For Sale: HTP Rear Big Brake kit*CLOSED* - Focus Fanatics
Old 11-30-2008, 06:40 PM   #1
HTP Designer
HTP Designer's Avatar
Fan#: 34811
What I Drive: '01 Ugly Betty, '06 Yel 2.5L RWD RS
FF Reputation: 19 HTP Designer Great Standing Member
Buy-Sell-Trade Rating: (25)
Exclamation For Sale: HTP Rear Big Brake kit*CLOSED*
Selling my prototype big brake kit due to the slew of changes I am making for the next setup. These changes do not make this brake kit obsolete but I am going to be using a different caliper so it will need a different brake line setup along with different brackets. Since I will be changing everything minus the rotor, I am going to sell the whole kit to make it easier for the next person.
Part: HTP Big Rear Brake kit, 11.66"
1. Wilwood GT Series Directional Vane Rotors (slotted and vented)
2. Wilwood Blank aluminum hat machined by HTP (me) for the correct register and lug pattern
3. HTP Billet Aluminum Caliper brackets (caliper through holes have been sleeved with Chromoly steel) The brackets are new and never used because I added the Chromoly steel sleeves and also clocked the caliper position 15 degrees from the originals.
4. Mustang Cobra Calipers with mechanical e-brake.
5. Earls stainless steel brake lines and fittings
6. All instillation hardware
I will include the spindles if converting from a SVT or will include hubs if converting from a drum setup. Drum spindles and svt hubs are used for this setup.
SVT E-Brake cables are used for this setup also, if you do not have them, please ask when inquiring and I may be able to help.
I do recommend that a brake kit larger than the OEM svt setup be used, such as HTP big brake kit, TCE street or track, Bear or Brembo.
This kit was ran with 16" OZ wheels with no clearance issues. I am not sure how it will fit in a 15" wheel. Kit has 7,000 miles on it. 3 autocross events, 1 track day. All components are in great shape, brackets are NEW. Rotors are barely worn and the pads have plenty of life left.
Questions, post them up and I will be sure to answere or email me at jason@htperformance.net
Price: $700 shipped . PLEASE FEEL FREE TO MAKE AN OFFER. This is a complete over the top kit that works well and has minimal miles on it.
Payment: Paypal or credit card
HTP Designer is offline
Old 11-30-2008, 06:42 PM   #2
HTP Designer
Fan#: 34811
Oh, the rust on the rotor came off the first time I hit the brakes, lol
Old 11-30-2008, 09:21 PM   #3
VenomRogue
VenomRogue's Avatar
Fan#: 24506
What I Drive: a Volvo??!?
FF Reputation: 11 VenomRogue Great Standing Member
Buy-Sell-Trade Rating: (23)
price?
9 Foci. and a rebadged mK II Focus ST (Volvo C30)
Yes, I have issues.
Next question.
VenomRogue is online now
Old 11-30-2008, 09:55 PM   #4
HTP Designer
Fan#: 34811
Price is $1000 shipped or best offer. It took over $1k in parts, materials and labor to design and build this kit. I would just like to see it go to a good home.
Old 12-01-2008, 09:49 AM   #5
hurtinfocus
hurtinfocus's Avatar
Fan#: 835
What I Drive: 03 SVT (RS conversion)
FF Reputation: 4 hurtinfocus Good Standing Member
can you calrify what you mean by "uses drum spindles with SVT hubs" ???
is this a hodgepodge of drum brake, svt brake, and cutoms parts?
My majorly huge hand-made Focus RS replica build: http://www.focusfanatics.com/forum/showthread.php?t=289061
hurtinfocus is offline
Old 12-01-2008, 04:24 PM   #6
HTP Designer
Fan#: 34811
When someone says "hodgepodge", I think of junk and this is by no means junk.
The svt spindles have a caliper bracket built into them which is not in an ideal position, so the stock type drum spindles are used which are identical to the svt but without brackets built in. You then use a svt hub which houses your bearing. You can not use a stock drum hub due to the fact that the drum is the hub and well... you cant mount rotors to a drum.
Old 12-02-2008, 08:53 AM   #7
hurtinfocus
Fan#: 835
I wasnt implying low quality at all, but thank you for clearing that up for me. any chance of some pics of this kit mounted up like from the backside or something? do you just remove the calipers/wheel cylinders/all brake equipment, and then throw on the svt hub/bearing with this bracket/caliper/rotor assembly?
Old 12-02-2008, 10:27 AM   #8
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
wish i had the money for this and your front kit, theyre amazing looking and light weight stuff is always grand
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is offline
Old 12-02-2008, 04:01 PM   #9
HTPerformance
HTPerformance's Avatar
Fan#: 41307
What I Drive: 2002 SVT Focus
FF Reputation: 10 HTPerformance Great Standing Member
Buy-Sell-Trade Rating: (7)
More pics:
http://htperformance.net/index.php?o...d=21&Itemid=51
I'll let Jason describe the mechanics of it for you if you can't see it in the pictures.
HTPerformance is offline
Old 12-02-2008, 06:00 PM   #10
hurtinfocus
Fan#: 835
thanks for that link. I like the design. I may be inquiring in a couple months about this setup with a different bolt pattern, but still for the focus.
Similar Threads
How To - Extensive Suspension Overhaul (Front and Rear) SuperFlea Brakes, Suspension & Body Chassis 71 06-26-2014 10:58 PM
Tips for changing the rear pads on a SVTF darkstarmotorsports Wheels & Tires - Sponsored By Tire Rack 0 06-21-2009 02:24 AM
2001 ZX3 rear brake squeaking (how to take them apart) ChrisRobin General Technical Chat 10 09-11-2007 11:10 PM
Weird rear brake noise Mr-914 Brakes, Suspension & Body Chassis 5 08-18-2007 10:59 AM
Ford Focus: Suspension & Brakes hotfocus Brakes, Suspension & Body Chassis 0 02-17-2005 03:40 AM
