fuel filter change (Diesel) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 10-29-2008, 11:07 AM   #1
duncan22
Fan#: 60161
What I Drive: 2002 blue focus diesel 115
FF Reputation: 1 duncan22 Good Standing Member
Hi,
Can anyone advise me about a fuel filter change on a ford focus diesel 2002.
The filter sits in an ideal position to change it in the engine bay but I have heard that the diesel is under pressure and if you disconnect the pipes air can get in the system and the car will not start... There is also something in the workshop manual about releasing the pressure before starting to change the filter.
Any advice on this would be appreciated.
Thanks
NB I know about filling the new filter with diesel before reconnecting the pipes.
duncan22 is offline
Old 10-29-2008, 02:48 PM   #2
whitefox
whitefox's Avatar
Fan#: 54401
What I Drive: 2008 Ebony CC 2dr coupe SES 5spd
Points 1,961, Level 26
Points: 1,961, Level: 26 Points: 1,961, Level: 26 Points: 1,961, Level: 26
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 35 whitefox Great Standing Member
Changing the fuel filter will not affect the fuel system. After changing the filter, let the fuel pump build the pressure for about a minute. Then start the engine. If there is any air to purge out of the system, it will do so after the engine starts. You will be able to tell because of the white exhaust - that is the air purging from the system. When the exhaust clears, it will be ready to drive.
Carl - whitefox -
Team Duratec # 164
Mid-Atlantic Team EXTREME
2008 Focus Ebony Clearcoat 2dr SES 5spd
whitefox is offline
Old 10-29-2008, 04:49 PM   #3
duncan22
Fan#: 60161
Whitefox,
Thanks for your help, will have a go at this over the weekend.
duncan22 is offline
Old 10-29-2008, 07:02 PM   #4
TnFocus
Dumbledore dies?!?!
TnFocus's Avatar
Fan#: 49496
What I Drive: 05 zx4, 88 rx7 with v8 swap, 69 bug
FF Reputation: 8 TnFocus Good Standing Member
There is a bleeder vavle on top of your filter, and whitefox nailed it.
Rx7 with built 383 stroker
7HR BOB-Jacob-gumpcrew #20
TnFocus is offline
Old 10-30-2008, 07:29 AM   #5
whitefox
whitefox's Avatar
Fan#: 54401
You are quite welcome. I had an F350 SuperDuty Supercab 4x4 8ft bed with the 6.0l power stroke diesel with auto trans. The fuel system on that was self priming, as is most all newer diesels. Even though the fuel system is pressurized, there is not much pressure on the system when the engine is not running. The high pressure is generated through the oil pressure (did not do the research to get a good explanation on this) and the fuel pressure at the injector is very high.
Carl - whitefox -
Team Duratec # 164
whitefox is offline
Similar Threads
Should I really replace my fuel filter every 48K?? 2000FordFocus General Technical Chat 24 03-30-2013 07:31 AM
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 10:59 AM
Lets talk about fuel pressure 03OrangeSVT General Forced Induction 71 03-28-2009 08:38 PM
i hate my fuel filter swimmerdude123 General Technical Chat 5 07-31-2006 03:30 PM
PZEV Fuel Filter johnbiagioni DURATEC Performance (2003-2007) 5 01-28-2006 04:07 PM
