R-compound shopping, need help - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 12-15-2008, 03:06 AM   #1
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
Well its about time for me to become an official addict, im seriously considering buying r compounds this season.
I see a couple of options. I already have a spare set of OEM 15's, but im not sure about them being that they are only 6" wide. But... they are 15.2 lbs. Also I want to go a bit smaller diameter, my region's courses are usually perfect for me to stay in 2nd gear, but I often dip out of my cams' torque range in the tight corners.
Here is what im thinking in order of what i want right now. trying to stick to cheap tire sizes, probly going with Ecsta V710's. Rolling fenders is not an option at this point. Not looking to be a national contender or anything, but my street tires are starting to annoy me with their general complaining and lack of grip.
1. OEM 15's and 205/50/15 $186/tire
2. 15x7 aftermarket wheel and 225/50-15, but will the cost of the wheels be worth the extra 20mm of tire? and will they rub? $188/tire
3. I can also get new street wheels and retire my current wheels to racing duty. At about 17.6lbs theyre not too heavy. 16x7 aftermarket wheel and 215/40-16. $184/tire.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 12-15-2008, 11:23 AM   #2
xShiFTx
xShiFTx's Avatar
Fan#: 59110
What I Drive: 02 Sangria Red SE
FF Reputation: 5 xShiFTx Good Standing Member
What class are you planning to run?
xShiFTx is offline
Old 12-15-2008, 11:29 AM   #3
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
im already in SM it doesnt really matter
like i said im not looking to be a national contender or anything like that
SUV this!
illinipo is offline
Old 12-15-2008, 01:40 PM   #4
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
What I Drive: 2002 RED SVT Focus
FF Reputation: 175 WeeAsp Excellent Standing Member WeeAsp Excellent Standing Member
Given that you are in SM. The world is your oyster.
You could run a full blown slick with no additional penalty. However, the lifespan of a full AX race tire is measured in hours vs. events.
So, I think this would be cost prohibitive for most.
I would recommend that you go with a DOT rated R-compound tire.
Budgets aside, Hoosier is undoubtably your best bet - in dry weather conditions.
The A6 compound is available in a 205/50R15.
Advantages:
- Grip. Once up to temperature, IMHO there is no tire that offers the lateral cornering ability of the Hoosier.
- Size. Hoosier tends to "fudge" their tire sizes to an extent. A 205 is in reality closer to a 215 because of the sidewall design. This small increase should not cause you any issues with rubbing - even with the SM mods.
- Longevity. The tires would be good for a full season and probably 1-2 events into the following year. They will not last as long as either the Toyo or the Kuhmo.
Disadvantages:
- Wet Weather Performance. AX is run rain or shine. The A6 is GREAT in the dry and fairly unpredictable in the wet. It is difficult for the tire to build and retain heat. The shallow tread pattern is also virtually useless in channeling water. All these combined make for an exciting experience on an AX course. You'd be better off running a street tire in the rain.
- Cost. They are not cheap. Count on about $200 per tire. If you are not looking for a regional or national bid, your budget may come into play a bit more.
I've run the Hoosier for nearly 10 years. In a STOCK SVT, I've been able to perform on par with much faster cars running street tires and other brands of R-compounds (Kuhmo, Toyo). I've even beaten some in straight time (non-indexed).
As a result, I highly recommend the Hoosier A6.
FORMER Avenging Moderator of the Apocalypse and Leader of the Axis of Oversteer
"I live with fear every day and sometimes, she lets me race."
2002 SVT Focus... Stock
WeeAsp is offline
Old 12-15-2008, 02:14 PM   #5
WD40
The Librarian
WD40's Avatar
Fan#: 5157
^^^I think these are all legitimate AutoCross questions.
(Course, I see it hasn't been moved yet anyway.)
1) Obviously your least expensive option.
You could squeeze a 215 on that 6" rim without too much trouble.
2) Yes...that 20mm width increase is a HUGE advantage, and you'll notice it the very first turn you make right out of the gate.
Rubbing....depends on what offset wheels you get (try and get an offset of 45mm or greater), and what springs you currently have.
3) Good choice, but I swear that 16" race tires are harder to find than 15's or 17's.
17.6lbs is borderline, though you mentioned that competing at a national level isn't in the cards anyway.
I hope this was a help.
WD40 is offline
Old 12-15-2008, 03:42 PM   #6
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
Yep. I thought about and changed my mind... The comp tire knowledge base is predominantly here and not in the other forum.
WeeAsp is offline
Old 12-15-2008, 04:32 PM   #7
mlbbaseball
Shot me 3 deer!!!
mlbbaseball's Avatar
Fan#: 53541
What I Drive: 02 SVT, 2 7.3 L Diesel Excursions!
Points 27,847, Level 98
Points: 27,847, Level: 98 Points: 27,847, Level: 98 Points: 27,847, Level: 98
Level Up 50% Completed
Forum Activity 3%
FF Reputation: 42 mlbbaseball Great Standing Member
Buy-Sell-Trade Rating: (69)
My favorite is the yokohoma A048's, they are good all around and last decently long. but i've heard the new R888 compounds are pretty good too. and they do better w/ hydroplaining.
Now I rive 2 7.3 L diesel trucks!
mlbbaseball is online now
Old 12-16-2008, 11:47 AM   #8
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
alright well at this point I'm probly lookin at 15x7 with 225/50-15 since 225/x-16 are next to impossible to find...
thanks!
SUV this!
illinipo is offline
Old 12-16-2008, 12:02 PM   #9
HaveBlue83
Guest
Fan#: 1358
What I Drive: a car
FF Reputation: 70 HaveBlue83 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
LOL...i was gonna say "PM WeeAsp" cause he knows, but I see he took care of that already...
I know he runs them cause he pulled into a G2G with R compounds on straight from summit point one time...haha....crazy ricer!!
HaveBlue83 is offline
Old 12-16-2008, 08:58 PM   #10
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
Ricer?
I think you mean RACER !!!
WeeAsp is offline
Similar Threads
Rubbing compound and swirl mark remover? KeepItKauai Auto Washing, Detailing & Paint Protection 18 01-21-2009 03:07 PM
Compound Boost mpsii General Forced Induction 12 12-03-2007 10:49 PM
Catback: Shopping S0C0nFused DURATEC Performance (2003-2007) 15 04-27-2007 05:43 PM
Hit by a shopping cart zx5go SVT Performance (2002-2004) 9 02-06-2006 04:35 PM
Understanding brake pad compound to fit your application autocrossman Wheels & Tires 1 02-10-2005 06:52 PM
