HTP Adjustable Rear Suspension - Toe Arms - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 10-01-2008, 06:07 PM   #1
HTPerformance
HTPerformance's Avatar
Fan#: 41307
What I Drive: 2002 SVT Focus
FF Reputation: 10 HTPerformance Great Standing Member
Buy-Sell-Trade Rating: (7)
HTPerformance.NET is proud to introduce a fully Adjustable Rear Toe Arm set! As many Focus and Mazda 3 tuners lower or even raise their rides to maximize performance, caster and camber angles can become skewed and do not exactly match the drivers’ needs. The HTP Adjustable Rear Toe Arm, when correctly installed will allow the tuner to fully adjust rear toe, and may also aid in achieving caster and camber angles desired for performance suspension installations. Other companies make their arms with inferior components such as paper thin rubber bushings that can wear quickly and are prone to dry rot; the use of mild steel alloys is also a terrible mistake when it comes to long lasting performance. Why make an adjustable STOCK arm? It just doesn’t make sense to us.
HTPerformance Adjustable Rear Toe Arms are made with only the best components:
• Our HTP Toe Arms are easily adjustable with a ¾” open-ended wrench
• Weighs less than the stock toe arms
• Stronger than the stock toe arms
• These sexy rods can replace those ugly rusted OEM arms
• Saves time over removing the old bushings, and pressing in new bushings as well as giving you the added adjustability (which gets you out to the track/street sooner).
• Adjustable Rear Toe Arm body is made from Billet 7075-T651 aircraft grade Aluminum alloy; which is much more expensive than 6061 and 2024. It is well worth the added expense for the additional durability and safety through increased strength.
• The Toe Arm body is red anodized to maintain structural performance over the life the part as well as providing a long lasting surface finish.
• The HTPerformance logo has been Laser Marked on the rod body
• High-grade Jam Nuts provide a locking mechanism for the rod which prevents stripping the rod end threads
• 3-piece QA1 Precision Products, Inc. Rod Ends
Ball:
o 52100 Bearing Steel
o Heat treated
o Hard Chrome Plated
Race:
o Stainless Steel
o Heat Treated
o Self Lubricating Teflon Lined (PTFE) – Much superior to grease fittings!
Body:
o Alloy Steel
o Heat Treated
o Protective Coated for Corrosion Resistance
This is NOT an Economy 2 piece mild steel rod end!
• Corrosion resistant 300-series Stainless Steel Spacers keep the rod end centered
These can be used with ANY strut/shock/spring combination.
This set replaces #4 Illustrated above.
Other companies will tell you that their toe arms alone will allow for every adjustment on the rear suspension, but this is NOT true. Be sure to use camber bolts in the curved upper control arm in conjunction with HTP Adjustable Rear Toe Arms and the stock lower arm camber bolts for the maximum aftermarket suspension adjustability.
If you demand the BEST for your ride, HTP is your go-to company!
MSRP: $175
Place an order on our website or contact sales@htperformance.net to order your set!!!
Add rod end boots for just $13.95
HTPerformance is offline
Old 10-14-2008, 01:15 PM   #2
FOCUSSTDRIVER
FOCUSSTDRIVER's Avatar
Fan#: 50034
What I Drive: 2007 pitch black zx4 st SAP1
FF Reputation: 4 FOCUSSTDRIVER Good Standing Member
adjustable toe arms
just wondering what they look like when on the car...and if anyone else has bought them?
really interested in these...
07ST
ST Crew #82SAP Crew#19
FOCUSSTDRIVER is offline
Old 10-14-2008, 01:48 PM   #3
HTPerformance
Fan#: 41307
These were on a customers' car in California. Quite a number of customers have purchased sets of these adjustable rear toe arms!
To see what a typical technician at a Ford Dealers' alignment experience would be with these, we took the 2006 D20 development car to Keene Ford. When we picked up the vehicle the technician told us, " I have never been able to fully align a Focus like this with a lowered suspension." He was highly suprised and impressed at the adjustability with the combination of the upper camper bolt and our HTP Adjustable Rear Toe Arms.
Drop me a line if you are interested, I can surely take care of you!
Cheers,
Brian
Old 11-16-2008, 01:49 AM   #4
BOOSTA
BOOSTA's Avatar
Fan#: 36047
What I Drive: 2003 White ZX3 2.3L Turboed Duratec
FF Reputation: 8 BOOSTA Good Standing Member
Buy-Sell-Trade Rating: (11)
how long would it take to install these u think?
----The Honda Eater----
BOOSTA is offline
Old 11-17-2008, 09:52 PM   #5
loudfocus01
loudfocus01's Avatar
Fan#: 26006
What I Drive: 2001 White LX 2002 Infra-Red Svt
FF Reputation: 107 loudfocus01 Excellent Standing Member loudfocus01 Excellent Standing Member
Buy-Sell-Trade Rating: (17)
I'd say about an hour or less if you have all the tools on hand, and you can get the stock bolts out easy.
O'Reilly Auto Parts
Store Manager
Oak Grove, MO
loudfocus01 is offline
Old 11-17-2008, 10:32 PM   #6
HTPerformance
Fan#: 41307
Corrosion is the likeliest cause for any delay in installing these. If your car is newer or don't have harsh winter conditions like we do up here in New England, then it will likely be less than an hour for installation. If you have significant corrosion on your bolts, look for some solutions to that and consider replacement hardware before you tackle the job.
Old 11-25-2008, 05:38 PM   #7
HTPerformance
Fan#: 41307
Looking to do a group buy for Christmas on these fine suspension pieces! Who may be interested? I can put together pricing after you post up your interest.
-Brian
Old 11-26-2008, 12:27 AM   #8
FOCUSSTDRIVER
Fan#: 50034
how much for a group by?
07ST
Old 11-30-2008, 10:03 PM   #9
HTPerformance
Fan#: 41307
Who else is interested so I can work on pricing?
Old 12-16-2008, 09:01 AM   #10
klodkrawler05
Sooooooooooo EURO
klodkrawler05's Avatar
Fan#: 47771
What I Drive: BMW's
Points 12,705, Level 73
Points: 12,705, Level: 73 Points: 12,705, Level: 73 Points: 12,705, Level: 73
Level Up 64% Completed
Forum Activity 9%
FF Reputation: 26 klodkrawler05 Great Standing Member
Buy-Sell-Trade Rating: (30)
i'd be interested in a group buy!
-Brad
'03 VW Jetta TDI - The Daily Commuter
'02 Chevy Corvette Z06 - The Toy
'99 Triumph Daytona - Death Machine
klodkrawler05 is offline
Similar Threads
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
Focus Rear Tire Wear - Camber Bolts or Control Arms? 2003focusowner Brakes, Suspension & Body Chassis 8 04-05-2008 06:32 PM
Rear suspension making weird noise... brandnew161 Brakes, Suspension & Body Chassis 9 12-30-2007 05:38 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
thunking rear suspension? anybody? jeremy SVT Performance (2002-2004) 14 02-27-2004 06:42 PM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
