Trunk wont latch - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-11-2008, 11:44 AM   #1
Tom-E09
Pimp'n ain't easy
Tom-E09's Avatar
Fan#: 59383
What I Drive: 2002 Gray ZTS
Points 9,998, Level 66
Points: 9,998, Level: 66 Points: 9,998, Level: 66 Points: 9,998, Level: 66
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 10%
FF Reputation: 2 Tom-E09 Good Standing Member
Trunk wont latch
so my trunk wont latch shut when
i had to sit on top of it to get it to stay shut I've heard this is a common problem so im up for any suggestions on how to fix it. or what the problem is
Sedan Revolution #138SR Town Drunk
Team Dreamspeed
Originally Posted by ChazimusZX4ST View Post
I come speeding along and they think I'm all "lets run" when in reality its "MOVE YOU POS, IT'S BURRITO TIME!"
God I love burritos.
Tom-E09 is offline
Old 11-11-2008, 12:29 PM   #2
necenece
Fan#: 60522
What I Drive: 2002 fort knox gold SE
FF Reputation: 1 necenece Good Standing Member
Mine started acting up a few months ago. When you push the button (key fob or on-dash) to unlatch the trunk, it makes a series of clicking noises, but you can open it. Once open, it won't latch. To get it to latch, we found that by pressing the trunk button again must reset something, and then it will latch. Good luck!
necenece is offline
Old 11-11-2008, 02:02 PM   #3
DaveCombs
DaveCombs's Avatar
Fan#: 50626
What I Drive: 05 Mazda3s 5dr
FF Reputation: 4 DaveCombs Good Standing Member
Don't know if this helps, but we recently did some suspension work on Ryan's '02 LX. We replaced the rear shocks and the struts, as well as springs all around. Anyway, to get to the shocks you have to take out all the panels in the trunk - the pieces that cover the tail lights, the center piece between those (where the latch is), and the fabric-covered panels over the wheel arches. Once we got it back together, it was difficult to close the trunk and it's also difficult opening it. You can press the remote release on the dash, but you still have to manually lift the trunk.
If you did any work in the trunk, make sure that plastic center piece inbetween the tail lights is in the right place and down tight.
Asshattery knows no bounds...
DaveCombs is offline
Old 11-11-2008, 11:35 PM   #4
carguychris
Fan#: 59179
What I Drive: 2005 Black ZX4 ST
FF Reputation: 3 carguychris Good Standing Member
Check that the striker is centered in the latch opening as the trunk is closed. You can observe it by lowering the seatbacks and closing the trunk from the inside. Another clue is to look for damaged finish from metal-to-metal contact. Once you verify that the striker is off center, you can loosen the bolts, move it sideways to center it, then retighten. The bolt holes have loads of slop to allow side-to-side adjustments. FYI you'll need a set of Torx sockets for this.
The strikers seem to go off center over time, probably from having stuff dragged over them and repeatedly getting whacked by the latch when the trunk is closed. When the striker is off center, it hits the side of the latch on its way down, making it difficult for the latch to engage all the way.
Centering the striker got my trunk to close properly, but I had to do a little more work to get it to open easily. When the latch hits the striker, a rotating plastic hook catches it. The trunk is held closed by a metal finger that catches a matching metal bump on top of the hook; when you press the trunk release, a solenoid withdraws the finger and allows the hook to rotate out of the way (that's the best way I can describe these parts- it makes more sense if you inspect the latch). My striker had worn an indentation in the plastic hook, which caused it to stick. I carved away the edge of the indentation with an X-Acto knife, and viola, the trunk now pops open like a champ.
carguychris is offline
Old 11-12-2008, 02:14 AM   #5
mlbbaseball
Shot me 3 deer!!!
mlbbaseball's Avatar
Fan#: 53541
What I Drive: 02 SVT, 2 7.3 L Diesel Excursions!
