[:)][:)][:)][:)][:)][:)]NEW HKS Turbo Timers Available[:)][:)][:)][:)][:)][:)] - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Exclusive Vendor Discussions > Massive Speed
Massive Speed Discuss about forced induction upgrades and performance tuning for your Ford Focus.
Sponsored By: Massive Speed
Old 11-14-2008, 05:57 PM   #1
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Points 15,888, Level 81
Points: 15,888, Level: 81 Points: 15,888, Level: 81 Points: 15,888, Level: 81
Level Up 8% Completed
Buy-Sell-Trade Rating: (19)
HKS USA, Inc., celebrating its 35th year as the premier manufacturer and supplier of automotive performance systems and parts, is proud to announce the ninth generation of the HKS Turbo Timer.
In 1982 HKS introduced the world’s first Turbo Timer to assist in cooling down the turbocharger to prevent oil coking in the center bearing cartridge assembly. Oil "coking" occurs when a turbocharger is not properly cooled down and the oil that normally lubricates the center cartridge heats up and forms solidified oil deposits. A turbo timer allows an engine to idle for a preset amount of time after the ignition key has been turned to the off position and removed. By allowing a turbocharged engine to idle, oil continues to pass through the turbo until it has cooled down to the point where oil "coking" will not occur. Re-designed for 2008, the all new Turbo Timer Type-0 and Type-1 feature a new, slim low profile design with a separate LCD display and control unit following the same design concepts as the current HKS EVC and A/F Knock Amp.
The Turbo Timer Type-0 features a red LCD backlit display for easy visibility, 2 timer modes, and a battery voltage meter with a peak value indication and warning function.
The Turbo Timer Type-1 features a light blue LCD backlit display and has the same basic timing and voltage features as the Type-0 plus several monitoring and measurement functions. The Turbo Timer Type-1 features an Auto mode for the timer function allowing the Turbo Timer to automatically calculate optimum idling time according to the most recent driving pattern. Vehicle speed and RPM can be displayed on the Type-1's LCD monitor and a speed warning level can be set. A two-stage RPM warning can also be set and used as a shift indicator. When a warning level is reached the Type-1's LCD monitor will blink and an audible beep will sound. The HKS Turbo Timer Type-1 also features various measurement functions including 1/4 mile timer, 0-60 timer and a stopwatch function that can be used for lap timing. The Turbo-Timer Type-1 can read in either MPH/SAE or KPH/Metric.
The new HKS Turbo Timers are compatible with all HKS Turbo Timer harnesses to make for an easy installation.
Turbo Timer Type-0
* Part # 41001-AK009
* MSRP: $99
* Positive Lit LCD
o Red Back Light
* Black Display Case (W:89.5mm/H:22.5mm/D:13mm)
* LCD Display (W:41.5mm/H:11mm)
* Black Control Unit Case (W:69.0mm/H:80.0mm/D:21.0mm)
* Timer Functions:
o Manual Mode (0-10 Minutes)
o Memory Mode #1 (1 touch, 1 Minute Setting)
o Memory Mode #2 (1 touch, 3 Minute Setting)
* Battery Voltage Display:
o Battery Voltage
o Peak Value Indication
o ON/OFF Warning Function
* Compatible with all HKS Turbo Timer Harnesses
Turbo Timer Type-1
* Part # 41001-AK010
* MSRP: $155
* Positive Lit LCD
o Blue Back Light
* Timer Functions:
o Auto Mode (0-5 Minute Setting)
o Battery Voltage
* Vehicle Speed Indication Function:
o Vehicle Speed
o Peak Speed Hold Value
o Speed Warning Function
* Engine RPM Indication Function:
o Engine RPM
o Peak Engine RPM Hold Value
o Engine RPM Warning Function
* Display in either MPH/SAE or KPH/Metric
* Metric Distance Time Functions:
o Acceleration Distance (0-100m, 0-200m, 0-400m)
o Section Time (200-400m)
o Acceleration Time (0-100km/h, 100-150km/h)
o Auto or Manual Start for Quarter Mile Function
* SAE Distance Time Functions:
o Acceleration Distance (0-60 foot, 0-1/8 mile, 0-1/4 mile)
* Stopwatch Tool Time Measurement
o Total Elapsed Time
o Lap Times
Simple Hook up -
IN STOCK at Massive!!!
Type 0 - JUST $87.32
Type 1 - Just $135.71
Find em' in Here
K Dog is offline
Similar Threads
FEELER SALE: Turbonetics T3 Super60 Turbo tobyboom Archive 5 07-26-2006 01:45 PM
Turbo Set Up stillspoolin General Forced Induction 2 09-05-2005 04:13 PM
turbo stuff- maf, injectors, hks ssq bov, 2" ic pipe SVT ewx ca Archive 14 10-16-2004 06:08 AM
Turbo Questions - maybe a sticky eventually? petik General Forced Induction 5 10-11-2004 03:17 PM
