No 2003 Focus PCM communication. - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 11-13-2008, 10:21 AM   #1
Dirty Harry
Fan#: 60572
What I Drive: 2003 Focus
FF Reputation: 1 Dirty Harry Good Standing Member
Hey everyone. Great forum. I've been trying to pull codes on my sister-in-law's 2003 Focus 2.0 with no success. The car has a check engine light on and still runs ok. I've got an OTC Genisys that I just updated over the internet this morning with no success. It will pull codes for the other modules, (ABS, GEM, and airbag). Since the scanner will pull PCM codes on my 2001 Taurus and 1997 Explorer, I'm guessing it's the car. OTC's tech hotline suggested it's the wiring in the car and possibly the data connector wiring possibly to the PCM. Anyone else have an issue like this or can point me in the right direction? I'm looking to get an 03' Focus wiring diagram as soon as I can. Thanks.
DH
Dirty Harry is offline
Old 11-13-2008, 11:07 AM   #2
CHillRyde
CHillRyde's Avatar
Fan#: 29104
What I Drive: 01 Twilight blue 5spd ZX3
FF Reputation: 1 CHillRyde Good Standing Member
Sounds like it the DLC (data link connector). Its not getting power. in you get the wiring diagram pin out power and gound on the DLC. All DLC's have the same power and ground but I forget what terminals they are. I have come acorss this in VW's and Audi's but in their case its usually b/c an aftermarket radio has been installed and that screws up the DLC.
ZETEC CREW #101
Steeda short throw, CAI, & tower brace, Screamin Demon coil & Wires, FC TB, EBC brakes, SVT header kit, Random Tech cat, Magnaflow catback, Fidanza Cam gears, Ford Racing S2 cams, .410 springs, UDP, P&P head, Eibach Pro 1.5" drop.
CHillRyde is offline
Old 11-13-2008, 11:43 AM   #3
Blivit
Blivit's Avatar
Fan#: 51292
What I Drive: 2013 ST
FF Reputation: 118 Blivit Excellent Standing Member Blivit Excellent Standing Member
If the DLC was not getting power, your scanner would not power nor would it read anything. FYI, power is at pin 16 and ground is at pins 4 and 5.
Does your unit come back saying there are no PCM DTC codes or does it give an error when trying to read?
Blivit is offline
Old 11-13-2008, 12:25 PM   #4
Dirty Harry
Fan#: 60572
03' Focus no pcm communication
Yeah, I believe the scan tool is getting power from the data connector because I can monitor the other modules in the car. The unit comes back with an error saying that there is no communication with the car and to check the cables and the fuses in the car. I just ordered the Ford repair CD off of Ebay so I'll have to go from there. I don't know how the pins go in my data connector but once I get the manual, I'll check for power and ground there first.
Thanks.
DH
Old 11-13-2008, 01:08 PM   #5
CHillRyde
CHillRyde's Avatar
Fan#: 29104
Oh my bad, I though you werent getting power at all from the DLC to the scan tool, but you knew it works on your other cars.
ZETEC CREW #101
Old 11-13-2008, 02:00 PM   #6
Blivit
Blivit's Avatar
Fan#: 51292
Long shot but is there an aftermarket chip installed in the PCM?
I know with our stuff if there is a chip installed we cannot communicate with the processor. The chip has to be removed before we can datalog or flash.
Blivit is offline
Similar Threads
2008 Focus SpcghostII Ford Focus & General Car Chat 55 09-17-2007 08:05 PM
2003 Focus Central TB, and the TPS problem, install zGOTxBOOST2 ZETEC Performance (2000-2004) 6 09-23-2006 04:10 PM
APC 2003 Customized ZX3 Focus jchumney Archive 11 03-31-2005 04:44 AM
Soon to come, more SVT parts for your non-SVT Focus... myFordPerformance.com ZETEC Performance (2000-2004) 32 05-02-2004 04:31 PM
