How To: 05-07 Halo Projector CCFL Transformer Replacement - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-27-2008, 06:11 PM   #1
DarkFire1986
暗炎
DarkFire1986's Avatar
Fan#: 40966
What I Drive: 2010 Silver Fusion, 1994 Ranger
Points 3,421, Level 36
Points: 3,421, Level: 36 Points: 3,421, Level: 36 Points: 3,421, Level: 36
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 31 DarkFire1986 Great Standing Member
Buy-Sell-Trade Rating: (6)
As of now, the 2005 to 2007 Focus only has one option for aftermarket headlights.
The Halos in my passenger light went out last week.
Since these halos are the CCFL type, I assumed that both of them going out simultaneously had to be the result of a blown transformer.
This is partially because I've had CCFL tubes inside my car before and experienced many transformer changes.
What you will need:
New transformer (http://www.oznium.com/cathode-transformer)
10 mm socket
7 mm socket
Phillips head screwdriver
Flat head screwdriver / Knife
Pliers
Wire strippers
Soldering iron with solder
Electrical tape / Heat shrink tube
Double sided tape
Remove Headlight. Remove cover for high beam bulb (reflector housing).
and locate a black box with a white label.
The box is attached with double sided tape. Place a flathead screwdriver or knife under it and pry it up.
Theres plenty of extra wire, so don't worry about accidentally removing the halo lights.
I cut the power wires to the transformer in order to make working on it easier.
Once out, pry it open with a flathead screwdriver or knife.
This is necessary to disconnect the wires from within the transformer.
The only issue here is that they are glued in. I used pliers to crush the circuit board and cut the unneeded connector.
Your other option is to cut the wires and solder on the new ones.
Once out, the original connectors will plug straight into the new transformer.
Since I cut the wires going into the transformer, I had to solder them to the new connector.
If you decided to cut these wires, don't forget to replace the rubber grommet.
Reconnect your wires.
Apply double sided tape to the new transformer and replace it inside your headlight.
Reinstall your headlight and make sure everything is working.
DarkFire1986 is offline
Old 11-27-2008, 11:28 PM   #2
pistolgripbmx
pistolgripbmx's Avatar
Fan#: 49331
What I Drive: 86 ranger, 2007 focus zx3 s
FF Reputation: 38 pistolgripbmx Great Standing Member
Buy-Sell-Trade Rating: (8)
good to know incase mine go out.
nice write up
teamduratec #143!
focus sport cool-flo, f2 v.3 header, trubendz 2.5 SS, frpp 1.5" front sportline rear, vf rear engine mount, 93oct Focus Power tune
pistolgripbmx is offline
Old 11-27-2008, 11:33 PM   #3
jmotank
"Party Pic WHORE"
jmotank's Avatar
Fan#: 10320
What I Drive: 2005 pitch black zx4 st
FF Reputation: 1 jmotank Good Standing Member
Buy-Sell-Trade Rating: (15)
^tru dat!! good info!!
ST crew #29
team DURATEC #53
MBRP exhaust, SRI, BFG G-Force sports, Steeda STS, painted stock rims, 1 12" diamond audio D6 sub, 3201T audiobahn amp, JVC headunit, Kicker 6X8's, 2 Farad cole cap, FC front strut bar, under body LED kit
jmotank is offline
Old 11-28-2008, 01:12 AM   #4
stilix
Zzzykeyah!!!!!!
stilix's Avatar
Fan#: 53230
What I Drive: 2007 liquid grey metallic ZX3
FF Reputation: 4 stilix Good Standing Member
Buy-Sell-Trade Rating: (13)
Thumbs up
great write up
stilix is offline
Old 11-28-2008, 08:52 PM   #5
zx4cliff
Fan#: 51014
What I Drive: 07 CD Silver ZX4
FF Reputation: 1 zx4cliff Good Standing Member
Nice. Mine went out a while ago. I didn't have the time or intelligence to find the needed replacement parts. I just put my stockers back in. Now, I can fix my halos and put them back in. I liked the look better than the stocks. Even though the light throw sucks, a bunch on the halos... ;-)
2007 ZX4, 2.0 liter Duratech, MBRP, Cossie CAI, Tri-Ax, SVT suspension, and blacked out CCFL halo projectors (halo died in one, but I got it fixed! Waiting for HID conversion kit). Not much else, yet... ;-)
zx4cliff is offline
Old 11-28-2008, 11:37 PM   #6
DarkFire1986
暗炎
Fan#: 40966
Thats exactly why I did this write up.
Its sort of simple and not very hard, but if you don't know what you're looking for it can seem overwhelming
Originally Posted by mofocus View Post
my car makes babies cry
Old 12-07-2008, 01:40 AM   #7
zx4cliff
Fan#: 51014
Talking Thanks DarkFire
Thanks DarkFire. I now have mine repaired. Worked like a charm. Great shipping from Oznium. I ordered Monday or Tuesday, and had them by Friday. I ordered two. One of the original ones went bad in such a short period of time, there is no reason for me to believe that the other won't go bad soon. I plan on changing both transformers, just to get things off on the same foot.
Thanks again. Now I just need to wait for my HID conversion it to show up...
Cliff
zx4cliff is offline
Old 12-07-2008, 01:41 AM   #8
zx4cliff
Fan#: 51014
Cliff
zx4cliff is offline
Old 12-07-2008, 04:59 AM   #9
ShamrockSVT
ShamrockSVT's Avatar
Fan#: 47719
What I Drive: 2011 Ford Fiesta SE
FF Reputation: 72 ShamrockSVT Excellent Standing Member
good job!
ShamrockSVT: Doing my part
ShamrockSVT is offline
Old 12-07-2008, 09:23 AM   #10
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the 'How To Archive'...... nice work.
Chad (S2)
S2 is offline
Similar Threads
"HOW TO" Ebay Halo Projector led replacement (56K WARNING) scrammer MK1 Focus 191 12-23-2013 09:58 PM
Halo Light Replacement Question Blitzkrieg2003 MK1 Focus 0 04-21-2008 11:29 PM
KS Halo Replacement Bulbs? lildisco MK1 Focus 9 08-26-2005 12:28 PM
Replacement Halo Light Housings randazzm MK1 Focus 0 01-09-2004 11:32 PM
Projector w/ halo replacement triplehsoul Archive 0 01-03-2004 11:25 PM
