Is it really worth it? - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 06-04-2009, 12:11 PM   #31
Blackcatn2o
soon to be turbo!
Blackcatn2o's Avatar
Fan#: 48278
What I Drive: 06 silver ZX4 ST
Points 8,020, Level 60
Points: 8,020, Level: 60 Points: 8,020, Level: 60 Points: 8,020, Level: 60
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 48 Blackcatn2o Great Standing Member
Buy-Sell-Trade Rating: (13)
I have to say the toe in on the front makes a big difference.
Blackcatn2o is offline
Old 06-04-2009, 01:00 PM   #32
xShiFTx
xShiFTx's Avatar
Fan#: 59110
What I Drive: 02 Sangria Red SE
FF Reputation: 5 xShiFTx Good Standing Member
Originally Posted by tukaniSVT View Post
From the looks of the fender gap ... that is some body roll.
-Ray-
Tons of body roll (stock suspension 133k miles), hopefully the bigger sway bar will reduce that a little as well. Eventually I am going to pick up some SVT shocks and dampers but that won't be for a while.
Could you explain? Going from the factory spec toe, to a more aggressive toe I really noticed no difference in handling.
xShiFTx is offline
Old 06-04-2009, 03:31 PM   #33
Auto-X-ZTS
Fan#: 54278
What I Drive: 2000 ZX2 S/R
Points 318, Level 6
Points: 318, Level: 6 Points: 318, Level: 6 Points: 318, Level: 6
Level Up 36% Completed
FF Reputation: 7 Auto-X-ZTS Good Standing Member
Toe out helps turn-in. Toe-in helps high-speed stability...
Erik B.
(_/\_-Head)
www.waiautox.org
___/\_____/\_____/\_____/\___
Auto-X-ZTS is offline
Old 06-04-2009, 05:33 PM   #34
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Originally Posted by xShiFTx View Post
my tires are getting killed. I have had to resort to swapping them on the rims occasionally (IE inside is running facing outwards).
Still running 42psi in the front??
Try 45-48 next time.
And, you shouldn't need 45psi out back.
I'd drop that down to 40.
WD40 is offline
Old 06-04-2009, 06:03 PM   #35
xShiFTx
xShiFTx's Avatar
Fan#: 59110
Yep, still running 42. I'll try your suggestion out this weekend.
It is not that they're getting killed, they just wear all the way down to the line where the sidewall meets the face (??) of the tire. This is past the wear indicators, but still technically not the sidewall.
I had the rears pumped up to 45 to try to promote some oversteer, but I'll it out!
xShiFTx is offline
Old 06-04-2009, 06:07 PM   #36
WD40
The Librarian
WD40's Avatar
Fan#: 5157
You never know till you try.
Sometimes getting out of your "comfort zone" is the only way to see improvements (or lack thereof at times).
I've run as high as 50psi in the front before I got stiffer sidewall tires and then camber plates.
WD40 is offline
Old 06-09-2009, 11:03 AM   #37
xShiFTx
xShiFTx's Avatar
Fan#: 59110
So I ran an event on Sunday, overall I was happy with my performace. I ended up 3rd in novice out of 7, and only an STi and an Evo X beat me.
I ran my tires at 48/42 and they seemed to handle well, I thought I was going to lose a bunch of traction by adding that much pressure in the front but I was surprised.
I like the 21mm FSB, it made transitions much more crisp and I could tell it eliminated some of my body roll. (Although it did add a tad bit of understeer)
The local SCCA is putting on a school the 27/28 so that will be my next time out. Plans are to put some toe-out up front, and run neutral in the rear. We will see how it goes!
xShiFTx is offline
Old 06-09-2009, 05:58 PM   #38
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Sweet! Thanks for the update.
So, ya like that much pressure up front now?
WD40 is offline
Old 06-09-2009, 06:02 PM   #39
1-ST
1-ST's Avatar
Fan#: 53127
What I Drive: various duratec powered vehicles
Points 721, Level 14
Points: 721, Level: 14 Points: 721, Level: 14 Points: 721, Level: 14
Level Up 21% Completed
FF Reputation: 10 1-ST Great Standing Member
Before I built my suspension, I always had better luck with higher pressures in the front. Don't worry about the FSB. Learn to adjust your driving to prevent understeer, or you'll go crazy over your setup and not improve your times or learn much. Plenty of national level stock class cars run big FSBs to control camber and improve transitions. Just don't overdrive it. Slow is fast! The best people out there are usually boring to watch.
05 ZX4 ST - parts donor. Daily driver until a rock found the oil filter and locked the motor.
08 S Coupe - autocross toy. Less weight and more tire.
06 Ranger - lowered commuter and parts hauler.
1-ST is offline
Old 06-09-2009, 06:20 PM   #40
zx360
zx360's Avatar
Fan#: 32439
What I Drive: 2005 black zx3 ses
Points 16,856, Level 83
Points: 16,856, Level: 83 Points: 16,856, Level: 83 Points: 16,856, Level: 83
Level Up 2% Completed
FF Reputation: 44 zx360 Great Standing Member
Buy-Sell-Trade Rating: (33)
it would be really nice if the link referenced at the beginning of the thread would get fixed
FocusFest 11' "Best in class" Oct'11 HOTM FITF'12 "Best Show & Shine" July 12 ROTM
instagram @360DSGNS
zx360 is offline
Similar Threads
Do you think 'Car Modding' is worth it? S2 Official Polls & Surveys 578 Today 02:16 AM
Limited Slip Differential Worth It? 2002silversvt5 SVT Performance (2002-2004) 49 04-15-2011 02:14 AM
How much is it worth? mdquack SVT Performance (2002-2004) 2 08-28-2005 01:03 PM
Will it be worth it? Volcom8234 ZETEC Performance (2000-2004) 9 04-08-2005 01:01 AM
