Focus 2002 Zetec - Water Pump Failure? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-15-2008, 08:32 AM   #1
stubee
Fan#: 60604
What I Drive: 2002 Silver Focus 1.6 Zetec-SE
FF Reputation: 1 stubee Good Standing Member
Question Focus 2002 Zetec - Water Pump Failure?
Hi Guys,
First post here as I need some help. I'm booked into my local garage on Tues but wanted some other opinions beforehand.
I've got a completely standard 1.6 Zetec-SE Focus which was fine until last week. I've noticed a few things since I started my diags this morning!
1. Both radiator fans are running all the time regardless of engine temperature. With my internal fan/blower set to 1 if I start the engine the fans will start immediately. With the internal fan/blower set to '0' I can start the engine and the fans do not spin. As soon as I move to position 1 both fans will kick in again. They will only stop when I then switch off the engine.
2. My temperature gauage quickly climbs to half-way and then just sits there ...
3. Opening the bonnet this morning, I've noticed a loud clicking noise comming from/near the water pump. I hear a loud click (as if trying to engage itself?) followed by a smaller click and a whirr a few seconds later .... This will reapeat itslelf with say 10-15 seconds between each loud click. This may be a coincidence but as the engine got warmer the clicking stopped altogether ..??
4. My radiator expansion tank is up to the full mark and I'm not loosing any coolant
5. After running the engine for 5 minutes - the radiator connection hoses only get warm/hot nearest the engine. I dipped my finger in the rad expansion bottle and the coolant was stone cold.
My initial impressions is that the water pump has failed - but would this cause the fans to run all the time?
Would be very interested to hear your opinions ..
Cheers,
Stu
stubee is offline
Old 11-15-2008, 02:02 PM   #2
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 460, Level 9
Points: 460, Level: 9 Points: 460, Level: 9 Points: 460, Level: 9
Level Up 20% Completed
FF Reputation: 17 nilskje Great Standing Member
Both fans running when blower on , indicates that A/C is on, the vent is set to defrost (air to windscreen) , clicking might be the A/C compressor clutch. The fans should stop after a few minutes with the blower switch set to 0, try that out first.
nilskje is offline
Old 11-15-2008, 11:15 PM   #3
briandg510
briandg510's Avatar
Fan#: 3966
What I Drive: 2001 Fort Knox Gold ZTS
Points 1,409, Level 21
Points: 1,409, Level: 21 Points: 1,409, Level: 21 Points: 1,409, Level: 21
Level Up 9% Completed
FF Reputation: 118 briandg510 Excellent Standing Member briandg510 Excellent Standing Member
Buy-Sell-Trade Rating: (13)
I think this guy is right. When the car doesn't overheat the water pump is working. How many miles on your odometer? When I replaced my water pump after hitting 95K miles I did not notice any wear on it. IMO the water pump is well built on Zetec engines.
briandg510 is online now
Old 11-16-2008, 12:23 AM   #4
TnFocus
Dumbledore dies?!?!
TnFocus's Avatar
Fan#: 49496
What I Drive: 05 zx4, 88 rx7 with v8 swap, 69 bug
FF Reputation: 8 TnFocus Good Standing Member
Not a zetec guy, but saw the post on the main screen. I agree with the above poster about the fans. It may be the thermostat. It sounds as if its not opening up alowing coolant to circulate.
Rx7 with built 383 stroker
7HR BOB-Jacob-gumpcrew #20
TnFocus is offline
Old 11-16-2008, 06:02 AM   #5
stubee
Fan#: 60604
Solved !
Thanks to the responses given guys - you just saved me a packet at the garage
Re. the fans running all the time - turns out it was set to defrost (windscreen). Setting this to internal vents & the fans switch of after approx 60 secs. So all was well here and working as per normal.
Re. the coolant, turns out the stat was knackered. Placed it in a bowl of boiling water and no movement whatsoever So, changed the stat for a new one and BINGO - flowing coolant that's piping hot so obviously going through engine, therefore the water pump is ok after all.
So, I'm a happy chappy thanks to you guys & this excellent forum.
Cheers,
Stu
stubee is offline
Similar Threads
Zetec electric water pump inis General Technical Chat 12 11-02-2007 03:52 PM
Even this fOCUS!!!! Jeezzzz!!!! TORQUERULES Ford Focus & General Car Chat 22 02-11-2007 11:47 PM
possible water pump failure? Dr_Watson General Technical Chat 26 10-05-2005 03:59 PM
Soon to come, more SVT parts for your non-SVT Focus... myFordPerformance.com ZETEC Performance (2000-2004) 32 05-02-2004 05:31 PM
Ford Focus: Parts Links hotfocus Member FAQ's & How-To Information Archive 0 10-21-2003 10:34 AM
