#1 | ||||
Horn does not work
My horn does not work anymore. When I push on the wheel, I just hear a click click.
I have no clue where the horn is under the hood or what wires to check. |
Remove Advertisements |
Fan#: 1
#2 | ||||
Jetsetter
sounds like the horn itself is dead, it should be located under the drivers side front bumper, its kinda hard to miss once your under there
ZETEC Crew #26 SR #20 YELLOW BLAZE OWNERS GROUP#4 Moderator Pilot, 2 foci Owner! 04 SE Sedan [P RNDL], 12 SE HB ╠╬╝ Ford Focus Discussions, Ford Focus Marketplace, Ford Focus Tech Discussions, Movies & Music Fanatics, Regional Forums Advocare 24 Day Challenge! |
#3 | ||||
I have a 2003 LX and I have the same problem, i even got down there with a volt meter just to be sure its the horn and.... it is.
Law of Mechanical Repair, After your hands become coated with grease, your nose will begin to itch and you'll have to pee. Sedan Revolution # 157 |
#5 | ||||
...watch for finger!
Jealousy is contagious, Get well soon bitch! WWW.PATTERNTEK.COM WWW.SNAPOFFRACING.COM |
#7 | ||||
MACHINERY TECHNIAN
i plan to replace mine with some from a toyota tundra.. those are loud and sound sharp. much better than my stock ones. which don't work anyways
Carpe diem quam minimum credula postero ODOMETER: 162,000 miles |
#8 | ||||
The clicking is the relay near the fuse panel. One is for the horn and the other for the battery saver. ( turns lights off ) So you know the horn button on wheel and the fuse is okay. Horn is very simple to change. I put mine up behind the headlight because it kept getting filled with water. The stock location isn't good. I've done mine twice in the past year.
#9 | ||||
Mine just did the same thing so I put in an air horn kit, much better :)
'02 SVT - Sonic Blue Why does everyone get boost except me? |
#10 | ||||
The problem with the mounting is the horns have a little spiral like a seashell inside, and the mouth points down. Some of the water that gets shoved in when it rains, goes up over the top and is trapped against the metal diaphragm, which then rusts. I mounted mine pointed up, but drilled an 1/8" hole in the plastic body at the lowest spot when mounted to let the water out. It's only been about two years, but it's still working at the moment. I think I bought my horns from NAPA, they look the same and mount the same, but I had to change the lugs for the wiring weren't quite the same. Probably better to get them from Ford unless the price is way different between the two places.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Drive Through Car Wash Kills my horn!! | cowymo | Ford Focus & General Car Chat | 12 | 06-22-2007 05:35 PM |
| Stock alarm horn - 2k SE | vrat_on_2k | General Technical Chat | 1 | 09-09-2006 12:02 PM |
| Can any Ford dealer work on my SVT? | eurofocer | SVT Performance (2002-2004) | 7 | 06-20-2006 10:34 PM |
| Hard braking = Horn? | dantegl36 | General Technical Chat | 11 | 05-01-2006 11:48 AM |
