No fuel pressure - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-30-2008, 02:52 PM   #1
FiFoci
FiFoci's Avatar
Fan#: 59433
What I Drive: 11' Mustang GT 5.0,01' Twilight Zx3
Points 7,198, Level 56
Points: 7,198, Level: 56 Points: 7,198, Level: 56 Points: 7,198, Level: 56
Level Up 24% Completed
FF Reputation: 6 FiFoci Good Standing Member
Buy-Sell-Trade Rating: (20)
No fuel pressure
i got his code. my symtoms r described below.
how to i reset the Inertia fuel shutoff switch?
P1233 - Fuel System Disabled or Offline LS6/LS8:
For LS6/LS8, P1233 indicates the PCM is not receiving the fuel level information on SCP from the rear electronics module (REM). Refer to the Workshop Manual Section 413-01 for diagnostics.
All Others:
The PCM monitors the fuel pump monitor (FPM) circuit from the fuel pump driver module (FPDM). With the key on, the FPDM continuously sends a duty cycle signal to the PCM through the FPM circuit. The test fails if the PCM stops receiving the duty cycle signal. Inertia fuel shutoff (IFS) switch needs to be reset
Open FPDM ground circuit
Open or shorted FPM circuit
Damaged IFS switch
Damaged FPDM
Damaged PCM
Also for Escort/Tracer and Mustang:
Open FPDM PWR circuit
Open B+ circuit to constant control relay module (CCRM) pin 11
Open ground to CCRM pin 18 (Mustang)
Damaged CCRM
Also for Continental:
Open VPWR circuit to FPDM
The PCM expects to see one of the following duty cycle signals from the FPDM on the FPM circuit: 1) 50% (500 msec on, 500 msec off), all OK. 2) 25% (250 msec on, 750 msec off), FPDM did not receive a fuel pump (FP) duty cycle command from the PCM, or the duty cycle that was received was invalid. 3) 75% (750 msec ON, 250 OFF), the FPDM has detected a fault in the circuits between the FPDM and the fuel pump.
when i start my car i have only about 1-6psi fuel pressure just enough to keep it idleing. it will stay at 1-6 only until i move the car. when i move the car it will SLOWLY build psi up to 57 then drop and setle at 39 then it fine until i restart the car in the morning the next day.
the CEL didnt come on but i got this code P1233.
so my question is how to i reset the Inertia fuel shutoff switch?
FiFoci is offline
Old 10-30-2008, 07:29 PM   #2
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Page 168 of your owner's manual. For some reason I cannot copy from the PDF version of the manual.
If you do not have your manual, you can download one free from http://www.fleet.ford.com
penguin is offline
Old 10-30-2008, 07:54 PM   #3
90base
90base's Avatar
Fan#: 59586
What I Drive: 2003 Cd Silver LX
FF Reputation: 3 90base Good Standing Member
Button in the front passenger kick panel, remove a piece of plasit(if it still has it) Press the button
Law of Mechanical Repair, After your hands become coated with grease, your nose will begin to itch and you'll have to pee.
Sedan Revolution # 157
90base is offline
Old 10-30-2008, 08:30 PM   #4
malim
malim's Avatar
Fan#: 55004
What I Drive: 2007 Ford Focus ST - Black
Points 972, Level 16
Points: 972, Level: 16 Points: 972, Level: 16 Points: 972, Level: 16
Level Up 72% Completed
FF Reputation: 4 malim Good Standing Member
Question, if the pressure is there but very small, doesn't that indicate a clogged fuel filter ??? Kind make sense in my head...
Just brain storming!!
I thought of shut off switch too, but the pressure is there... hmm
malim is offline
Old 10-31-2008, 04:46 PM   #5
90base
90base's Avatar
Fan#: 59586
Perhaps it is like a half tripped breaker and only letting a small amount of voltage to the pump, therfore giving Little to no pressure
90base is offline
Old 10-31-2008, 07:36 PM   #6
penguin
Fan#: 21700
Not impossible, but a one in several thousand chance.
Low pressure, makes me think of (1) clogged fuel filter, (2) bad fuel pump/strainer in the fuel tank, (3) pressure sensor/regulator problem.
penguin is offline
Old 11-01-2008, 01:18 AM   #7
FiFoci
FiFoci's Avatar
Fan#: 59433
i was able to reset it. so it was triggered some how??
but tonight i ran at the track and i kept losing fuel pressure at the top of 3 and the car would fall on its face (about 18psi) and some run it would hold about 36psi all the way to 7k my best time was a 15.8 at 86 and 16.1 when i lost pressure.
i used my x3 datalog for the fuel psi.
oh and i have an 03' pump in my 01 zx3...
FiFoci is offline
Old 07-08-2013, 12:29 AM   #8
micsachek
Fan#: 103604
What I Drive: 2001 green ford focus zx3
FF Reputation: 1 micsachek Good Standing Member
i also have no fuel pressure. where would be the best place to start? i hit a deer and tore up the body. i fixed the body work. i had to change out a radiator, A/C, timing chain cover, and alternator.
after all work is done i have no fuel pressure. anyone know a easy fix?
micsachek is offline
Old 07-08-2013, 02:55 PM   #9
micsachek
Fan#: 103604
anyone around?
Similar Threads
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 10:59 AM
32psi fuel pressure? Randaroo General Technical Chat 10 08-19-2008 08:35 AM
How to determine a vacuum leak or lack of fuel focus_SWT General Technical Chat 0 11-27-2007 08:36 AM
Fuel rail pressure sensor Ford cant find it zGOTxBOOST2 General Technical Chat 0 07-31-2007 09:22 AM
Excessive Fuel Pressure mr.squatch ZETEC Performance (2000-2004) 0 03-17-2006 10:36 PM
