Go Back   Focus Fanatics > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 11-24-2008, 12:35 PM   #1
Daschj
Fan#: 59798
What I Drive: 2004 Silver ZX3 D23
FF Reputation: 1 Daschj Good Standing Member
H Stock legal upgrades
Howdy:
I'm a new owner of a '04 ZX3 2.3 PZEV and am considering upgrades, but want to keep the SCCA autoX H Stock class an option. We do have a local club and they do run some local (eastern Idaho) events. From preliminary studies I am aware that I must stay with 15" or 16" rims, can upgrade to some "R" compound tires, can upgrade the front anti-sway bar and bushings and can use any stock type shock, like the SVTs.
I'm in doubt about two other variables. There are no specific prohibitions about the mufflers other then the cat. Can I upgrade to a free flow type muffler so long as the noise level is acceptable?
Since the SVTs were an option in '04 could I use any other of the stock SVT suspension parts legally?
Finally, any experience based recommendation on wheel and tire combos would be appreciated. Also suggested alignment.
Thanks, In advance.
Adios, David
Daschj is offline
Fan#: 1
Old 11-24-2008, 12:55 PM   #2
ajp
ajp's Avatar
Fan#: 54748
What I Drive: Red 2003 EAP
FF Reputation: 8 ajp Good Standing Member
the svts are G stock so Im not sure about the svt suspension. check out the forums on www.ubcscc.com, they have a section for these kinds of questions.
ajp is offline
Old 11-24-2008, 12:58 PM   #3
Dcl2049
MyCarBreaksAlot
Dcl2049's Avatar
Fan#: 18957
What I Drive: 2002 Malibu Blue ZX3
FF Reputation: 69 Dcl2049 Excellent Standing Member
I was under the impression that you have to use a stock wheel. I don't know if that means you can change them around at will based on all the different rims that there are, but I guess you could pick up some of the smallest steelies you could fit on those brakes. I race in street tire class so I'm out of the loop as far as R-comps go, sorry.
As far as the muffler, I don't know if I would spend any money there. I'm not sure welding a different muffler in would give you any measurable difference, and I don't know if they allow catback systems or not (still don't think you'd see much of a difference with all those cats, but I guess a catback would actually remove one so that's a no-no). If they make replacement high flow air filters for the 2.3 then see if you can grab one of those.
On shocks, someone correct me if I'm wrong but I seem to recall hearing how adjustables such as Koni yellows can be considered OEM replacements for stock class. You might want to look into those, as you can fine tune to match your driving.
It's been a while since I've read up on all the rules but I told you everything the way I remembered it. Good luck.
Yes, that is a banana in my pocket.
Dan - gumpcrew #4
[BBS][Borla][Focus Central][Hella][K&N][Koni][Lentech][Wings West]
#23 STS Wiregrass Region SCCA
Dcl2049 is offline
Old 11-24-2008, 05:13 PM   #4
MyBlackST
Capital Obvious
MyBlackST's Avatar
Fan#: 11768
What I Drive: 2008 Redfire Metallic Fusion
FF Reputation: 1 MyBlackST Good Standing Member
Buy-Sell-Trade Rating: (4)
As far as upgrade go to still play in "H" stock, you can do the following:
Air filter (not a CAI)
Shocks/Struts
Cat back exhaust
Wheels - You can run any wheel that is the same size (width/diam./offset) as what was available on you model car. If you don't have a SVT you could not use those wheels.
Tires - street legal tires...."R" comps should be allowed in your region since they are DOT approved.
For more details to the rules, Check out www.SCCA.com Click on the SOLO tab and check out page 62 of the rule book.
Drag racing is for fast cars, AUTOCROSS is for fast DRIVERS...
You can live in your car, but you can't race your house.
ST Crew #3
TEAM DURATEC # 7
MyBlackST is offline
Old 11-26-2008, 11:41 AM   #5
Daschj
Fan#: 59798
Howdy back:
Thanks for that info. Yes, I'm still reading and interping the SCCA rule book. Any advice or suggestions on a good tire for 16" stock type rims? "Good" meaning dual purpose street and autoXing.
Adios, David
Daschj is offline
Old 11-26-2008, 12:03 PM   #6
Dcl2049
MyCarBreaksAlot
Dcl2049's Avatar
Fan#: 18957
If I were you I would probably look for a set of steel 15's as those will have more choices available for tires and would probably weigh less (don't quote me on that part, but I think there's a sticky somewhere in Wheels/Tires with the weight of these). The sizes the Focus uses for 16s are kinda uncommon. I've seen people using Falken Azenis RT-615 on 15's which make a good street/track tire. They are more popular for Street Tire class though since Stock class can use R comps. There's a new Bridgestone Street/Track tire called the RE-01 that is supposed to be excellent.
Dan - gumpcrew #4
Dcl2049 is offline
Old 12-22-2008, 07:55 PM   #7
ronnycage
Fan#: 61444
What I Drive: 2001, black, honda s2000/07 focus
FF Reputation: 1 ronnycage Good Standing Member
Originally Posted by Daschj View Post
Howdy back:
Adios, David
ok i joined for some h stock info and ive been heavily researching this.
Id run the hooiser a6's kumho 710s or victoracers. they are all good, they heat up quickly and they are good for dry grip.
tires like the yokohama a048s and bfgoodrich gforce and michelin sport cups etc... all take too long to heat up and respond at better at higher tire temps 160 degrees and beyond. by the time you achieve that temperature your runs are done. def look into a good auto x tire dont settle on azenis unless your on a budget.
16s in a 205 45 16 should do you or a good 205 50 15 I think should be fine.
street/auto x I feel the yokohama s drives or the azenis will be fine... if your serious about autoX pick up a second set of wheels and let it rip!
konis are legal as long as theres no more then 2 adjustments and im pretty sure just dampening and non ride height or spring pre load works. someone correct me if im wrong.
"auto racing was born the day the second automobile was made"
2001 s2000 low loud and out of control sm2 killer
2007 gfs focus H stock killer
auto x for life!
ronnycage is offline
Similar Threads
"The Official/Unofficial SVT Header Conversion Guide" svtguy88 ZETEC Performance (2000-2004) 108 05-09-2013 07:37 AM
For Sale: stock parts fallacious_focus Archive 10 10-10-2005 07:40 AM
OE sedan Tailights, Ignition coil, Stock header and stock Cat for SALE!! no6969el Archive 4 03-17-2005 11:52 AM
i/e 2.3pzev vs stock civic si ???? mustang2focus82 DURATEC Performance (2003-2011) 38 12-14-2004 03:29 PM
Wings West Front Air Dam, 2000 Focus stock bumper, 2000 Focus stock suspension sale! meanpiolin Archive 0 07-10-2004 02:51 PM
