame. You can Pull & Wiggle & Snap the assembly off the door and you might or might not break it in the process. I found a smarter method. After the interior door panel has been removed... Using a medium/heavy duty hemostat, I was able to reach into the slot where the window glass slides into and Pinch the plastic tab/prong that is securing the door handle onto the door. Once the prong was squeezed by the hemostat, I Pulled, Wiggled, Snapped the handle assembly off of the door frame. If that one little plastic prong gets broken your screwed.
Thank you to the OP for this how-to thread. I also used the link below to help me learn how to do this job. This was my first time doing a window regulator. After a month of driving with a broken window regulator, I am so happy to have my power window working again.
I bought a XW4Z-54234A44-AA "spacer" in advance but oddly never saw where it was used. Never really looked for it. Strange. Realized
I missed or forgot about it only after the job was done.
http://www.scribd.com/doc/206251168/...or-Replacement
You've got to ask yourself one question: Do you feel lucky? -and could you really drive a Focus ATX Wagon?
Marde is offline
Old 07-17-2014, 10:45 PM   #14
amc49
Fan#: 96610
Forum Activity 9%
The spacer is used on rear glass only, it attaches differently to the regulator than front one with the two white plastic grabber clips. Glass has a hole, spacer goes in it and then a plastic expander pin into the center to expand it out tight.
The Scribd document is for a REAR window but the basics are the same except for the glass attachment.
Fix the driver first, then fixing the car becomes so much easier.
amc49 is offline
Old 07-18-2014, 01:49 AM   #15
Marde
Marde's Avatar
Fan#: 115991
Forum Activity 11%
Ah dang-it, I shoulda caught that before. Thank you for the info. Bought it at my local Ford dealer, so will return this small spacer and get 16 bucks back. If it weighed 1 pound, I guess it might sell for $1,600.00 or more. -jk I accepted prices on Ford (+GM +others) parts long ago, no complaints from me... so I bought a Dorman window regulator.
Thanks again, Cheers!
Marde is offline
Old 07-19-2014, 06:16 AM   #16
amc49
Fan#: 96610
Forum Activity 9%
Hey I'm still cussing over the last snap ring I bought from them.........$15 for THAT???!!
The Dorman part virtually the same as Ford but without the oval stamped on it and the Ford one breaks as quick........easy $50 savings there and Ford gives no lifetime warranty like over the counter does. One of the few parts you should keep the receipt on, they break more than once. I've been through like 5 now on two cars, even went to rebuilding the broken ones. The unobtanium part (Ebay only) is the two window clips that commonly break. One is same as manual window one but the other is different and power only. The manual one can easily be found at the scrapyard as they don't break, it is the power motor running window up/down till it hits hard that breaks them. If you train yourself to not bash them hard they then last much longer, I barely kiss them nowadays and never go down 100% to bottom either.
amc49 is offline
Old 07-19-2014, 03:00 PM   #17
Fierceintent
Fierceintent's Avatar
Fan#: 117556
What I Drive: 04 infra red Svt, 03 2.3 red sedan
Points 499, Level 9
Points: 499, Level: 9 Points: 499, Level: 9 Points: 499, Level: 9
Level Up 98% Completed
FF Reputation: 1 Fierceintent Good Standing Member
Why would you want to remove the door handle?
Fierceintent is offline
Old 07-19-2014, 05:27 PM   #18
amc49
Fan#: 96610
Forum Activity 9%
Can't get door panel off without doing it.
BTW, proper handle assembly popping loose at least on the earlier models is...rotate FRONT of assembly out and toward centerline of car, then once front is popped loose go forward to unhook the back.
amc49 is offline
Old 07-19-2014, 05:40 PM   #19
Marde
Marde's Avatar
Fan#: 115991
Forum Activity 11%
I guess you are saying that the (drivers) regulator can be replaced without disconnecting the door handle assembly from the door frame? Maybe it can? Do you know that I am talking about the handle that is on the inside of the car?
This thread shows it removed. It was in my way when removing the delicate moisture barrier foam. I got the moisture barrier *removed without tearing it, but if the door handle stays on the door, you must tear it... at least on my car.
* = not fully removed, just peeled it fully forward, leaving one edge still connected.
Marde is offline
Old 07-19-2014, 05:50 PM   #20
Marde
Marde's Avatar
Fan#: 115991
Forum Activity 11%
Not on mine. Panel comes off while door handle is fully attached onto the door frame.
The small accessory panel that holds the door lock switch and power window controls must be removed first, and then wiggled around the door handle... and then the door panel can be removed.
Marde is offline
Similar Threads
Power Hatch (ZX3) broken or what? jcarian General Technical Chat 15 01-26-2005 05:48 PM
02 ZX3 Power Premium - Moonroof - Cheap! plasticspaceman Archive 7 08-08-2004 05:57 AM
zx3 power window Sharpening_Beneath Archive 0 04-25-2004 11:44 PM