Points 27,847, Level 98
Points: 27,847, Level: 98 Points: 27,847, Level: 98 Points: 27,847, Level: 98
Level Up 50% Completed
Forum Activity 3%
FF Reputation: 42 mlbbaseball Great Standing Member
Buy-Sell-Trade Rating: (69)
there are also 2 bolts that bolt the locking mechanism to the trunk sheet metal. they tend to come loose and then the locking mechanism also isn't lined up! tighten them up as thats the easiest fix!
Now I rive 2 7.3 L diesel trucks!
mlbbaseball is online now
Old 11-12-2008, 06:36 AM   #6
Feral
Feral's Avatar
Fan#: 58350
What I Drive: 1 2002 / 2 2001 Wagons
FF Reputation: 53 Feral Excellent Standing Member
Buy-Sell-Trade Rating: (23)
x2 I picked up a wagon with the same symptoms and from investigating someone left something across the striker lock assembly and when they closed it they forced it back ( evident from the screw marks being off) I reset the locking mechanism back to the default spot and my door closes fine
Wagon Partout - http://www.focusfanatics.com/forum/showthread.php?t=212282
My Wagon Rebuild - http://www.focusfanatics.com/forum/showthread.php?t=217009
Feral is offline
Old 11-12-2008, 11:28 AM   #7
04FocusInSK
04FocusInSK's Avatar
Fan#: 53013
What I Drive: 2004 SE in Arizona Beige Metallic
FF Reputation: 1 04FocusInSK Good Standing Member
So here's a question..... With a sedan, is my trunk supposed to pop and actually open, or just pop, and then I have to open it myself? My wife's Sunfire, when she pops the trunk will actually open up, but mine doesn't. Lid stays closed, but it's unlocked.
Thanks! :) By the way, my car was rear ended before I bought it.
When I had my Ranger I swore I'd never buy another Ford. I knew there was a reason my mom told me never to swear!
04FocusInSK is offline
Old 11-12-2008, 12:37 PM   #8
Feral
Feral's Avatar
Fan#: 58350
Im not sure if there supposed to lift automatically ( I have a pair of Focus SE Wagons) but if my memory serves me right when I went to inquire about Lift Shocks they actually had ones for the Sedan yours may be weak and needing to be replaced... ( Just like mine which at the moment needs a 2x2 to keep it open XD there completely drained and I have a welt on my head to prove it)
Feral is offline
Old 11-12-2008, 02:28 PM   #9
DaveCombs
DaveCombs's Avatar
Fan#: 50626
I don't know if those little gas struts would be able to lift the sedan's trunk. They sure as heck don't right now!
Old 11-13-2008, 08:22 AM   #10
whitefox
whitefox's Avatar
Fan#: 54401
What I Drive: 2008 Ebony CC 2dr coupe SES 5spd
Points 1,961, Level 26
Points: 1,961, Level: 26 Points: 1,961, Level: 26 Points: 1,961, Level: 26
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 35 whitefox Great Standing Member
The trunk on my 08 just pops and you have to lift it yourself.
For Tom-E09, also check to make sure the latch is not dry - try putting a little synthetic grease on it after you confirm (readjust) the latch.
Carl - whitefox -
Team Duratec # 164
Mid-Atlantic Team EXTREME
2008 Focus Ebony Clearcoat 2dr SES 5spd
whitefox is offline
Similar Threads
New trunk latch beanhead07 Ford Focus & General Car Chat 3 07-27-2007 11:07 AM
Trunk latch... beanhead07 Ford Focus & General Car Chat 4 07-19-2007 12:32 PM
2000 Focus ZTS trunk latch whycoyote General Technical Chat 24 11-01-2006 01:18 AM
Broken Trunk Latch thejoshu Ford Focus & General Car Chat 9 07-09-2004 10:07 AM
Trunk latch problem... bszarek001 Ford Focus & General Car Chat 7 03-19-2004 03:10 PM
