help!! focus just dieing at idle - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-10-2008, 03:40 PM   #1
metallica_r
Fan#: 39339
What I Drive: 2003 ford focus zts
FF Reputation: 1 metallica_r Good Standing Member
Exclamation help!! focus just dieing at idle
ok, first my focus was dieing at idle in park or netural. then it started dieing in drive at stop signs and stop lights. I changed out the fuel filter yesterday and put some gas treatment and extra strength stp fuel injector cleaner today with a full tank of gas. Right now i am sitting about a hair above a 1/2 tank of gas and it's dieing in park and netural but not drive. As soon as i got home i tried some different things. I turned on the head lights, a/c, and the heater to see if it would drain down the motor and kill it's self again. nope it just kept running. then not even after me turning it all off it was about 10 seconds later it died. what is goin on?
If you need to know i have a 2003 focus zts 2.0L DOHC auto with over drive. and it has about 108 to 109,000 miles on it.
Please help me!
metallica_r is offline
Old 10-10-2008, 09:08 PM   #2
metallica_r
Fan#: 39339
gee guys thanks for the help.
Old 10-10-2008, 10:46 PM   #3
ZETEC-X3
Fan#: 58716
What I Drive: 2000 Dark Blue ZX3
FF Reputation: 5 ZETEC-X3 Good Standing Member
i think you have a bad fuel system, check your injectors again, fuel filter good, sparks plug, wires and coilpack dude, i had a similar problem and this thigs was what i did. hope this can help you out man.
ZETEC-X3 is offline
Old 10-11-2008, 08:04 AM   #4
metallica_r
Fan#: 39339
well first how do i check the injectors? and how many miles on a car should i change the coil pack? and man thanks for the help.
Old 10-11-2008, 12:36 PM   #5
cassano1029
Fan#: 6267
What I Drive: 2003 Red Focus SE
FF Reputation: 1 cassano1029 Good Standing Member
I have had the same problem i got a 2003 SE standard. Mine would go up and down at an idle finally it just would not idle at all. I replaced the Atoumatic Idle Control Valve AIC Valve) Their is a link here that tells you were it is here the link
http://web.archive.org/web/200708140...kemanifold.htm
You can do this yourself from underneath the car i did its not that bad to do just need to be patient with it Make sure that you put the rubber o ring back in?
That solved some of the problem. The other was a collasped PVC Valve hose at the back of the engine close to the fire wall and wraps around to the drivers side to the valve in front the engine. Mine was collapsed right at the back thei or 3 parts to this hose the one i need came rright off the engine here is a link for it. Someone has pics in this link.
http://www.focusfanatics.com/forum/s...pvc+valve+hose
I also had a bad battery connection corroted i guess cleaned them up and that also improved it.
These part here in Canada are a lot more than you will pay for them in the states so i won't even bother with the costs.
Hope that helped you out some?
cassano1029 is offline
Old 10-11-2008, 08:12 PM   #6
metallica_r
Fan#: 39339
i went to auto zone and they put it on the machine to see if any codes was comming up. nope not one of them. i talked with them and they said that i could be the egr valve or something in the plugs or wires. the egr is goin to run me about 78 bucks. i hope this works. also they said that it could be the fuel pump. that will wait untill last since it's goin to run me about 180 bucks, and would be the most time consuming to replace. It's driving me nuts.
Old 10-15-2008, 09:14 PM   #7
metallica_r
Fan#: 39339
ok, got my oil changed today and bought some plugs, wires, and air filter. driving home check engine light comes on. well i turn around where i am at and go to autozone and have them put it in the computer and see what codes it's pumping out. it says it's the o2 senser. well there goes 54 bucks. i bought it went home. put on the o2, plug wires (not plugs yet i lost my gapper.), and air filter. started it up still doing it. so i unhooked the battery to see if that would rest the engine light and it did. but still running like before. went to the gas station to buy a coke and what do ya know. check engine light back on. wow and how come i am not surprised? what could be goin on with this. i mean really. come on.
Old 10-17-2008, 08:44 PM   #8
metallica_r
Fan#: 39339
ok i ended up going back to autozone and they finaly did a print off on the troubleshooting code: P2195. this what the print out says. also i just changed my plugs cause i bought a gapper and it seems to make it better.
Definition
Lack of H02S-11 switch- Sensor indicates lean
Explanation
Ecm tried to correct for lean condition
ecm make a rich correction but was unable to bring with in specs
Probable Causes
1. Failed H02S sensor - I just changed it and upt a new one in.
2. Open or shirt circuit condition
3. Failed fuel pump or blocked fuel filter - i just changed the filter.
4. MAF sensor failure - i have the type i can't clean so i have to replace it
5. Vacuum leak
what do you think i should go with next?
Old 10-17-2008, 09:49 PM   #9
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
You can clean your MAF, look for the holes in the sides, use a Q-tip and alcohol carefully to wipe the resistors.
I don't think that's the problem. I think the problem is the IAC, and it's just closing off when it should be going to a lower flow state.
I would still do a very close inspection of every vacuum line, even to the point of removing each to see if the rubber was falling apart. Fortunately, there aren't that many compared to 80's cars.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-17-2008, 09:52 PM   #10
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
What I Drive: 2002 RED SVT Focus
FF Reputation: 175 WeeAsp Excellent Standing Member WeeAsp Excellent Standing Member
Welcome to FF !!!
I am 90% sure that this is a vaccuum leak.
Check underneathe the throttle body and in/around the PCV valve for the smaller vaccuum lines.
They tend to rest agains metal bits theat wear holes in them.
FORMER Avenging Moderator of the Apocalypse and Leader of the Axis of Oversteer
"I live with fear every day and sometimes, she lets me race."
2002 SVT Focus... Stock
WeeAsp is offline
Similar Threads
Introducing the redesigned 2009 Ford Focus Coupe Tom Ford Focus & General Car Chat 392 03-31-2009 02:20 AM
Focus won't idle when cold 919Maniac General Technical Chat 6 01-15-2007 09:22 AM
2008 Focus TimHickey Ford Focus & General Car Chat 5 01-11-2007 01:51 PM
Body/Lip Kit Companies S2 MK1 Focus 1 12-04-2004 05:20 PM
Soon to come, more SVT parts for your non-SVT Focus... myFordPerformance.com ZETEC Performance (2000-2004) 32 05-02-2004 05:31 PM
