Replacing Ball Joint - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-04-2008, 11:49 AM   #1
zackattack784
Fan#: 29847
What I Drive: 2000 Silver ZTS
FF Reputation: 1 zackattack784 Good Standing Member
I took my '00 ZTS in for inspection the other day and just got a call saying the one ball joint needed to be replaced and the other will most likely need to be replaced come next year.
They said it would be over $300 to replace one, close to $600 for both. I see online that a ball joint for the focus is pretty cheap, is this something that is hard to replace and that's why it costs so much?
If not, is this something I could do myself? I'm at work so I haven't had a chance to look in the chilton yet.
Can anybody offer any insight on this? Thanks!
zackattack784 is offline
Old 11-04-2008, 02:28 PM   #2
whitefox
whitefox's Avatar
Fan#: 54401
What I Drive: 2008 Ebony CC 2dr coupe SES 5spd
Points 1,961, Level 26
Points: 1,961, Level: 26 Points: 1,961, Level: 26 Points: 1,961, Level: 26
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 35 whitefox Great Standing Member
Ball joints are usually fairly simple to replace, but I am not 100% versed on the Focus front suspension. I believe you should be able to do it yourself if you have a Chilton's repair manual.
Carl - whitefox -
Team Duratec # 164
Mid-Atlantic Team EXTREME
2008 Focus Ebony Clearcoat 2dr SES 5spd
whitefox is offline
Old 11-04-2008, 06:02 PM   #3
mrprichda2
mrprichda2's Avatar
Fan#: 36155
What I Drive: 07 Subaru WRX, 03 Focus SE
FF Reputation: 1 mrprichda2 Good Standing Member
They said it would be over $300 to replace one, close to $600 for both. I see on line that a ball joint for the focus is pretty cheap, is this something that is hard to replace and that's why it costs so much?
If not, is this something I could do myself? I'm at work so I haven't had a chance to look in the Chilton yet.
I am not an expert but I am in a similar situation. Ford made the control arm and the ball joint one piece. So you have to buy it as a whole. It just seems like to much money just to put one control arm/w ball joint on. You can buy the control arm at http://www.rockauto.com for a good price. If you have the right tools you can do it yourself with some help. If you cant just I would just supply them withe the part. I would replace both if you have the $$$$$.
MrPrichda2
mrprichda2 is offline
Old 11-04-2008, 06:13 PM   #4
bfgsvt
bfgsvt's Avatar
Fan#: 44617
What I Drive: 02 Blue SVT
FF Reputation: 1 bfgsvt Good Standing Member
ball joint
You can replace the ball joints on the Focus, you have to remove the control arm, and drill out three rivets. The replacement ball joint comes with nuts and bolts to fill the holes from the rivets. Spray every thing with penetrating oil before you start. The best way to free the ball joint from the spindle is with a long pipe attached to the control arm from below with a chain or heavy wire wound multiple times around. Have the car secured on jack stands and push down, it will pop out easily. I tried the first time with a hammer and pickle fork, with a torch and a hammer, and so on, but these methods didn't work as well as the pipe.
Good Luck
bfgsvt is offline
Old 11-05-2008, 12:22 PM   #5
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
Level Up 2% Completed
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Hell, why you're in there, replace the control arm bushings with some polyurethane inserts and maybe a stiffer sway bar. Along with some Moog Endlinks. But then you'd need to stiffen up the rear sway and bushings.
just saying.....lol
Mr.Bergner is offline
Similar Threads
Ball joint Torx bolt TeamPrecisionIT General Technical Chat 11 05-23-2008 10:47 PM
Ball Joint Question?? richcat04 General Technical Chat 10 11-09-2006 02:52 PM
Lower Front Ball Joint Boot has a rip... how to repair? joeblow General Technical Chat 4 04-25-2005 05:20 PM
Steering knuckle ball joint removal problem l88m22vette General Technical Chat 0 07-07-2004 06:32 PM
Steering knuckle ball joint removal problem l88m22vette Wheels & Tires 0 07-07-2004 01:42 PM
