lateral headlight adjustment, 05-07 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-15-2008, 08:32 AM   #1
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Member bluefront Excellent Standing Member
Buy-Sell-Trade Rating: (6)
I wonder if anybody has tried to pull it off? My headlights (06) have up/down adjustment only....I guess all these cars are that way. My '95 Sentra also had a side-to-side adjustment. It was accomplished by a separate headlight mount bracket that was adjustable.
I wonder if a small amount of adjustment could be performed by enlarging the Focus headlight mount holes....or some other method? I only need a few degrees adjustment on both sides.
Pretty cheap of Ford to leave off this essential adjustment IMO.
I'll keep my guns, my freedom, and my money.....you can keep the "change".
bluefront is offline
Old 11-16-2008, 01:52 AM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
The bolts on the top of the radiator support allow a bit of side to side adjustment. Yes I have tried it with my car, but I really didn't gain any better night vision than factory, but I could notice that light dispersion changed slightly.
121,000 members and still no sponsored racing.
iminhell is offline
Old 11-16-2008, 04:38 AM   #3
bluefront
bluefront's Avatar
Fan#: 56816
Thanks for the reply.....gives me some hope I can pull it off anyway, maybe with some small enlargement of the mount holes. I've always been picky about headlight aim, and try for the same headlight alignment with every car I've owned. This is the first car I've had with a fixed side-to-side setup.
When you get older, you become more aware of these sorts of things, and getting it right becomes more necessary. I ordered a new set of headlights recently, so I'll have the things off for the install. Good time to do the necessary mods.....
When I get the right time to do this, I'll update this thread.
Old 11-19-2008, 04:50 PM   #4
bluefront
bluefront's Avatar
Fan#: 56816
Update.....I had the headlight housings off today, and got a chance to examine the mounts closely. Doing the adjustment mod looks to be possible, without much trouble. I suspect you could get 5-8 degrees adjustment.
How.....there are two location dowels that prevent adjustment. On my car I need the headlights to pivot outward slightly. To do this you would cut off the inner dowel on each side (closest to the center grill). You would also have to enlarge the upper mount holes in the headlight housing....and do a small amount of trimming of the outer bracket.
Now when finished, you would loosen the two upper mount bolts, and manually pivot the housing. This would involve some trials, and some road tests to get it set right. But it will work.
This mod I'm saving for next spring.....but it's possible if you're picky, or maybe your headlights are way out because of an accident.
Old 11-19-2008, 05:21 PM   #5
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
Move to: "Exterior Body & Lighting"
the Mach headlights have horizontal adjustment.
not sure of the 99-04 non-HID headlights have horizontal or not.
scrammer is offline
Old 11-24-2008, 05:21 AM   #6
bluefront
bluefront's Avatar
Fan#: 56816
Here's a photo of the location dowel you would have to cut. The part to cut off is circled. The other part would just rest on the core support, preventing the headlight assy from going downward at that point, but still allowing side-to-side adjustment. If you wanted a more secure mount......after you settled on a final adjustment, it would be easy to make a small bracket to tighten it down. (don't think that's necessary however).
Old 11-24-2008, 12:26 PM   #7
bergj1986
bergj1986's Avatar
Fan#: 57747
What I Drive: 2005 SEXZ FUCUS
FF Reputation: 2 bergj1986 Good Standing Member
Arrow My Cross-Eyed '05
I recently got eBay projector headlights and have been having some aiming issues. As most of you know, the headlights can be aimed vertically, but not horizontally. My drivers headlight is pointing a little to the right, however, my passenger headlight aimed even more to the right, making it's light output pretty worthless. Anyone have any ideas how I can correct for horizontal aiming? My car is an '05 ZX3.
Thanks!
I like my Focus cuz it's better than your Focus...
bergj1986 is offline
Old 11-24-2008, 12:51 PM   #8
bluefront
bluefront's Avatar
Fan#: 56816
I haven't done the mod yet......but I'm confident it will give you enough adjustment to make up for most alignment problems.
Old 11-24-2008, 06:54 PM   #9
bergj1986
bergj1986's Avatar
Fan#: 57747
Wow, I started a thread with this question and all of a sudden it turned into your thread, weird. I just got my HIDs and I'll be trying this mod in a few hours. I'll let everyone know how it goes.
Old 11-24-2008, 08:50 PM   #10
bluefront
bluefront's Avatar
Fan#: 56816
The mods merged your new thread with my original thread......and used your thread title.
I tried leaving out the lower mount screw (the one under the fender). You might get more adjustment this way. The upper two mount bolts seem to be plenty, as long as one location dowel is left in place. You might even try cutting both dowels to get more adjustment. Depends on how much adjustment you need. The outer mount bracket (by the fender) may need to be trimmed slightly on the edge, to gain a few more degrees.
I didn't have to do any mods to my new black headlights. The alignment was almost perfect. Report back and let me know the outcome...I'm interested.
Similar Threads
Headlight adjustment techniques.... bluefront MK1 Focus 4 07-28-2014 12:21 AM
Headlight bulb adjustment question BlueSEsvt MK1 Focus 7 12-01-2008 05:22 PM
Headlight Mod, Now Headlight Won't Work (help the newb!) NotMyZX3 General Technical Chat 11 03-04-2008 09:09 AM
Headlight Adjustment Ball out on HIDs Hubris MK1 Focus 0 07-03-2006 12:24 PM
Headlight adjustment kwack99 MK1 Focus 4 02-08-2005 09:58 AM
