Road Racing & Rally The place to discuss information about road/rally racing stats, tips and events. Track sanctioned events only.
#31 | ||||
Shot me 3 deer!!!
In my car i would, I want to just use my 4th gear. at 7500 rpm in 4th, w/ 3.3 ish final drive gears that would be good, talking 130 + . but I would still be fine in the low end too. It all depends on what type of rallying too. the LSPR where I want to be doesn't see much more than 90 mph, so thats high 3rd in those gears. for my car, I already have enough torque for the NA modified 2wd G2 class. Enough to get me into trouble. So depending on what engine mods you have, this can dictate ur gearing. If you need the torque, go w/ taller gears. If you have enough, go w/ shorter. If I was stock, I would go taller gears. I will, if I can find it, go w/ shorter gears. I already have trouble enough putting power down w/ a lsd and dirt tires, so i need shorter. Like i said, it depends on ur power.
Group buy, CARBON FIBER bezels till July 28 check in the Group buy section! Owner of Custom Carbon! PM me w/ CF needs! |
#32 | ||||
done:
- inspection sticker. No problems encountered, except for slipsliding around on the ice. - got car cover todo: - wire up kill switch. I found out that it's not hooked up - diagnose auxilliary fog lights not working. Hopefully it's a wire harness or relay problem - winter tires - order suspension tools, grease gun, grease, urethane glue - repair front light housing glue link: http://www.levineautoparts.com/3mwinsupfasu.html grease gun: http://www.harborfreight.com/cpi/cta...emnumber=47520 http://www.harborfreight.com/cpi/cta...emnumber=40710 http://www.harborfreight.com/cpi/cta...emnumber=96468 (for reach rear ball joint zerk, according to PO)
check out my Fiesta Movement entry: youtube.com/watch?v=dXY3mi1NWeg&eurl=http://www.focusfanatics.com I wholeheartedly endorse McNew's for installing and tuning your Focus. Last edited by kimbo305; 12-23-2008 at 08:33 PM. Reason: put some links for my own reference |
#33 | ||||
SE HABLA ESPAÑOL
-Team Duratec #122 SoCal #0 278whp & 259 ft/lb @ 2688rpm of Pure N/A baby!!! 7.22 @ 89 mph 1/8 mile 10.68 @ 127 mph 1/4 mile I'm a time taker and I just wasted your time |
#35 | ||||
Clutchmasters stg 4 with an aluminum flywheel. Feels pretty stock to me.
The brake lever pushes its own piston, which is hooked up to the brake lines, and drives out to the rear brakes.
check out my Fiesta Movement entry: youtube.com/watch?v=dXY3mi1NWeg&eurl=http://www.focusfanatics.com I wholeheartedly endorse McNew's for installing and tuning your Focus. |
#36 | ||||
SE HABLA ESPAÑOL
yeah, how do you do that? that would be like super fun to have in my car
#38 | ||||
No the brake pedal works normally. The hydraulic ebrake just helps send more volume to the rear calipers. There's also a brake bias lever so I can tweak the amount of rotation I want when braking into turns.
#39 | ||||
SE HABLA ESPAÑOL
oops, forgot to mention that I totally want to kill you and rob your car. (wrc don't count, they are pros) If a rally car doesn't look effed up, then it is not a rally car , and you man, you got a really freaking sweet effed up car.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| The Ford Focus Parts List! | gthang | MK2 Focus | 13 | 01-26-2009 11:05 PM |
| Advice on rally car build | NewToFocus Guy | Ford Focus & General Car Chat | 5 | 03-20-2007 08:53 AM |
| Soon to come, more SVT parts for your non-SVT Focus... | myFordPerformance.com | ZETEC Performance (2000-2004) | 33 | 01-02-2007 11:41 PM |
| does anyone driwes rally whit focus in USA | diff | Road Racing & Rally | 1 | 09-19-2004 04:58 PM |
