Transmission Whine - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-31-2008, 03:48 PM   #1
90base
90base's Avatar
Fan#: 59586
What I Drive: 2003 Cd Silver LX
FF Reputation: 3 90base Good Standing Member
Transmission Whine
My car is a 2003 Ford Focus LX. SPI, MTX. IB5 Transmission
I had the clutch changed and they filled the tranny with 90 weight. I told them that was wrong and they put synthetic Transmission fluid in it. When it had the 90 weight it was really bad in Gears 1, 3, 5. Now that they have put in the correct fluid it only does it when the engine is cold, like when i start it in the morning. But it is still constant in 5th gear, just quieter.
Now before I had the clutch changed it still did it in 5th gear. Any Ideas"???
Law of Mechanical Repair, After your hands become coated with grease, your nose will begin to itch and you'll have to pee.
Sedan Revolution # 157
90base is offline
Old 11-01-2008, 12:59 PM   #2
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 460, Level 9
Points: 460, Level: 9 Points: 460, Level: 9 Points: 460, Level: 9
Level Up 20% Completed
FF Reputation: 17 nilskje Great Standing Member
Not really, have had this in both my focuses -00 1,6, ran for 220k miles b4 i sold it, and my present -04 1,6. The first one started to make this whine at 30k miles and it lasted until a gearoilchange at 150kmiles, my present also makes a slight whine om 5th at around 65mph uphill, guess i will try the replacing/refilling oil.
nilskje is offline
Old 11-01-2008, 05:55 PM   #3
90base
90base's Avatar
Fan#: 59586
NOte... It also does this in neutral when you let out on the clutch.
90base is offline
Similar Threads
Common Ford Focus Transmission Problem, How to fix aokrongly General Technical Chat 135 01-20-2015 10:36 PM
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 10:59 AM
Every trouble code defined 03OrangeSVT General Forced Induction 9 05-25-2011 01:53 PM
Could use some help please? Iceberg General Technical Chat 13 06-30-2009 10:26 PM
how do you fill a mtx-75 with fluid?!!!! help please!!!! firemanchev General Technical Chat 26 09-11-2008 07:18 PM
