How-To Datalog Wideband On XCAL 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-24-2008, 01:09 PM   #1
Wagamos
Stock
Wagamos's Avatar
Fan#: 21396
What I Drive: 2001 Malibu Blue ZX3; 03 ZX3 PZEV
Points 9,489, Level 65
Points: 9,489, Level: 65 Points: 9,489, Level: 65 Points: 9,489, Level: 65
Level Up 47% Completed
FF Reputation: 13 Wagamos Great Standing Member
Buy-Sell-Trade Rating: (4)
This is a how to for wiring your Wideband so that you can datalog with an Xcal3 and then how to setup your datalog file. I did this with my Innovate LC-1 wideband. Should be similar with any wideband, just different color wires for your wideband sensor. You can look in your wideband manual for the diagram for that.
Tools:
Wire Strippers
Soldering Iron
Solder
Heatshrink (optional)
Electrical tape
Terminal Connector
Lighter (only if you are going to use heatshrink)
Other things:
Xcal 3
6-pin Firewire cable (mine was 6 ft which is more than enough)
Pin chart that SCT's firewire cable comes with. It also worked from the one that I got from the computer supply store. If your colors are different then you will have to pin out your cable.
Lets begin!
WIRING WIDEBAND AND FIREWIRE TOGETHER
Step 1: Cut one end of the firewire off and strip enough of the outer wire off so that you can work with it. This is what you will see.
Step 2: Separate the wires so that you have the two input wire bundles available. Then strip the ends of all the wires except for the 5v (white) and the input 2 (red). Take the black, green, and blue wires and pull them to the side, these are your three ground wires for the firewire. You will later connect these with the ground wires from the wideband sensor.
(Optional Step): Put a piece of heatshrink tube over the analog output 2 wire (brown).
Step 3: Solder the Analog output 2 wire (brown) from the wideband to the analog input 1 wire (orange) from the firewire. Then place the heatshrink over the exposed wire and use the lighter to shrink it to fit the wire. Also fold the white and red wires over and use electrical tape to cover the ends.
Step 4: Take your terminal connector and the 5 ground wires and solder them together in the terminal connector. Should be the 3 firewire grounds black, green, and blue. Should also be the 2 wideband grounds white and blue.
Step 5: Find a spot to ground your wires and bolt them down tight. This is what I used but I do have all my wires located inside the car.
SETTING UP DATALOG FILE IN THE XCAL 3
Step 1: Power up the Xcal 3.
Step 2: Go to Datalogging and Setup datalog.
Step 3: Hit select to Overwrite previous configuration. Then choose the gasoline.dlf file.
Step 4: Scroll down to the bottom and you will see AIN 1, select it and then select wideband. Choose any other choices that you want to datalog as well, then hit cancel. You will be presented with a screen to choose your analog 1 input. Choose wideband. Then select your wideband (mine was LC-1). Then save your file. Thats it for setting up the datalog file.
Bone Stock
223whp/218wtq
Wagamos is offline
Old 10-25-2008, 08:49 AM   #2
Roushturboedzx3
I Fab Too Much
Roushturboedzx3's Avatar
Fan#: 42814
What I Drive: 2002 Liquid Gray ZX3
Points 14,483, Level 78
Points: 14,483, Level: 78 Points: 14,483, Level: 78 Points: 14,483, Level: 78
Level Up 9% Completed
FF Reputation: 20 Roushturboedzx3 Great Standing Member
Buy-Sell-Trade Rating: (18)
Hey Someone needs to sticky this i just did it and it works. this needs to be stickied to help everyone else out
New: 2012 Mustang GT premium
SOLD:RACE GAS 602whp 501tq Pump Gas SAE 454whp
Garrett GT3582r, Topmount, built motor, Ported head,Tuned by Fernando@RacingPartsSolution
I may not be the baddest, but the baddest dont Fu** with me
Roushturboedzx3 is offline
Old 10-25-2008, 06:25 PM   #3
Wagamos
Stock
Wagamos's Avatar
Fan#: 21396
Glad to hear it worked for you to! What wideband are you using?
It took me a little while to get it all working. I talked to Mike Rogers at SCT and he hooked me up with wiring diagrams and answered all my questions.
Bone Stock
223whp/218wtq
Wagamos is offline
Old 10-25-2008, 09:20 PM   #4
Roushturboedzx3
I Fab Too Much
Fan#: 42814
I have a aem wideband
Old 11-04-2008, 11:48 AM   #5
Damage
Fan#: 10682
What I Drive: 04 ZX3
FF Reputation: 5 Damage Good Standing Member
Buy-Sell-Trade Rating: (7)
Thanks for the how-to. It was very good. I also have the LC-1....the only difference is I had to use the analog 2 to log it in the xcal3, I did wire it up as per your instructions. Maybe our firewire was slightly different. Not a big deal. Thanks again.
Damage is offline
Old 06-14-2009, 06:45 PM   #6
hardSVT
Turbo Freak
hardSVT's Avatar
Fan#: 53566
What I Drive: 03 svtf
Points 13,954, Level 76
Points: 13,954, Level: 76 Points: 13,954, Level: 76 Points: 13,954, Level: 76
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 5 hardSVT Good Standing Member
whats the differance between 6-pin Firewire cable and a din9 cable?
RIP SVT
300hp mazdaspeed3
Rocco's built turbo zetec mine now!
hardSVT is offline
Old 06-14-2009, 08:47 PM   #7
pitchedblack04
Bewst Anyone!!!
pitchedblack04's Avatar
Fan#: 62993
What I Drive: 2004 turbo'd svt
Points 3,266, Level 35
Points: 3,266, Level: 35 Points: 3,266, Level: 35 Points: 3,266, Level: 35
Level Up 44% Completed
FF Reputation: 7 pitchedblack04 Good Standing Member
I also have an AEM wideband and will be referring to this when i need to datalog. Hey roush what wires did you use off the aem so ppl can refer to this if they have the AEM?
Deff needs to be stickied...
Car is for sale. Pm me for details.
pitchedblack04 is offline
Old 06-15-2009, 12:35 AM   #8
Wagamos
Stock
Wagamos's Avatar
Fan#: 21396
Different cables. The ends are different too. You would have to get a pin out chart and figure out which wire is which for that.
Bone Stock
223whp/218wtq
Wagamos is offline
Old 06-15-2009, 12:37 AM   #9
hardSVT
Turbo Freak
hardSVT's Avatar
Fan#: 53566
whats a pin out chart?
RIP SVT
300hp mazdaspeed3
hardSVT is offline
Old 06-15-2009, 06:22 AM   #10
pitchedblack04
Bewst Anyone!!!
Fan#: 62993
im guessin its like a wiring diagram of how the pins are layed out so you know which one is which.
Similar Threads
SCT Strategy flash vs xcal 2/3 R3d_RovrZX3 ZETEC Performance (2000-2004) 0 01-13-2008 08:15 PM
SCT XCal I vs. SCT XCal II Josh912 SPI Performance (2000-2004) 1 08-24-2007 04:37 PM
SVT XCAL 2 question- Extracting a tune onto your PC itbparada General Forced Induction 3 06-06-2007 03:03 AM
Sct Xcal Socal SVT SVT Performance (2002-2004) 11 04-03-2007 10:15 PM
For Sale: Hypnotics Tuned XCal II *SOLD* Charged SVTF Archive 15 08-03-2006 10:56 AM
