Write up w/Photos ZX3 Power Window Regulator Install - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-17-2008, 01:22 AM   #1
SVTF4243
SVTF4243's Avatar
Fan#: 4068
What I Drive: SVT 2002
Points 4,095, Level 40
Points: 4,095, Level: 40 Points: 4,095, Level: 40 Points: 4,095, Level: 40
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 2%
FF Reputation: 11 SVTF4243 Great Standing Member
This will apply to 2001-2006 ZX3s
This is for the drivers side & took me about 2 hours. Got new regulator for $69 plus shipping
Follow these instructions for door panel removal.
Unscrew speaker and then unplug.
Take out Door Latch: The screw hole is a tab that will pull out the back of the plate has an l shaped tab
Take out the crash foam It's on hooks it sort of lifts up and back
Carefully use a utilty knife to peal back the moisture barrier. It's very easy to tear.
Once you have that off here's what you have
the numbers refer to the Images below
Position the window so that the rear rail screw is accesable and secure with tape
Image 1
Reposition the window so that the front rail screw is accesable and secure with tape
Image 2
Pull out window from the exterior side of the door
it will come out at an angle front side down
Unscrew the 5 bolts of the regulator
Image 3
Pull out the regulator
Install new regulator
Put back in window it will go in at an angle front side down
Put back the moisture barrier
Put back Door latch
Screw in speaker and then replug.
Reinstall crash foam
Put back panel
Silver SVT 2002 svtf4243.com
Silver ST3 MR::: 02 11 2013
GO :: Cobb RRM | Accelerator petal mod| JBR OCC | STS | Springs| Rear Swaybar | Tune
SHOW :: Lights tint | Calipers Painted| Graphite colored wheels| Back up Cam | Window Tint
SVTF4243 is offline
Old 12-17-2008, 05:39 AM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,689, Level 86
Points: 18,689, Level: 86 Points: 18,689, Level: 86 Points: 18,689, Level: 86
Level Up 68% Completed
Forum Activity 18%
Buy-Sell-Trade Rating: (4)
Not too shabby. Sending the link to Chad (S2) to add to the FAQ. Thanks for the effort, it is quite appreciated, rep'd.
OH, you're not playing dumb ...
iminhell is offline
Old 12-17-2008, 06:09 AM   #3
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Member bluefront Excellent Standing Member
Buy-Sell-Trade Rating: (6)
FWIW....I've done this exact job on many different cars. It's really not necessary to remove the window itself. You lower the window far enough to remove the screws/bolts (usually just two) that hold the window to the regulator. Then you push the window upward in it's tracks by hand. Wrap several pieces of long duct tape around the top of the window frame attached to both sides of the window (to keep it from falling down while you're working).
This simplifies the operation, and avoids possible scratching of the window or the door frame.
If the window regulator is hopelessly jammed, you may not be able to get the window far enough down to get to the attachment bolts. In that case you may need to cut the control cables.
A while back, Nissan had a massive recall of all the regulators on several models. They paid the mechanic about 1.4 hrs labor time to do all four doors. I got pretty good at that......
I'll keep my guns, my freedom, and my money.....you can keep the "change".
bluefront is offline
Old 12-17-2008, 08:09 PM   #4
SVTF4243
SVTF4243's Avatar
Fan#: 4068
Forum Activity 2%
Thanks Bluefront
I'd add that as an alternate
I was going to tape it up, but the window was pretty wobbly
It only took a minute to take out and 3 to put back
You could probalby do this in your sleep...but then again i only did one
SVTF4243 is offline
Old 12-17-2008, 08:24 PM   #5
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the 'HOW TO' Archive........
Chad (S2)
S2 is offline
Old 07-06-2009, 06:56 PM   #6
Mav3rick21
Fan#: 66685
What I Drive: 2000 Red Zx3
FF Reputation: 1 Mav3rick21 Good Standing Member
helpp
Hello, im new here.. ive been looking for a window regulator! i need the passenger side! i couldnt find the same one as in the picture! i know this is and old topic. I want to ask where did you get that window regulator?
Mav3rick21 is offline
Old 07-07-2009, 04:28 AM   #7
Mulingko
Fan#: 49233
What I Drive: 2000 Black Focus ZX3
FF Reputation: 1 Mulingko Good Standing Member
Nice write up, I had to do this blind. BUT one problem I had that you did not adress, is running the new wiring into the car, they use these stupid plastic modular connectors in the door, so ya have to drill new holes. I have the tracks and motors in but havent ran the wires yet. I cant open the doors all the way in my small garage. lol. :(
2000 ZX3 Black 5-spd
3 year N/A build, still hasn't seen the road yet.
Mulingko is offline
Old 08-18-2009, 08:32 PM   #8
lofocus
lofocus's Avatar
Fan#: 9667
What I Drive: {04 Snow zx3}
Points 678, Level 13
Points: 678, Level: 13 Points: 678, Level: 13 Points: 678, Level: 13
Level Up 56% Completed
FF Reputation: 1 lofocus Good Standing Member
doing the same thing... did you find some info on how to wire it up? i got all the goodies from a DOA foci and i am going to transplant.
04 Snow zx3 FSWerks Sg 2 Turbo
SoCal Crew #28 | Boost Crew #127
lofocus is online now
Old 08-20-2009, 06:09 AM   #9
Mulingko
Fan#: 49233
No I still havent gotten to it, just finished all the chasis. it shouldnt be to difficult, most of the wires were on harness's and you just unplugged them, helps to label them with tape, the only cut wires you would have to adress are the ones going in the door, so just reconnect them. Sounds easier then it is I know but, hope that helps.
Mulingko is offline
Old 04-09-2011, 04:35 PM   #10
jongun78
Fan#: 84760
What I Drive: 2000 Hunter Green Focus
FF Reputation: 1 jongun78 Good Standing Member
just wondering, can you give more details about removing the door latch, can't get it off, grrrr....
Thanks!
jongun78 is offline
Similar Threads
Power Hatch (ZX3) broken or what? jcarian General Technical Chat 15 01-26-2005 05:48 PM
02 ZX3 Power Premium - Moonroof - Cheap! plasticspaceman Archive 7 08-08-2004 05:57 AM
zx3 power window Sharpening_Beneath Archive 0 04-25-2004 11:44 PM
